Leaf spring advancements
#3127630
03/08/23 08:57 PM
03/08/23 08:57 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Has anybody thought about changing out the rear segment on a Calvert mono leaf for more or less stored energy .. has anybody ever mixed a composite rear segment with a steel front segment I'm currently working on changing things around looking for more stored energy however the Calvert Springs just do not have very much Arch definitely not as much Arch as I would like.. the rear end currently suspends 3 inches from ride height before the car has to fight the spring as well as the shock I'd like to increase that to 5 in of free travel and maintain a relatively low stance
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Leaf spring advancements
[Re: WHITEDART]
#3127651
03/08/23 09:42 PM
03/08/23 09:42 PM
Posts: 20,643 in a cattle trailer down by th...
Guitar Jones
Calvert will make any arch you want. I would call them and discuss it with them.
[Re: Guitar Jones]
#3127702
03/09/23 12:42 AM
03/09/23 12:42 AM
WHITEDART
bean town ....Ca
Not anymore the business has sold I just don't think they have the technical background anymore
[Re: WHITEDART]
#3127712
03/09/23 01:28 AM
03/09/23 01:28 AM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Landrum does leaf springs. Haven't talked to anyone at Calvert. Someone should be able to build a spring to spec.
Spring rate and compression at ride height. I'm not an expert but a low rate spring with enough arch to get it loaded and hold desired ride height will store more energy than a high rate spring that is deflected less..
More horsepower, gear, etc usually means less help needed from low rate springs to get the tire applied. i.e same car, same weight with a mild small block and automatic would get a different spring than a decent big block stick combo. Springs matter. They don't just hold the car up as some people think.
[Re: CMcAllister]
#3127741
03/09/23 10:01 AM
03/09/23 10:01 AM
WHITEDART
bean town ....Ca
My thinking here is a power Adder car has enough horsepower to separate the spring Beyond its neutral position down track on a motor car we lack down track horsepower which means the leaf spring is actually trying to pull the tire back up off the track.. this is just a theory for instance I have five and a half inches of shock travel and a leaf spring that only suspends two and a half inches from ride height.. so the car on separation actually is beginning to fight the leaf spring after two and a half inches I think ideally when I'm looking for is for the same right height and a leaf spring that will suspend five or six inches that way all of the action will be controlled by shock adjustment not the added variable of the spring
[Re: CMcAllister]
#3127742
03/09/23 10:02 AM
03/09/23 10:02 AM
WHITEDART
bean town ....Ca
More horsepower, gear, etc usually means less help needed from low rate springs to get the tire applied. i.e same car, same weight with a mild small block and automatic would get a different spring than a decent big block stick combo. Springs matter. They don't just hold the car up as some people think. . You're thinking exactly the same way I am I'm just trying to figure out the best way to get there
[Re: WHITEDART]
#3127750
03/09/23 10:17 AM
03/09/23 10:17 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Maybe try a section from a stock leaf spring and cut it to be a rear section?
68 Barracuda Formula S 340
[Re: WHITEDART]
#3127757
03/09/23 10:45 AM
03/09/23 10:45 AM
Posts: 9,856 MI, usa
dvw
MI, usa
My thinking here is a power Adder car has enough horsepower to separate the spring Beyond its neutral position down track on a motor car we lack down track horsepower which means the leaf spring is actually trying to pull the tire back up off the track.. this is just a theory for instance I have five and a half inches of shock travel and a leaf spring that only suspends two and a half inches from ride height.. so the car on separation actually is beginning to fight the leaf spring after two and a half inches I think ideally when I'm looking for is for the same right height and a leaf spring that will suspend five or six inches that way all of the action will be controlled by shock adjustment not the added variable of the spring Exactly, the more power you have the less help you need with planting the tire. So without a poer adder, you want a spring with less rate. To acomplish the same ride height with leafs there are 2 options. #1 mount the spring attaching points lower in the body. Since your instant center seems to be working that means moving the rear slider. #2 find a spring segment with more arch. There are probay more places that could built a steel spring then there are a composite. The trick is knowing what rate you need. Any arch could be put into a steel spring.
[Re: WHITEDART]
#3127778
03/09/23 12:33 PM
03/09/23 12:33 PM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
My thinking here is a power Adder car has enough horsepower to separate the spring Beyond its neutral position down track on a motor car we lack down track horsepower which means the leaf spring is actually trying to pull the tire back up off the track.. this is just a theory for instance I have five and a half inches of shock travel and a leaf spring that only suspends two and a half inches from ride height.. so the car on separation actually is beginning to fight the leaf spring after two and a half inches I think ideally when I'm looking for is for the same right height and a leaf spring that will suspend five or six inches that way all of the action will be controlled by shock adjustment not the added variable of the spring So maybe its time to call your shock guy. Most of the fast leaf spring cars are using the blue Afco's or Santuff shocks...I know the valving is key... https://www.afcoracing.com/store.aspx?itemid=3548&pagetitle=Big-GunRhodes makes it seem simple: https://www.motortrend.com/features/leaf-spring-tips-tricks-x275-racer-ron-rhodes/
[Re: challenger451ci]
#3127840
03/09/23 03:11 PM
03/09/23 03:11 PM
Posts: 4,688 On the parachute mount
n20mstr
just add a small plate kit ..... I know...... LMAO , im just being "that guy" Props for keeping it all motor The level your at now......info doesnt seem to come easy . As already mentioned, get with a "good" shock guy and hopefully you get some help. ALSO 235 radial cars are right at your ET level, and yes they have a power adder but some are leaf spring cars and maybe some of that info can crossover to your program. Are you data logging, and do you have rear shock sensors to see the travel as the car is going down the track?? AND ....nitrous cars dont add power down track, usually the kit is all in by .9 or less , so in reality you are pretty close to a 235 radial car
....BAD A$$ STREET CAR.....
[Re: WHITEDART]
#3127859
03/09/23 03:53 PM
03/09/23 03:53 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
More horsepower, gear, etc usually means less help needed from low rate springs to get the tire applied. i.e same car, same weight with a mild small block and automatic would get a different spring than a decent big block stick combo. Springs matter. They don't just hold the car up as some people think. . You're thinking exactly the same way I am I'm just trying to figure out the best way to get there DA shocks to control it all. Maybe some fancy shocks to hold the housing out until you want them to release. With some of the stuff I'm involved with now, I'm getting into OEM suspension stuff more than I have in the past. Same principles apply. A spring - coil, leaf, torsion - all react the same to a change in rate and preload/compression at ride height.
[Re: WHITEDART]
#3127868
03/09/23 04:35 PM
03/09/23 04:35 PM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Not anymore the business has sold I just don't think they have the technical background anymore Shiloh, Not sure where you heard that Cavert has sold but apparently it is not true. I asked the company about it and this was their response: "No sir, not true at all, John Calvert is still owner, he did move to Arizona a year ago, so maybe that is why someone thinks this."
I have not used their customer service lately so I can't comment, it used to be excellent. Bill
[Re: 340Cuda]
#3127887
03/09/23 06:26 PM
03/09/23 06:26 PM
Posts: 2,515 PA
moparacer
PA
My theory is as stiff as possible on the front segment and soft on the rear. Kind of mimic what a ladder bar does with the front being stiff and the rear having the springs that hold up the car. All the rear segment would do is technically hold the car up.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3127894
03/09/23 07:04 PM
03/09/23 07:04 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
My theory is as stiff as possible on the front segment and soft on the rear. Kind of mimic what a ladder bar does with the front being stiff and the rear having the springs that hold up the car. All the rear segment would do is technically hold the car up. I've wondered about using tubing for the front segment and the rear section from a calvert spring. It would eliminate the need for any type traction bar............I think.
[Re: n20mstr]
#3127955
03/09/23 10:31 PM
03/09/23 10:31 PM
WHITEDART
bean town ....Ca
just add a small plate kit ..... I know...... LMAO , im just being "that guy" Props for keeping it all motor The level your at now......info doesnt seem to come easy . As already mentioned, get with a "good" shock guy and hopefully you get some help. ALSO 235 radial cars are right at your ET level, and yes they have a power adder but some are leaf spring cars and maybe some of that info can crossover to your program. Are you data logging, and do you have rear shock sensors to see the travel as the car is going down the track?? AND ....nitrous cars dont add power down track, usually the kit is all in by .9 or less , so in reality you are pretty close to a 235 radial car yeah working closely with mensker there shocks are on all four corners and have been back and forth a few times to tune them up.. yes we have racpak unfortunately we do not have travel sensors at this time however we do video under car often typically the problem is at the area that we want to work on is .3 to .4 typically. And I do agree with your statement regarding the 235 tire stuff. on a good track like Vegas or Sacramento a 1.12. 60 ft is common on the marginal tracks where I think we can be better.
[Re: 340Cuda]
#3127957
03/09/23 10:33 PM
03/09/23 10:33 PM
WHITEDART
bean town ....Ca
I have not used their customer service lately so I can't comment, it used to be excellent. Bill I have been an advocate for Calvert for many years it has been noticed that there has been a change I guess
