Gen III Hemi into a Fusie #3127465
03/08/23 09:00 AM
03/08/23 09:00 AM
Coastal Maine
Mr onetwo Offline OP
Coastal Maine
Good morning to all,
I am starting the planning for swapping a Hemi into my 1970 Plymouth Fury III convertible.It is a 318 car so the existing drivetrain has no special value by itself. I am going to purchase a whole running or wrecked vehicle as I want to utilize as much of the oem computers, wiring and accessories as possible. Being a C-body I have a lot of room for everything.This has been done successfully a few times so I know it is possible.
My question is what series of Hemi should I target. My preference is to get a car with the 5.7 Eagle and the ZF 8HP70 transmission as I have a 2014 Ram 1500 Laramie that is as smooth as butter...a truly amazing vehicle. This generation may be too complicated to swap...I am not sure.Would it better to find a 2005 up Chrysler 300c with the NAG1 trans. I am not afraid of either the dropped valve seat issue in the 03-08 engines or the lifter/cam failure issue of 2009 - up. I have the budget to fix that stuff before the engine goes in. I know the NAG1 fits without slicing up the floor...not sure about the 8 speed.I am also hoping to get as many comments on whether MDS delete is worth it...I am inclined to think not. Keep in mind this engine will basically be in stock form with any upgrades for durability and reliability.I will be rebuilding the entire suspension and upgrading the brakes, ect.
Please feel free to give me your thoughts...and thank you in advance
Early or Late Gen III Hemi
single choice
Votes accepted starting: 03/08/23 08:59 AM
You must vote before you can view the results of this poll.
Re: Gen III Hemi into a Fusie [Re: Mr onetwo] #3127505
03/08/23 01:39 PM
03/08/23 01:39 PM
BDW Offline
BDW  Offline
I would get as new as possible, the early motor is already a 20yr old design.
I would hope the later motors would have most issues worked out.
Re: Gen III Hemi into a Fusie [Re: BDW] #3127517
03/08/23 02:18 PM
03/08/23 02:18 PM
ILLINOIS
V
volaredon Online content
volaredon  Online Content
V
ILLINOIS
Stay simple, either LA, BB, or carbd magnum.
Re: Gen III Hemi into a Fusie [Re: volaredon] #3127582
03/08/23 05:57 PM
03/08/23 05:57 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
Eagle all the way, its flat out superior to the early design and they make everything to do the swap, its not exactly new either as it came out in 2009.
Re: Gen III Hemi into a Fusie [Re: Dart 500] #3127621
03/08/23 08:34 PM
03/08/23 08:34 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
You may already have found it but a guy did this swap to a '72 Fury Suburban some years back over on Cbodydrydock.
http://cbodydrydock.com/e107_plugins/forum/forum_viewtopic.php?87680.0
I believe his swap used the older 545rfe transmission but I'm sure the thread would be of some help. The swap starts on page 12.
Re: Gen III Hemi into a Fusie [Re: 440newport] #3127696
03/09/23 12:11 AM
03/09/23 12:11 AM
IL
furious70 Offline
furious70  Offline
IL
it's basically the same cost to get the nag1 or TF8 working. I would personally go late model to get the improved lifters. The different years have different FMEA mount and locations. You should study those to see what will work best for what you want to do. I tested both the car setup and later truck in my coronet. Some day I may do a gen III in my Fury. Rough measurements show the car orientation of the alt might fit and not hit the a arm. Of course now Holley also sells an expensive but useful FMEA that moves things around for conversions. The a/c compressor low slung usually hits the conversion mounts I think, not needed for my Coronet so I didn't test that but quite sure it would hit the mounts or the K member itself.
The 03-04 truck FMEA is actually the easiest to work with if you want a/c and ps from what I've seen, but the water pump design changes on an eagle I think? And you wouldn't be able to run a car intake, which is ok because the truck intakes have more tq.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Gen III Hemi into a Fusie [Re: furious70] #3127729
03/09/23 08:40 AM
03/09/23 08:40 AM
Coastal Maine
Coastal Maine
I see a/c as being the biggest problem in this swap.I may look into an electric driven compressor that is compatible with R12...may not exist. I really prefer the TF8 but the cost of the donor is important. After looking at a bunch of videos I wonder if a non-mds early block with a full eagle head swap including pistons might be the way to go.Put a 392 cam and lifters in it with the right springs.Opinions? shruggy
Re: Gen III Hemi into a Fusie [Re: 440newport] #3127731
03/09/23 08:49 AM
03/09/23 08:49 AM
Coastal Maine
Coastal Maine
Thanks, I had forgotten about that one.Haven't been over on the dock in quite some time.I think the transmission he used is the cause of a lot of unnecessary work...would never use a 545RFE.
Re: Gen III Hemi into a Fusie [Re: Mr onetwo] #3128011
03/10/23 01:06 AM
03/10/23 01:06 AM
IL
furious70 Offline
furious70  Offline
IL
I would never use the truck trans either. Very goofy ratios and still big.
In that combo you get HotRodDave's high CR engine that he really likes.
392 cam is the best value in cam for sure. I have one for the eventual 5.7 in my coronet
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Gen III Hemi into a Fusie [Re: Mr onetwo] #3128678
03/12/23 07:41 AM
03/12/23 07:41 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I voted older. As you stated you're going to fix the issues first and are budget minded. wrench
Re: Gen III Hemi into a Fusie [Re: redraptor] #3130262
03/18/23 04:33 AM
03/18/23 04:33 AM
Coastal Maine
Coastal Maine
Well, my vote is in.I just ran into a 2012 5.7 Eagle in a Ram 1500. 113,000 miles, turns over easy and no metal in the oil.Comes with all the wiring and controllers for $500...not bad at all.Now I have to make a decision on the transmission, but I have plenty of time.
Re: Gen III Hemi into a Fusie [Re: Mr onetwo] #3130278
03/18/23 09:21 AM
03/18/23 09:21 AM
IL
furious70 Offline
furious70  Offline
IL
Score!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Gen III Hemi into a Fusie [Re: furious70] #3130581
03/19/23 03:11 PM
03/19/23 03:11 PM
K
Kiddart Offline
Kiddart  Offline
K
that is a huge score!! where are these deals for me??
Thank you
Kiddart
Re: Gen III Hemi into a Fusie [Re: Kiddart] #3131172
03/21/23 05:01 PM
03/21/23 05:01 PM
Coastal Maine
Coastal Maine
Yep, it is a rippin" deal! boogie I am going down Thursday to get it.I am going to try to get the OBD2 port and wiring and the lower radiator support for fabbing. Is there anything else I should try to get? I am going to get an 8hp70 so none of that stuff in necessary. Also not going to use the gauges from the 2012.Maybe the tank and pump...I don't know?
Re: Gen III Hemi into a Fusie [Re: Mr onetwo] #3132077
03/25/23 07:27 AM
03/25/23 07:27 AM
Coastal Maine
Coastal Maine
Well, we got it home in one piece.It looks to be in pretty decent shape, but only time will tell if I made a mistake or not.Now I have the summer to find a transmission.
Re: Gen III Hemi into a Fusie [Re: Mr onetwo] #3132488
03/26/23 05:02 PM
03/26/23 05:02 PM
K
Kiddart Offline
Kiddart  Offline
K
if you change your mind shoot me a PM i will gladly pay you what you paid.
Thank you
Kiddart
Re: Gen III Hemi into a Fusie [Re: Kiddart] #3133797
03/31/23 05:35 AM
03/31/23 05:35 AM
Coastal Maine
Coastal Maine
Sorry dude....not gonna happen
Re: Gen III Hemi into a Fusie [Re: Mr onetwo] #3133798
03/31/23 05:38 AM
03/31/23 05:38 AM
Coastal Maine
Coastal Maine
Well, I just got what I think is a pretty good deal on a 8HP70 to go with the Hemi.From a 2014 truck with 78,400 miles...will be a fun build this winter.
