Re: Measuring for pushrods
[Re: 6PAX]
#3127358
03/07/23 06:40 PM
03/07/23 06:40 PM
Posts: 4,457 Washington
madscientist
Washington
As I have mentioned in another post, I had originally installed a solid lifter cam in my new motor (still on the stand, never run) and have since changed my mind and decided to go with a milder hydraulic cam which is now installed. I had originally measured for and bought new 3/8" push rods for the solid cam that were 8.425" in length. I'm not sure as I don't have the rocker arms installed yet but I suspect they may be too long for the hydraulic cam so I likely will need to remeasure again for new pushrods. However, I need my memory refreshed on the measuring process. I have a set of adjustable pushrods to use for measuring. This is what I was planning to do. Set the roller of the rocker arm so it is resting on the valve stem. Have the rocker arm adjuster set so that approx. 1 1/2 threads are sticking out of the arm. Have the intake and exhaust lifters setting on the base circle of the cam. Insert adjustable pushrod and adjust it so it is snug in the rocker arm cup to where you can still turn it with your fingers. Take out the adjustable pushrod and measure it then add .030 to allow for hydraulic preload. Does this sound right? I add .060 but .030 will work. If you bought Smith Brothers or Trend pushrods they will shorten them for you. They may do another brand of pushrod but I’m not sure about that. You’d have to call and ask. It’s cheaper to shorten them than to buy new.
[Re: 6PAX]
#3127391
03/07/23 09:02 PM
03/07/23 09:02 PM
Posts: 4,209 New York
polyspheric
New York
How much preload do the lifters need?
Boffin Emeritus
[Re: 6PAX]
#3127420
03/07/23 11:38 PM
03/07/23 11:38 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
[Re: polyspheric]
#3127525
03/08/23 02:39 PM
03/08/23 02:39 PM
Posts: 5,648 Detroit area
6PAX
Detroit area
How much preload do the lifters need? The instructions that came with the cam (Lunati) say this for adjustable rocker arms (no specific number mentioned): On engines with shaft-mounted adjustable rocker arms, we recommend fully backing off all adjusters prior to installing the rocker shaft assembly. Be sure the pushrods are properly “seated” in the lifters and rocker arms before starting your adjustment procedure. NOTE: Improper adjustment of the rocker arms can cause the valve to hit the piston upon engine rotation! On hydraulic lifter cams, rotate the engine in the normal direction of rotation until the exhaust valve begins to open. At this point, adjust the intake valve to ZERO LASH with no pre-load at the lifter, then tighten 1/2 more turn. Rotate the engine again until the intake valve has fully opened. Now you can adjust the exhaust valve to ZERO LASH, then 1/2 more turn. Repeat this procedure until each cylinder is completed. But they do specify an actual amount of preload for non-adjustable rocker arms: On engines with non-adjustable rocker arms, you must have a lifter pre-load of .020” to .060”.
[Re: 6PAX]
#3127526
03/08/23 02:43 PM
03/08/23 02:43 PM
Posts: 8,899 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
On engines with non-adjustable rocker arms, you must have a lifter pre-load of .020” to .060”. I'd hardly call a range of .040" "specific" !!!
[Re: 6PAX]
#3130790
03/20/23 11:54 AM
03/20/23 11:54 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
You did this as well correct?
"rotate the engine in the normal direction of rotation until the exhaust valve begins to open. At this point, adjust the intake valve to ZERO LASH with no pre-load at the lifter, then tighten 1/2 more turn. Rotate the engine again until the intake valve has fully opened. Now you can adjust the exhaust valve to ZERO LASH, then 1/2 more turn. Repeat this procedure until each cylinder is completed."
[Re: 6PAX]
#3130928
03/20/23 07:31 PM
03/20/23 07:31 PM
Cab_Burge
I did it in the order in this chart. Forget that 40 yr. od GM chart Use the new, better, correct method describe above on the valves opening and closing . This works well on 1.5 ratio rockers, I use 1/10 to 1/3 turn preload (depending on iron or aluminum heads) on 1.6 or higher ration rockers on hydraulic lifters You can also use the piston at top dead center method on the firing stroke also Another thing to consider is the adjuster diameter and thread count, the 3/8x24 adjusters have .042 adjuster movement for one full turn, the 7/16x20 adjusters have .050 per thread movement 1/2 turn on the 3/8 adjusters is .022 preload, 1/2 turn on the 7/16 is .025 the devils is in the details
[Re: INTMD8]
#3131174
03/21/23 05:12 PM
03/21/23 05:12 PM
6PAX
Detroit area
"rotate the engine in the normal direction of rotation until the exhaust valve begins to open. At this point, adjust the intake valve to ZERO LASH with no pre-load at the lifter, then tighten 1/2 more turn. Rotate the engine again until the intake valve has fully opened. Now you can adjust the exhaust valve to ZERO LASH, then 1/2 more turn. Repeat this procedure until each cylinder is completed." I adjusted the rockers that way today and it didn't change anything. For some reason just the one rocker/pushrod combo is different from the rest. When I have the adjuster backed all the way out and the pushrod in place, I can't turn the pushrod with my fingers without the lifter turning slightly as well. If I pull upward on the pushrod very slightly as I am spinning it the lifter stops turning in the bore. So, since it looks like the pushrod is just starting to push down on the lifter plunger without having set any lash, instead of doing the half turn to set the lash I only did a quarter turn.
