Re: Thermostat probe
[Re: NITROUSN]
#3127288
03/07/23 02:19 PM
03/07/23 02:19 PM
Posts: 10,232 Someplace you aren't
SomeCarGuy
Thank you for posting that. My plugs in the housing are so corroded that it would require a torch by all the perfect stuff in my engine bay. Should be able to slip this in and use an aftermarket gauge. I don’t trust the factory one all that much.
I want my fair share
[Re: TJP]
#3127519
03/08/23 02:24 PM
03/08/23 02:24 PM
Posts: 272 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Shouldn't be to hard to find, The mancini piece is nice but bend me over rover LOL .
Speedway, jeg's Summit, circle track, Ebay AND Amz. It’s only $15 more than the Meziere I use, and I would have gladly paid that for the better positioning of the sensor
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: Moparite]
#3128101
03/10/23 12:05 PM
03/10/23 12:05 PM
Posts: 6,306 nowhere
Sniper
nowhere
Flex a lite makes a fan controller with a probe you put in the rad hose by the radiator. You also can adjust what temp you want the fan to come on at. link I looked at them, the do not make an in the hose probe. They make two types, in the fins and a thread in sensor set up.
[Re: terzmo]
#3128383
03/11/23 11:47 AM
03/11/23 11:47 AM
Posts: 146 Missouri
randavis
Missouri
I am using the adaptor that Mancini sells on my 440 based 511. AndyF makes it. It is a high quality piece. I'm using it to provide a place for a zinc anode to protect the aluminum heads, water pump housing, and radiator. It doesn't stand out, looks wise. I have got to the point that I realize that parts that are made for our old mopars are going to be expensive, so if I think I need it, I bite the bullet and buy it and don't look back.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: randavis]
#3128415
03/11/23 01:10 PM
03/11/23 01:10 PM
Posts: 1,008 rust belt
Moparite
rust belt
They make two types, in the fins and a thread in sensor set up. Well they used to because i have one. The kit comes with a piece of tapered rubber you put on the probe so the clamp doesn't crush it(inside the hose at the upper rad inlet). They may not make it anymore but you should be able to adapt one to work. Here is one but not flex a lite. link
[Re: NITROUSN]
#3128596
03/11/23 09:29 PM
03/11/23 09:29 PM
Sniper
nowhere
I never liked that shove the probe into the hose method. Crude and rude to me. Probably a reason they don't make it any more.
[Re: Sniper]
#3128769
03/12/23 02:04 PM
03/12/23 02:04 PM
Posts: 15,489 Omaha Ne
TJP
Omaha Ne
You'd be much better off putting your temperature sensor where the coolant enters the block. That way you are using the OUPUT of the radiator to control the fan. That is how it is on my 1 Plymouth when I converted it over.
It is also how the OEM's have done it for years. Which to clarify, is on the engine side of the T'stat not the radiator side. This will give you the most accurate reading of the engine temp. Putting it anywhere else can be misleading/ disastrous if the thermostat malfunctions as you would then be reading the radiator coolant temp not the engine temp. Spal sells 2 preset sensors that I have had very good luck with. They can be used with normal 5 pin relay (available anywhere). they control the fans by grounding the relay coil. I have new ones still in the packaging, If anyone is interested PM me TS-185 it turns on at 185 and of at 165, I have One TS-195 it turns on at 195 and off at 175, I have 2 or 3 Pretty sure I even have a few or their wiring kits. if anyone is interested PM me
[Re: TJP]
#3128834
03/12/23 07:25 PM
03/12/23 07:25 PM
Posts: 19,589 north of coder
moparx
i agree the temperature sender or probe needs to be after the radiator, and preferably in the water jacket around the cylinders. a good place [in my opinion] would be where the block drain plug is located. i am also a guy that likes to see the engine temperature at, or around, 195-215 or so. this is with a 16lb or higher [20-22lb dirt track radiator cap] radiator cap, and a 35-50% mix of water and coolant. i think the extra heat produces a tick more oomph from the engine, as well as making sure all acids and moisture's are boiled out of the block internals. remember, this is just my [old man] opinion. your mileage will vary.
