Page 6 of 7 1 2 3 4 5 6 7
Re: Strange rivets [Re: topside] #3126872
03/06/23 12:06 AM
03/06/23 12:06 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Originally Posted by topside
Well, here's a stock, 17,000-mile unrestored '69 RR's trunk lid. SPD 2/12/69, St Louis.
'68-'69, there were 2 versions of the underside: a panel with cut-outs, and the full panel.
OP's car has base interior but Decor Group B-pillar caps. Those caps were available separately, but that's extremely rare.
I've seen the cracking mentioned on 1 or 2 HT B-pillars, but not on Coupes.
What I've seen of the subject car so far indicates a past incorrect restoration, and likely some major repairs early in its life.
I'm not buying special bodywork by the factory; I don't recall seeing a similar car in any of the early road tests or the traveling caravan Plymouth had.
It's good to keep info exchange.
THe quarter skin will crack where it transitions into the jamb. It would be interesting to see if the torque on a post car would result in cracking there. If the incorrect resto prevails I'd say this car has lead a pretty pampered if not mostly stationary life.
Again info exchange to find out more.
Re: Strange rivets [Re: srt] #3126873
03/06/23 12:18 AM
03/06/23 12:18 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
What option got you the b pillar caps without the A87?
I want my fair share
Re: Strange rivets [Re: SomeCarGuy] #3126879
03/06/23 01:22 AM
03/06/23 01:22 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Yes the A87 option would get you the bright B-pillar molding BUT it would also get you the "Decor" interior with rear arm rests with ashtrays, etc and the high-grade seat covers which it appears not to have. The M07 stand alone molding option would get you just the bright B-pillar molding.
Mike
Re: Strange rivets [Re: A12] #3126880
03/06/23 01:30 AM
03/06/23 01:30 AM
SomeCarGuy Offline
SomeCarGuy  Offline
Thanks, I’m sure I’ve never seen a tag with that code on it.
Re: Strange rivets [Re: SomeCarGuy] #3126883
03/06/23 01:56 AM
03/06/23 01:56 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Not sure, yet it is shown as an (E) extra cost option on pg 26 of the Dealership Data Book
Here <- Click
On page 30 it indicated (by lack of an *) it was available outside of the complete ""Decor Package" along with "rear Armrests with Ash Receiver".
I no expert of the nuances of ordering, yet believe the above.
I see 33 mo. back you looked at a green rr with the same trim/ and w/o decor.
Hope the above helps.
fwiw I'm not certain and would have to look through a bunch of old pics: there was green rr that came out to some gatherings in the sf bay area in the late 80's driven by the son of original owner (had passed away) it must have been parked in a narrow garage as there were scrapes and dents the entire length of both sides. I believe the car had the bright b pillar covers (and can't honestly recall if it had the decor pkg.
I was typing when you two exchanged info. In the linked pages it's interesting about the front seats. Decor pkg available only on post car, and buckets or vinyl bench (available in pkg only - noted on pg 30).
Re: Strange rivets [Re: srt] #3126886
03/06/23 02:47 AM
03/06/23 02:47 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
There's a few things that I would like to know about like the "double stripe" S- standard on a Sport Satellite that I have never seen??? The double stripe is not available on any other model but standard on the Sport Satellite? Or is this for '68 models which after looking at it again appears to be as it list a S- standard reflective stripe for the GTX which there was but the reflective stripe on my '69 GTX was E-extra? This must be for '68 B-body models.
Re: Strange rivets [Re: srt] #3126896
03/06/23 06:53 AM
03/06/23 06:53 AM
SomeCarGuy Offline
SomeCarGuy  Offline
Here <- Click
I remember that car. It had the decor seats and no b pillar trim. Tag didn’t match the resto and was a lynch rd car so limited intell on it to begin with.
Re: Strange rivets [Re: SomeCarGuy] #3126908
03/06/23 09:41 AM
03/06/23 09:41 AM
robertop Offline OP
robertop  Offline OP
The car came with the lighting package, chrome b pillar covers, chrome door top edges, Super Track Pak, power steering, 3-speed windshield wipers, and Deluxe 3-spoke steering wheel.a
Strange rivets #3126911
03/06/23 09:53 AM
03/06/23 09:53 AM
robertop Offline OP
robertop  Offline OP
One more thing: the negative battery cable was attached to the long bolt that holds the power steering box. The cable in the photo is a Frank Badalson part, a very good reproduction. The original cable obviously has no engine pint , since it was installed long after the engine was painted.
Re: Strange rivets [Re: robertop] #3126923
03/06/23 10:23 AM
03/06/23 10:23 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
That makes no sense to me at all as the reason it was painted was it was attached to a bare or unpainted engine block or intake manifold to make a good GROUND. Attaching it to an already painted power steering pump bracket or even a painted engine/intake point would be asking for trouble IMO. Not buying that the factory did that.
Mike
Re: Strange rivets [Re: robertop] #3126927
03/06/23 10:39 AM
03/06/23 10:39 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
It had to have a 3-speed wiper because with the standard with a Hemi "Air Grabber" big oval air cleaner cover the 2-speed wiper motor was too close to it, in fact I think it even hits it. I also thought because of the weight of the Hemi engine power steering was standard too? Also I thought it was either an optional wood grain three spoke steering wheel or the standard Deluxe 3-spoke for '69 and no base 3-spoke like the taxi cab base '68 RR steering wheel? The A01 light package had the delayed ignition key light, map light, trunk light, glove box light and console courtesy lights if equipped with a C16. Chrome door top edges? Do you mean "Belt Molding"?? (M31) like my Y4 A122 above?................and why another new thread for a ground cable shruggy wink
Re: Strange rivets [Re: A12] #3126935
03/06/23 11:23 AM
03/06/23 11:23 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Not sure ps was required seen several w/o it.
Re: Strange rivets [Re: A12] #3126942
03/06/23 11:53 AM
03/06/23 11:53 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
yes, my bad. I had checked the 68 and 69 for b pillar molding and copied wrong tab for link. Here is correct <- Click.
Fortunately the b pillar molding was avail both years as (E).
I wonder about early production cars using prior year parts, this the reason (I had a couple tabs open) hoping whoever looks the car over inspects those items.
Re: Strange rivets [Re: srt] #3126946
03/06/23 12:02 PM
03/06/23 12:02 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
PS optional regardless of engine - I've had 2 Hemi RRs with manual steering.
Sport Satellite striping was unique to that trim level, was lower on the body - visible in '69 brochure.
Decor Group on RRs brought interior up to the Satellite trim that was included on HTs, BUT:
Around 1985-6 I looked at an apparently original '69 RR HT that had the base interior, low-option car.
It was a red car, black interior, 4-speed, low-option, in Burbank CA.
To date - and from when they were introduced - it's the only such anomaly I've ever seen.
That said, a buddy back then bought an original '68 Super Bee from its original owner, who'd had the dealer swap its black seats & door cards for white.
Re: Strange rivets [Re: A12] #3126948
03/06/23 12:10 PM
03/06/23 12:10 PM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
Quote
It's the 3rd new thread that's been started about this topic. I've merged the latter 2 into the original.
Earning every penny of that moderator paycheck.
DBAP
Re: Strange rivets [Re: not_a_charger] #3126985
03/06/23 02:06 PM
03/06/23 02:06 PM
robertop Offline OP
robertop  Offline OP
Thanks for the moderator to combine my posts. I did not know how to do that, so good move!
Re: Strange rivets12 [Re: A12] #3126988
03/06/23 02:13 PM
03/06/23 02:13 PM
robertop Offline OP
robertop  Offline OP
I will take a picture and show it, but I really don’t know if it will be different or not.
Re: Strange rivets [Re: robertop] #3126991
03/06/23 02:23 PM
03/06/23 02:23 PM
You can't do it. Just keep posting in this topic instead of starting new ones.
DBAP
Re: Strange rivets [Re: A12] #3126993
03/06/23 02:25 PM
03/06/23 02:25 PM
robertop Offline OP
robertop  Offline OP
Well, I remember many years ago I was reading few articles from an important expert that I will not name about these cars were put together at the factory. In one article he said it was a known fact that in the beginning some mechanics used to put the ground cable where mine is, and in another article he denied that. So take your pick. I have to agree that is kind of stupid, if they did it, because there is a chance of a bad contact! On the other hand, I drove the car daily for 10 years with no such problem…..
Re: Strange rivets [Re: robertop] #3128078
03/10/23 11:25 AM
03/10/23 11:25 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Thinking about this car.
emission controls?
headrests?
shoulder/seat, or seat belts?
resonator hangars?
k frame, wiper motor, trunk lip and rad bulkhead?
There is likely more to add beside dates of various original parts present.
When "restored" was used above a lot of this stuff should have been documented. Surely op knew what he had going into the work.
