B/RB rear-main side seals with pipecleaners?? #3125971
03/02/23 05:10 PM
03/02/23 05:10 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
Wanted to ask this question on the general forum...
After the seal retainer is properly aligned and torqued in place, do you then force the RTV or silicone (from the tube) into the side seal area from the small opening at the pan rail surface? And then, per John K. and Mitch, insert a ~2 3/4" piece of damp pipe cleaner into the same opening?
Is the adhesive silicone preferred over RTV?
Thanks. I've only used the old cardboard or rubber side seals and wanted to try this method.
-Mike
Re: B/RB rear-main side seals with pipecleaners?? [Re: WarEagle1] #3125975
03/02/23 05:25 PM
03/02/23 05:25 PM
I use the stock side seals, make sure they are all the way in and are touching the block were the main seal holder seats wrench I then use adhesive silicone and a putty knife to fill the main seal holder against the block on the crankshaft flange side including both sides of the bottom of the seal holder wrench up
No pipe cleaners used by me down twocents
Re: B/RB rear-main side seals with pipecleaners?? [Re: Cab_Burge] #3126078
03/02/23 11:51 PM
03/02/23 11:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Many retainers have a larger gap on one side than teh other. Therfore I don't use side seals. Fill the grooves with Ultra Grey RTV before installing the main seal retainer. Then squesze a little additional in at the top of the groove. Fill the retainer bolt recesses as well. Not all gaskets and pans fully cover that area. Have never had a rear main leak.
Doug
Re: B/RB rear-main side seals with pipecleaners?? [Re: dvw] #3126132
03/03/23 10:38 AM
03/03/23 10:38 AM
ILL
Greentween Offline
Greentween  Offline
ILL
Doug
I did similar, only I would add that when I assembled without the side seals like mentioned but dry. Once retainer is installed to fill the sides I used a luer lock syringe and 12ga blunt needle. Worked like a charm to fill up the side seal gaps. Used "Right Stuff" sealant.
Re: B/RB rear-main side seals with pipecleaners?? [Re: WarEagle1] #3126151
03/03/23 12:05 PM
03/03/23 12:05 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
The moisture in the pipe cleaner helps the silicone cure properly.
Re: B/RB rear-main side seals with pipecleaners?? [Re: R/T1968R/T] #3126193
03/03/23 02:26 PM
03/03/23 02:26 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Myself, I don't use anything. never had a leak either. But will admit I never put oil in them 🤣
