Pinion Snubber Install Torque Spec #3125835
03/02/23 06:48 AM
03/02/23 06:48 AM
Canada
Ghoste Offline OP
Ghoste  Offline OP
Canada
Is there a torque spec for the mounting bolts on the stock pinion snubber attachment plate? I dont see one in the fsm anywhere.
I see a light at the end of the tunnel, and it's... ELECTROLUMINESCENT!
Re: Pinion Snubber Install Torque Spec [Re: Ghoste] #3125915
03/02/23 02:03 PM
03/02/23 02:03 PM
moparx Offline
moparx  Offline
the typical grade 5, 3/8-16 thread can be torqued to 25-30ftlbs.
basically as tight as you can using a 3/8 drive ratchet or standard length box wrench.
beer
Re: Pinion Snubber Install Torque Spec [Re: moparx] #3125938
03/02/23 03:25 PM
03/02/23 03:25 PM
Canada
Ghoste Offline OP
Ghoste  Offline OP
Canada
Thank you.
Re: Pinion Snubber Install Torque Spec [Re: Ghoste] #3126017
03/02/23 08:14 PM
03/02/23 08:14 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
wave Hi Ghost , Factory Service Manual , Section 16 Propellor Shafts and Universal Joints Section . Tightening Reference , Pinion Bumper Plate Screws 7- 1/4 Axle 150 INCH Pounds . Pinion Bumper Plate Screws for 8.75 Axle , 9-1/4 Axle , and the 9 - 3/4 DANA 60 Axle , 200 INCH Pounds Per Factory Service Manual ! drive Hope this Helps , Ronnie wrench
Re: Pinion Snubber Install Torque Spec [Re: 1969ronnie] #3126102
03/03/23 06:12 AM
03/03/23 06:12 AM
Canada
Ghoste Offline OP
Ghoste  Offline OP
Canada
Ah, prop shaft was a section I didnt think to look. I tried axle and rear suspension. Thanks. (looks like I have them overtightened as I went with the 25 lbs)
Re: Pinion Snubber Install Torque Spec [Re: Ghoste] #3126119
03/03/23 09:45 AM
03/03/23 09:45 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
When you can't find a torque specification for a bolt in the FSM I usually resort to a reference guide.
Such as
https://www.portlandbolt.com/technical/bolt-torque-chart/
Re: Pinion Snubber Install Torque Spec [Re: Sniper] #3126176
03/03/23 01:25 PM
03/03/23 01:25 PM
moparx Offline
moparx  Offline
i used that calculator to determine the torque of a plain, [unplated, non lubed] 3/8-16 grade 5 bolt.
it came in as 31ftlb. i had suggested 25-30ftlb.
if i were to be installing the snubber plate, i wouldn't worry too much about what torque value the FSM states. i would just tighten it good with a medium length 3/8 drive ratchet and call it good. having installed [quite] a few of these over a 50+ year span as i have described, none have ever come loose, or have had any bolts broken or stripped threads in the housing.
however, one could always revert to the tried and true method of part installation that has worked forever. "tighten it up until it strips or breaks, then back it off 1/2 a turn."..........[i couldn't resist. biggrin]
beer
