pump premium or race gas?
#3125421
02/28/23 08:18 PM
02/28/23 08:18 PM
RapidRobert
63 dart 360 2bbl 9-1CR circle track. I can use either one. I wouldn't think pinging would be an issue tho I dont have quench. iirc there was something about race gas burning slower??? which should I use? thank you for your time. RR
Re: pump premium or race gas?
[Re: Cab_Burge]
#3125544
03/01/23 08:24 AM
03/01/23 08:24 AM
Posts: 9,863 MI, usa
dvw
MI, usa
My wifes Challenger 360 is 9.0-1. I've used pump 93 to race. But It runs 87 on the street. Cam is 220@.050/110 lca. It gets beat on every time I drive it. Never an issue. Been together since 2004. Not sure it even needed 93. Doug
[Re: RapidRobert]
#3125596
03/01/23 10:51 AM
03/01/23 10:51 AM
Posts: 2,930 A shed in England
Tig
A shed in England
63 dart 360 2bbl 9-1CR circle track. I can use either one. I wouldn't think pinging would be an issue tho I dont have quench. iirc there was something about race gas burning slower??? which should I use? thank you for your time. RR Just out of interest, I was watching engine masters last night. They tried 87, 93, 109, 116 octane and E85 on a 530hp LS engine. Only the E85 made more power. The gasolenes made almost the same power (plus or minus roughly 3-4 hp IIRC) and needed the same timing. The conclusion was if the engine runs optimal on the lower octane fuel, increasing fuel octane won't make any more power AND If the higher octane fuel makes optimal power at the same timing, It can't be burning slower.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3125769
03/01/23 08:33 PM
03/01/23 08:33 PM
RapidRobert
good info! I got my work cut out for me. I'll work on the handling first. thanks guys. RR
[Re: Tig]
#3125828
03/02/23 01:35 AM
03/02/23 01:35 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
I think that's a good point. It's not that higher octane burns slower. (can't really have race fuel and slow burn with say 20,000rpm F1 cars for example) but if you look at specific energy or btu/lb.... pump fuel is a bit higher than race fuel in that regard. So yes, if higher octane isn't needed......but used.....the result can be lower output, but for reasons other than burn speed. (which is rather similar between varying types of gasoline)
[Re: INTMD8]
#3125847
03/02/23 09:13 AM
03/02/23 09:13 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Pump 93. Anything more is a waste of money.
[Re: Dragula]
#3125928
03/02/23 02:53 PM
03/02/23 02:53 PM
Posts: 4,457 Washington
madscientist
Washington
Pump 93. Anything more is a waste of money. That is all I run, and I get it from the same pump each week to insure consistency. The only thing consistent about pump gas is it’s inconsistency.
[Re: RapidRobert]
#3126010
03/02/23 07:53 PM
03/02/23 07:53 PM
Posts: 4,209 New York
polyspheric
New York
Race gas additives displace gasoline, energy content per gallon goes down (HT Vizard).
I've read that high octane gas burns more slowly, but that's not the only anti-knock measure. Not all fuels have the same sensitivity (heat, physical shock, electrical current): you can drown a lit match in a bucket of kerosene. TNT (2,4,6-trinitrotoluene) is far more powerful than dynamite, but it won't explode if you hit it with bullet. TEL (tetra ethyl lead) increased octane for Spitfires' Merlin engines 80 years ago, but kills the whales, or something.
Boffin Emeritus
[Re: Dragula]
#3126048
03/02/23 09:48 PM
03/02/23 09:48 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
Pump 93. Anything more is a waste of money. That is all I run, and I get it from the same pump each week to insure consistency. Does that station get the same gas from the same refinery with the same gas year around? Or does it buy its fuel from the cheapest supplier they can by from? Do they have winter, spring, summer and fall mixes? We do have them, different mixes, out here on the west coast
[Re: Cab_Burge]
#3126156
03/03/23 12:16 PM
03/03/23 12:16 PM
Posts: 4,575 Motor City
6PKRTSE
Motor City
I run 93 pump gas in all of my old classic cars on the street. I switch to VP NO2 at the track when on the spray in my 70 Challenger street/strip car.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: RapidRobert]
#3126172
03/03/23 01:00 PM
03/03/23 01:00 PM
Posts: 16,928 NC
440Jim
NC
63 dart 360 2bbl 9-1CR circle track. I can use either one. I wouldn't think pinging would be an issue tho I dont have quench. iirc there was something about race gas burning slower??? which should I use? thank you for your time. RR I would run pump premium (92-93 octane). To add to the other comments.... I have heard from a dyno operator, and others; that since pump gas can have 10% ethanol, if you jet for it, you might be able to make a little more power. When I dyno tested a 10.3 CR big block Mopar with roller cam and 5800 rpm peak HP (stock heads, 496 CID), it made the same (+/-2) on pump premium and 112 race race.
[Re: RapidRobert]
#3126192
03/03/23 02:24 PM
03/03/23 02:24 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Use pump low grade with 10% ethanol content and jet for it. That engine with a 2bbl will be starving for oxygen and ethanol carries in liquid oxygen. There is no need for anything above 89 octane with that low of compression and low cylinder filling. Take the same engine and put a good induction and exhaust on it that is tuned to fill the cylinders with resonance tuning and really good flow or even over fill them then you "might" have an excuse to run higher octane with the lower compression.
[Re: HotRodDave]
#3126202
03/03/23 02:53 PM
03/03/23 02:53 PM
Tig
A shed in England
Use pump low grade with 10% ethanol content and jet for it. That engine with a 2bbl will be starving for oxygen and ethanol carries in liquid oxygen. Just for info, this was also touched upon in the EngineMasters episode I mentioned previously, the oxygen effects of E10 are negligable. Though not tested at that time, the 10% of the 10% (1% by volume ??) makes no difference according to the previous experience of Mr Brule.
[Re: Tig]
#3126203
03/03/23 03:02 PM
03/03/23 03:02 PM
HotRodDave
Kalispell Mt.
Use pump low grade with 10% ethanol content and jet for it. That engine with a 2bbl will be starving for oxygen and ethanol carries in liquid oxygen. Just for info, this was also touched upon in the EngineMasters episode I mentioned previously, the oxygen effects of E10 are negligable. Though not tested at that time, the 10% of the 10% (1% by volume ??) makes no difference according to the previous experience of Mr Brule. Got a link? I can't find it. I imagine it making a lot bigger difference on some engines than on others, an oxygen deprived engine I would expect more difference especially with some additional cooling from the alcohol evaporation helping more air molecules get in by making the air denser. I know it would not be as big a deal as say E-85 but when races are sometimes won and lost by a handful of HP and the real kicker is that the money for fuel could then be used elsewhere I would say it is defiantly worth while.
