Re: E body 2 speed to 3 speed wiper conversion, what do I need?
[Re: roadrunninMark]
#3124611
02/25/23 08:32 PM
02/25/23 08:32 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
What year car do you have 70-71 is different than 72-74
NS1AAR
[Re: ns1aar]
#3124623
02/25/23 09:23 PM
02/25/23 09:23 PM
Posts: 2,937 GA
roadrunninMark
GA
#3124754
02/26/23 11:58 AM
02/26/23 11:58 AM
Posts: 143 Canada
EW1BH27
Canada
I had a hard time finding the 2822293 link( from crank to left pivot) when converting mine over, eventually found one. There's a guy in Canada selling a "kit" to modify a 2 speed link if you don't have any luck.
https://www.ebay.com/itm/204243821262?hash=item2f8de162ce:g:IasAAOSwGwlaDIGn&amdata=enc%3AAQAHAAAAoEft%2Bg5yfWMWAmkO%2Fhzfr7F9ig8RwGeraXDEogPQ%2Fh1HMhnKf0JtckIGZFJF967ikV7YcnRwD3qGFchrMdIeWbYDEOLIvleJ7CMqvVD8CJrw%2FbXg%2BMzFEJA4lxRPdMGjnN3b8oG3H%2BA1ydS4YA78oUsitPH%2BMRYKLmJDOjGcF8RROb55tBGo5ecC%2BGis%2BGg1D7XCKWlJgT0RwXmgWYlltxg%3D%7Ctkp%3ABk9SR6rNmefRYQ
[Re: EW1BH27]
#3124758
02/26/23 12:03 PM
02/26/23 12:03 PM
Posts: 2,937 GA
roadrunninMark
GA
[Re: moparx]
#3124768
02/26/23 12:53 PM
02/26/23 12:53 PM
Posts: 1,705 central il.
second 70
central il.
You need switch #2770380 it's variable speed not 3-speed like the 72-74. They will not interchange. Shop around they're expensive. https://www.ebay.com/itm/255971284566?The 3 speed wiper and variable motors are the same. The wiring in the harness is the difference. If number matching isn't a a problem you can use the latter cheaper replacements. You just have to clock them to your car.
[Re: second 70]
#3124798
02/26/23 02:35 PM
02/26/23 02:35 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
The switch can be expensive when sold as an E body one but A body uses the same switch soooooooooooo.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#3124802
02/26/23 02:53 PM
02/26/23 02:53 PM
Posts: 6,240 nowhere
Sniper
nowhere
The switch can be expensive when sold as an E body one but A body uses the same switch soooooooooooo. Yes, looks like the one in my 65 Cuda
[Re: Sniper]
#3124838
02/26/23 05:34 PM
02/26/23 05:34 PM
ns1aar
ontario calif
The E-body uses a 25 OHM switch Red dot on switch
NS1AAR
#3124893
02/26/23 08:56 PM
02/26/23 08:56 PM
moparmarks
70-71 FPM shows 2770380 V-switch for B,J,V and L. I've swapped them between A and E bodies many times. Just use the E body knob.
[Re: fastmark]
#3124949
02/27/23 01:28 AM
02/27/23 01:28 AM
Posts: 1,754 Phila
PhillyRag
Phila
You need the 70-71 switch to fit your wiring harness not the 72-74 switch. The wiper motor can be sourced from any year of car if you’re not wanting correct numbers. The 077 motor is more pricy. You have to get an ebody crank to fit the correct year model of motor. The arm is different as well. I just sold a complete restored setup to a customer for his 70 Cuda. I used two guys on the board here for work and parts that I did not have. I think the total bill was a little over $1000. It was a 73 motor and crank with a converted variable switch. It was a c body switch converted over to fit an ebody. Finding a 380 switch is more expensive and you can’t read the part number once installed anyway. NS1AAR and Devinism can help you out. Not 100% correct. The wiring is the same for any 3 speed harness. It's the plastic spade ends that can be changed to use either switch. The later year just used a single plastic holder.
[Re: PhillyRag]
#3125012
02/27/23 12:49 PM
02/27/23 12:49 PM
second 70
central il.
You need the 70-71 switch to fit your wiring harness not the 72-74 switch. The wiper motor can be sourced from any year of car if you’re not wanting correct numbers. The 077 motor is more pricy. You have to get an ebody crank to fit the correct year model of motor. The arm is different as well. I just sold a complete restored setup to a customer for his 70 Cuda. I used two guys on the board here for work and parts that I did not have. I think the total bill was a little over $1000. It was a 73 motor and crank with a converted variable switch. It was a c body switch converted over to fit an ebody. Finding a 380 switch is more expensive and you can’t read the part number once installed anyway. NS1AAR and Devinism can help you out. Not 100% correct. The wiring is the same for any 3 speed harness. It's the plastic spade ends that can be changed to use either switch. The later year just used a single plastic holder. a 72-74 switch has simalar terminals as a 70-71 switch and will plug right in. There are two connectors that go on the switch on the 70-71. If you only connect the bigger plug you will get 1 speed and park out of the 72-74 switch but if you try to connect the other 2 wire plug it will smoke the wiring. The switch in my hand is a 70-71 correct 380 switch the other is a factory E-body 72-74 3-speed.
[Re: second 70]
#3125136
02/27/23 10:14 PM
02/27/23 10:14 PM
Posts: 1,754 Phila
PhillyRag
Phila
You need the 70-71 switch to fit your wiring harness not the 72-74 switch. The wiper motor can be sourced from any year of car if you’re not wanting correct numbers. The 077 motor is more pricy. You have to get an ebody crank to fit the correct year model of motor. The arm is different as well. I just sold a complete restored setup to a customer for his 70 Cuda. I used two guys on the board here for work and parts that I did not have. I think the total bill was a little over $1000. It was a 73 motor and crank with a converted variable switch. It was a c body switch converted over to fit an ebody. Finding a 380 switch is more expensive and you can’t read the part number once installed anyway. NS1AAR and Devinism can help you out. Not 100% correct. The wiring is the same for any 3 speed harness. It's the plastic spade ends that can be changed to use either switch. The later year just used a single plastic holder. a 72-74 switch has simalar terminals as a 70-71 switch and will plug right in. There are two connectors that go on the switch on the 70-71. If you only connect the bigger plug you will get 1 speed and park out of the 72-74 switch but if you try to connect the other 2 wire plug it will smoke the wiring. The switch in my hand is a 70-71 correct 380 switch the other is a factory E-body 72-74 3-speed. The motors operate the same for either years. Thus the wiring is the same. You just have to rearrange the wiring onto the plastic connectors to make it happen.
