Page 3 of 5 1 2 3 4 5
Re: Distributor phasing is a good idea [Re: CJK440] #312415
05/11/09 01:47 PM
05/11/09 01:47 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Alignment can be also be done on the bench using an old cap with holes drilled in it. Line up the reluctor with the pickup and look thru the spark plug wire hole to see if the alignment is correct
Or align rotor with spark plug hole, remove cap and check reluctor to pick up alignment
The vac adv plays an important part in where the "zero" position of the pickup ends up. Many times shimming the vac adv away from the housing quickly corrects any offset. You can also shorten the length of the arm on the vac adv as well if you are creative enough. Typically you will need to space the canister away from the dist body or shorten the arm length to correct any misalignments.
Again I will emphasize how much better any car runs with a phased distributor.
The pic shows the typical misalignment
let me ask- this picture shows a misalignment at idle. but, when the distributor starts advancing, the pickup will move counterclockwise and brign the misalignment back into alignment, won't it? so the net effect would be proper rotor phasing at higher rpm where its more important.
Once the rotor/terminal & reluctor tooth/pickup is phased it is not affected by mechanical or initial changes. The relationship between the relutctor and rotor is fixed and the position of the pickup to the terminal is fixed also. Only when the vacuum advance comes in will it go out of whack because the pickup now moved in relation to the cap terminal.
If your not running vac advance just shoot for dead on but with vacuum advance perhaps you want to adjust it so that the rotor is equidistant from the terminal a zero vacuum to max advance????
i dont believe thats true. i believe mechanical advance as well as the initial timing will change the orientation pickup /cap terminal to the rotor/reluctor spline
the relationship of the rotor tip and star wheel is fixed to the distrib shaft and is driven by the cam (but the relationship can be adjusted as stated above).
The cap terminal is fixed to the body of the distrib housing and will be moved back and forth as the housing is twisted CW or CCW.
When the housing is twisted CW or CCW, the pickup moved forward or aft of the reluctor. thats how mech timing is adjusted. Move housing so the pickup moved toward the reluctor spline and the coil fires off earlier thereby advancing it. move it away, the timing is retarded.
When the coil fires it sends the pulse down to the rotor to arc out to a plug terminal. it WILL JUMP A GAP here. the question is how much.
as the centrifigal advance kicks in, the rotor and the reluctor move so that the reluctor spline moves towards the pickup thereby advancing it
Now, i would imagine the width of the conductor on the tip of the rotor is such that one corner of it aligns with the front edge of the 1/4 wide contact on the cap and as the engine advances, the rotor contact swings through the terminal contact.
point is, the mech and the vac advance changes the relationship of the reluctor spline to the pickup. since the reluctor spline is tied to the rotor it will move in relation to the housing annd the cap terminal is tied to the housing.
Unless the setup was so far out of whack that the rotor tip was so far infront of the cap terminal or already behind it such that the spark couldnt jump (or would jump to the next terminal), you'd never see a problem.
Im going to play with my distributor and see what the alignment is like at my intial timing (18 deg) and compare it to a stock (4 degrees adv) and see the alignment
Re: Distributor phasing is a good idea [Re: aarcuda] #312416
05/11/09 02:10 PM
05/11/09 02:10 PM
Can anyone provide a definitive "reality check" to this post? I've owned a number of Mopars, using several different distributors over the years and have been envolved with many many friends "back in the day" as well as having tuned up hundreds on the scope when I worked at Miramar.
You are using terms like "most need alignment"
I don't remember seeing all that many with badly burned caps--the one physical indication of misalignment
Second, there IS CONSIDERABLE leeway in the cap. As the rotor rotates, the corner of the leading edge of the rotor comes "to" the corner of one edge of the cap contact. They then move past each other, to the opposite "corner" of each contact. That must be a dimension close to or better than 3/8"!!!!
You say "your car runs better." Have you proof of this? You showed a picture of what I would call a MASSIVE reluctor misalignment, and imply that you've checked that against a cap, and that is a "typical" situation. Frankly, I find that a little hard to believe.
Last, why are we just hearing about this now? For years and years, various people have been making high performance igniton, people like Mallory, Accell, Vertex, and a few I've forgotten
AND NOT ONCE in any advertisements for these products have there been blazing headlines about how necessary it is to "cure" the awful rotor phasing in Mopar distributors.
Re: Distributor phasing is a good idea #312417
05/11/09 02:22 PM
05/11/09 02:22 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
My statistical data:
Out of probably 6-7 cars that I converted to electronic ignition via the MP kit (and for street use only, if that matters), most of which had MSD ignition boxes (either the 5 or 6), and over a 15-year period...
Only 1 displayed any issues that were corrected via rotor phasing.
Would the others have run better if I experimented with phasing? I don't know...
I'd file this issue under the 'things to keep in mind' category.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Distributor phasing is a good idea [Re: aarcuda] #312418
05/11/09 02:32 PM
05/11/09 02:32 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Ignoring vac advance for a second.
The reluctor passing by the pickup is what triggers the coil to fire. When it does fire you want the rotor lined up with the cap terminal.
Since intial advance (rotating the distributor in the block) shifts the cap and pickup together as one, and centrifugal advance moves the rotor and the reluctor together as one the timing of when these events occur in relation to the crank may change but the rotor will always be in the same position in relation to the cap when the reluctor tooth lines up with the pickup.
The only thing that will change this is when the vacuum advance pulls the pickup around in relation to the cap terminal.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Distributor phasing is a good idea [Re: CJK440] #312419
05/11/09 02:41 PM
05/11/09 02:41 PM
To simplifiy ( I hope) this further, the rotor and reluctor/ points cam ARE ON THE SAME SHAFT so the mechanical advance has nothing to do with a change in phasing. Neither does changing initial timing.
the only thing that can affect phasing CHANGE is the vacuum advance or problems with the advance plate--loose, misaligned, etc.
Re: Distributor phasing is a good idea #312420
05/11/09 03:20 PM
05/11/09 03:20 PM
AndyF Online content
AndyF  Online Content
I started to make the custom reluctors to fix a problem that I had with the stroker motor in my car.
What happened with that motor was that when the vacuum advance was activated the rotor phasing would get far enough out of whack that the spark would start jumping to the wrong post and I'd get a severe misfire.
I chased my tail for a long time until I figured out how to test for this condition. Basically I just set the motor at a fast idle and then used a Mityvac to pull a vacuum on the advance canister. As soon as I reached a decent amount of vacuum advance the motor would start to misfire.
To fix it I remachined the reluctor so that the initial rotor phasing was to one side of the post and full vacuum adavance put me on the other side of the post. Basically I just split the difference. That solved the issue and the misfire condition went away.
I then started to sell the remachined reluctors but eventually the supply for them dried up and I got tired of how much work it took to make them. I also got tired of how little people were willing to pay for them and all the experts who told me that they weren't needed so I just stopped selling them.
I still think the re-machined reluctor is an easy solution to a specific problem. I'm not sure why some distributors have the issue and others don't but I do know I've run into the problem before and that it was severe enough to cause significant misfiring.
Re: Distributor phasing is a good idea [Re: AndyF] #312421
05/11/09 03:30 PM
05/11/09 03:30 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Most important part is to get the rotor centerd in the termanal when it fires across the gap. It changes. My method is always simple, run it for a while with a new cap, there will always be some burning on the terminals and rotor, look if most burning is centered in the center of the tip of both rotor and cap terminal, this will be where YOUR engine spends most of its time and will be most important to YOU, then adjust acordingly (whatever method you prefer)to get the burn spot in the center.
Re: Distributor phasing is a good idea [Re: HotRodDave] #312422
05/11/09 04:45 PM
05/11/09 04:45 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
On one of my caps inside the terminal was burned evenly across, what might that indicate.
Re: Distributor phasing is a good idea #312423
05/11/09 05:35 PM
05/11/09 05:35 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
the mechnical advance rotates the slotted plate (wrt to the pickup) which IS the rotor/reluctor mount.
So as the mechanical advance kicks in, it moves the rotor and reluctor wrt to the pickup, so the rotors alignment wrt the cap contact changes cause the cap contact didnt move. it has to
Re: Distributor phasing is a good idea [Re: 68Fastback] #312424
05/11/09 07:46 PM
05/11/09 07:46 PM
Az
Crizila Offline
Crizila  Offline
Az
Your running on 1 cylinder!
Fastest 300
Re: Distributor phasing is a good idea [Re: aarcuda] #312425
05/11/09 07:51 PM
05/11/09 07:51 PM
NO!!!!!
You are not thinking correctly. As the mechanical advance rotates BOTH the reluctor AND the rotor change TOGETHER. Their mutual relationship DOES NOT CHANGE.
There are two relationships here.
ONE THe relationship between the points/ reluctor and the CAP
TWO The fixed relationship between the rotor and reluctor.
If the reluctor is off in relation to the rotor, you have a phasing problem.
BUT ONCE YOU FIX/ verify that, then the postion of the mechanical advance means not. THEY ROTATE TOGETHER
The vacuum plate DOES move the pickup/ points, which changes position IN RELATION TO THE CAP
You can NEVER have absolute dead center phasing with a vacuum advance, because THIS MUST HAPPEN. so now you have two choices:
ONE Optimise the vacuum advance position and live with what should be minor phasing change, or
TWO Align the phasing perfectly and weld the advance plate and do without vacuum advance.
I've seen hundreds and HUNDREDS of caps and rotors in my lifetime, and I'm getting to be on in years. In my opinion, this is an overblown "problem"
Re: Distributor phasing is a good idea #312426
05/13/09 07:28 AM
05/13/09 07:28 AM
Answering the call of the wild
ThermoQuad Offline OP
Wow the cauldron of discontent...
I am amazed that a simple check for a problem and a fix that really works gets so much discourse.
Phasing works and the car runs better. Another perfect example of why some cars are faster & run better than others.
I have checked a number of used caps-the good ones-not the elcheepos-and there is no geometric tolerancing problem with the index slot and the positioning of the terminals. Are there any other forensic questions??
Here is a pic of the test cap terminals,that came off an un-phased distributor. Please look at the pic post #1 and look at the difference. Higher resistance in an electrical path reduces the efficiency of the circuit. E=IR
Re: Distributor phasing is a good idea [Re: ThermoQuad] #312427
05/13/09 08:45 AM
05/13/09 08:45 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
no discourse from me. im trying to figure out the best way to do it. Im thinking that the width of the terminal in the cap and the width of the contact on the rotor are such that when everything is properly phased, the rotor contact will sweep the width of the cap terminal throughout the advance.
i dont run vacuum advance. only mechanical. If my theory of sweep is correct and my belief that the mech advance changes the position of the rotor wrt to the cap terminal, then I can mess with mine.
im just trying to visualize everything in my head right now and its not working too well for me. once I get a distributor in my hands, im sure I'll figure out what i need. right now, im researching
Re: Distributor phasing is a good idea [Re: aarcuda] #312428
05/13/09 08:55 AM
05/13/09 08:55 AM
Cincinnati area
sch1966 Offline
sch1966  Offline
Cincinnati area
Did I miss something? I want to fix my phasing what is the best way to do this? Can I buy parts to do this? or modify what I have somehow? I do not feel like reading back through all the arguments to see if the info is in here somewhere!
Re: Distributor phasing is a good idea [Re: sch1966] #312429
05/13/09 12:10 PM
05/13/09 12:10 PM
I dont run vacuum advance. only mechanical.
ditto!
I think vacuum advance in a steet driven hot rod or strip operated car is meaningless anyway unless you frequently drive long distances.
I've gotten 14mpg out of a warmed over 440 doing 70mph with 3.23 gears and mechanical advance only. Better than I ever thought I'd get!
I can't tell you how many Mopar electronic distributors I've gone through for friends because they just can't get their car to run properly! It's not like it's a black art, they just treat it like it is!
Stuck weights, broken springs, and nasty corroded internals are all par for the course.
Re: Distributor phasing is a good idea [Re: ThermoQuad] #312430
05/13/09 12:25 PM
05/13/09 12:25 PM
You keep making wild statements like "the car runs better" but you haven't been able to back this up with any factual evidence.
You show us this one cap, here, and proclaim that it is an example of the badness at hand, but....evidently you have run no electrical analysis on this specific cap/ dist setup. You should be able to actually MEASURE the loss of power and possibly see it on an ignition scope.
I=E/R indeed. The secondary circuit is by nature a VERY high impedance circuit BY DESIGN. Let's add up the losses:
Several ohms in the two terminal connections at the coil/ cap tower, net loss= nearly zero
More than several ohms in the coil resistance wire (if used) and more yet in the resistor plug wires (if used)
A few more ohms lost in the terminal connections at the plug wire ends
MANY ohms lost --by design--at the rotor contact and gap. BEAR IN MIND that in the case of GM a "short" rotor was used on some cars BY DESIGN so in this case we are talking EVEN MORE gap
Now to the plugs. Some plugs have a gap in the insulator, some are resistor, and nearly all have a spring loaded arraingment in the ceramic, a few more ohms lost, and of course finally...
We have the plug gap itself, and whatever the firing conditions are in the chamber
The point? The HT voltage has got to be WAY more powerful than any of these losses, which are in the system by design and by necessity.
Now you post this last picture....how do you know that this cap is a problem? I see no obvious tracking on the cap, it MAY WELL BE POSSIBLE that as I mentioned earlier, the "corners" of the rotor/ contact came into alignment as the spark fired, and it stopped where you see the end of the arc in the middle of the contact. Or, the other way around.
YOU STILL HAVE NOT presented any viable proof that what you are presenting here is actually making any difference in performance, and worse yet, any quantifiable evidence of how good or bad the situation gets with a given misalignment, for example, .020" off from center causes 5hp loss, etc.
I guess the point I'm trying to make is that you simply haven't proved your arguement. There may well be bigger fish to fry. Spark scatter, for instance, has always been a problem with factory Mopar ignition, due partly to the design of the dist. drive and the dist. itself, and of course slop in the cam drive. It may well be, for example, that while you are fine tuning the dist for phasing, you may well have bad enough scatter that your efforts are for naught.
Re: Distributor phasing is a good idea #312431
05/19/09 02:30 AM
05/19/09 02:30 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
I double checked my setup and on two of the cylinders the reluctor gap is tighter than the other six. Is this ok.
Re: Distributor phasing is a good idea #312432
05/19/09 05:42 AM
05/19/09 05:42 AM
I will tell you what I have proved here: I should keep my knowledge to myself and just laugh when my cars run away from the rest of you. The lack of common sense and courtesy amazes me. My humblest apologies for trying to help others have better running/driving cars. The spark is definitely scattered...
Re: Distributor phasing is a good idea [Re: 68Fastback] #312433
05/19/09 06:45 AM
05/19/09 06:45 AM
You can trim the 2 teeth(gap & angle of the gap) & you would want the (min) gap at the closest teeth but 1st w a vacuum pump pull the vac can thru its range of travel & check clearances of each & every tooth. Alot of work but this kind of detail(in every system of the car) will let you outrun the next guy. EDIT you might contact Nacho as he has done extensive work with this issue.
Re: Distributor phasing is a good idea [Re: 68Fastback] #312434
05/19/09 07:53 AM
05/19/09 07:53 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
that might be because the shaft is moving
