Brake Fluid
#3124097
02/23/23 08:01 PM
02/23/23 08:01 PM
Posts: 7,861 Witness Protection Program
Kudakidd
The '70 Cuda I bought needs to have the m/c topped off. I don't have clue of what's in there now. What SHOULD be in there? Dot 3 or Dot 4? Is there anyway of determining what is in the m/c right now? I know Dot 5 is purple, so that's out. Thanks in advance, Moparters
Re: Brake Fluid
[Re: Cab_Burge]
#3124133
02/23/23 10:33 PM
02/23/23 10:33 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I would stick with DOT 3 Yep, I looked into it pretty deeply several years ago. What finally clinched it for me after running down all the rabbit holes is DOT 3 is still factory fill on new cars. Were I in your shoes buy enough DOT 3, or 4 or 5, pick one, and flush the system out, no telling how long it's been in there. Even 45 years ago when I was still a mechanic I'd come across some pretty muddy stuff. 2¢
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
Re: Brake Fluid
[Re: TJP]
#3124156
02/24/23 01:53 AM
02/24/23 01:53 AM
Posts: 11,691 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
DOT 3 will be adequate for most.
DOT 4 steps up the boiling point.
Re: Brake Fluid
[Re: SportF]
#3124876
02/26/23 07:56 PM
02/26/23 07:56 PM
Posts: 28,611 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Those cars look great. Why not do it right and flush the whole thing out and put DOT 5 in there. Have some friends over and have a winter party bleeding brakes. Gosh knows, at least up here in Minnesota we could all use a" car doing something" fix this time of the year. Mity-Vac is your friend.
Re: Brake Fluid
[Re: Sniper]
#3124950
02/27/23 01:30 AM
02/27/23 01:30 AM
Posts: 1,757 Phila
PhillyRag
Phila
MIty vac is horrible.
Motive power bleeder is much better. Agree: the ALL PLASTIC ones are really bad. Look for the earlier of metal/brass.
Re: Brake Fluid
[Re: PhillyRag]
#3124955
02/27/23 02:45 AM
02/27/23 02:45 AM
340SIX
Motive power bleeder is much better. Agree: the ALL PLASTIC ones are really bad. Look for the earlier of metal/brass. Mine is metal, only way i thought thet came. Thought the knock offs were plastic. Guess it is a case of don't make them like they used to.
Re: Brake Fluid
[Re: PhillyRag]
#3124965
02/27/23 07:56 AM
02/27/23 07:56 AM
Posts: 6,318 nowhere
Sniper
nowhere
Motive power bleeder is much better. Agree: the ALL PLASTIC ones are really bad. Look for the earlier of metal/brass. I have one of the brass ones, it still sux for brake bleeding compared to a pressure bleeder.
Re: Brake Fluid
[Re: Sniper]
#3125138
02/27/23 10:15 PM
02/27/23 10:15 PM
Posts: 1,757 Phila
PhillyRag
Phila
Motive power bleeder is much better. Agree: the ALL PLASTIC ones are really bad. Look for the earlier of metal/brass. I have one of the brass ones, it still sux for brake bleeding compared to a pressure bleeder. Why of course; 2 entirely different bleeding methods.
Re: Brake Fluid
[Re: robertop]
#3126075
03/02/23 11:32 PM
03/02/23 11:32 PM
Posts: 4,758 Moved to N.E. Tennessee
GomangoCuda
How do you connect the Motive can to the master cylinder in a 69 roadrunner?[ You buy the rectangular adapter Motive sells or the kit that includes the adapter. Motive Kit
Re: Brake Fluid
[Re: robertop]
#3126111
03/03/23 08:49 AM
03/03/23 08:49 AM
Sniper
nowhere
How do you connect the Motive can to the master cylinder in a 69 roadrunner?[ You go to the Motive website and use the application guide. It will tell you which adapter you need. My 51 Plymouth uses a different setup than your 69.
