Page 2 of 3 1 2 3
Re: 4.10 Rear Gears [Re: Kudakidd] #3121957
02/16/23 09:29 AM
02/16/23 09:29 AM
Norwich CT USA
moparts Online boogie
moparts  Online Boogie
Norwich CT USA
Originally Posted by Kudakidd
What were they thinking? 55mph spinning at 3,500 rpms. lol
You need some taller back tires whistling
Years ago I drove my 71 Challenger to Carlisle with 4:30 gears
At the time it had the Blower on it , stopped every 100 miles to fill it up
was with a group of friends and they thought they would blast past me coming down RT 81 , they figured I couldn't or wouldn't keep up
grin The looks on their faces when I did pass them at about 100 mph with the blower screaming and the engine wound up
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: 4.10 Rear Gears [Re: moparts] #3122079
02/16/23 02:38 PM
02/16/23 02:38 PM
VA
SR-71 Offline
SR-71  Offline
VA
Ditto on the taller tires. Back in the days, my 70 Challenger was running a 4.10 dana w/auto. Was my daily drive for two years, travelling every weekend from MD to VA on I-95; wasn't too bad. Had L70s x 15 tires in rear (yes, L70s for those old enough to remember; Hijackers were maxed out at 150 psi to prevent occasional fender rubs). The other 70 had a 4.56 dana (4-sp w/L60s x 15) which was almost unbearable to drive, again on I-95. Had to leave around 1:00am to prevent any traffic tie-ups and truckers from running me over in the slow lane. Drove the minimum 45 mph speed limit the majority of the time, on occasion up to 55. Took about ~4-5 vice ~2.5 hrs for the other Challenger. As someone previously mentioned, stop-light-to-stop light was the fun part with the 4.56's.
Re: 4.10 Rear Gears [Re: SR-71] #3122091
02/16/23 03:39 PM
02/16/23 03:39 PM
moparx Offline
moparx  Offline
i ran 5.38 gears in my charger for a while.
they were fun, but that eventually wore off and i swapped to 3.91's.
the car was as fast with those, and had more mph at the stripe to boot. imagine that. laugh2
beer
Re: 4.10 Rear Gears [Re: moparx] #3122207
02/16/23 11:48 PM
02/16/23 11:48 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I run 4.56 gears on a 29” tire. Needless to say, I don’t leave town. laugh2
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 4.10 Rear Gears [Re: Blusmbl] #3122331
02/17/23 01:37 PM
02/17/23 01:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by Blusmbl
Originally Posted by DaveRS23
Do the math on the Gear Vendors OD before you pull the trigger. It is not enough OD ratio for some guys. The 518s have an OD ration of .69:1. The GV has .78:1.
Agreed, I've seen a few people complain that it isn't a ton of overdrive. It isn't like a 0.5 OD like on a T56.
It would be cool to build a lockup style 727 with a GV or a 518, but I don't know how much power they can take. It seems that past 1000-ish it is not common to stick with a Mopar based trans.
If you use the right parts a 727 based trans will be fine at 1000HP, look at the Cummins powered rams making more HP than that , and the torque is even more than a gas engine . If you build the OD unit to Diesel specs you should be fine, the issue you may have is getting a lockup performance convertor for a gas engine in the stall you want? But they are making them for turbo 400 racers so there must be something available ?
Re: 4.10 Rear Gears [Re: JohnRR] #3122334
02/17/23 01:53 PM
02/17/23 01:53 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Its not 1980 any more.... set your rods and mains at .003, deep pan and good oil, optimized cooling system and hammer down. The most friendly gear I drive is a 4:30 the better is 4:56 and its happy in the 5-8k area. Nothing better then running 65mph and someone thinks your spent till you pull it down one and then they know the real truth.
I think back in the day the mostly stock bottom enders would of benefited from a bit more bearing clearance and better rod bolts.
Some have got complacent just cruising and cant/wont even run off a stop light which for some isnt a bad thing considering stock or just above stock cant muster a win over some modern V6s.
In the 80-90-s old iron still ruled over anything new.... no longer true.
STOP POTATO HATE!
Re: 4.10 Rear Gears [Re: Mr PotatoHead] #3122342
02/17/23 02:10 PM
02/17/23 02:10 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
My black one has 3.54s and is fine on the hiway even at 75 mph , but it is up there for RPMs . Its a hemi auto
My yellow has 3.91s and is a LOT more fun around town . but is screaming at me at anything over 65-70 mph its a 383 auto
Both have a 27inch tall tire
Re: 4.10 Rear Gears [Re: gtx6970] #3122528
02/18/23 01:35 PM
02/18/23 01:35 PM
HellsGate
outcast Offline
outcast  Offline
HellsGate
I have run 4.10 for yrs (30) in a 416 sm blk been 20 miles to 2000 miles & just under 2700 RPM but i run a 32 tall tire, keeps it at the 2700 RPM . Just like to get out on the interstate or old country roads people don.t expect to see our old cars there. To me it,s all about the smiles per mile
Re: 4.10 Rear Gears [Re: outcast] #3122737
02/19/23 08:54 AM
02/19/23 08:54 AM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
I was talking w/ a mechanic,and was told it's a real PITA to put a new ring and pinion in a Dana. Looks like I'm sticking w/ the 4.10s
Re: 4.10 Rear Gears [Re: Kudakidd] #3122740
02/19/23 09:25 AM
02/19/23 09:25 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I would guess he didn't have the tools needed. Ive done it on stands but a lift would make life easy.
1969 Hemi Roadrunner 2nd owner
Re: 4.10 Rear Gears [Re: 69hemibeep] #3122745
02/19/23 10:00 AM
02/19/23 10:00 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Same here. It's not too bad with the correct tools. I have the T&D installation tool kit. It includes all the extensions and pieces for all the popular rear ends. I put 4:10's in my Dana in my Challenger.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 4.10 Rear Gears [Re: Kudakidd] #3122748
02/19/23 10:14 AM
02/19/23 10:14 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Find a new mechanic.
Re: 4.10 Rear Gears [Re: Sniper] #3122775
02/19/23 11:55 AM
02/19/23 11:55 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree
Most vehicles have integral rear gears. If the 'mechanic' said the Dana 60 is hard to set-up then he must not be much of a differential guy.
Master, again and still
Re: 4.10 Rear Gears [Re: DaveRS23] #3122793
02/19/23 12:45 PM
02/19/23 12:45 PM
moparx Offline
moparx  Offline
look for a "rear end" guy.................[i couldn't resist. laugh2]
beer
Re: 4.10 Rear Gears [Re: moparx] #3122803
02/19/23 01:00 PM
02/19/23 01:00 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Re: 4.10 Rear Gears [Re: Sniper] #3122918
02/19/23 08:25 PM
02/19/23 08:25 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Just for the record your honor, I said A mechanic, not MY mechanic! lol
Re: 4.10 Rear Gears [Re: DaveRS23] #3122921
02/19/23 08:32 PM
02/19/23 08:32 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I have always liked 3.91s and have them in the Cuda. But many of my buddies have late model cars and want to hop on the interstate and run with traffic to a destination. So I converted a 518. WOW! What a difference. 75mph on the hiway and the engine sounds very relaxed. Didn't help the gas mileage much, but wasn't expecting it to.
No way would I ever go back to only 3 gears. The only down side is probably the weight. Man, that thing's heavy.
Yep this is the way to go really. Convert the trans. As much as I love the bullet proof 727, if you really wanna have the best of both worlds....
Facts are stubborn things.
Re: 4.10 Rear Gears [Re: larrymopar360] #3122954
02/19/23 10:26 PM
02/19/23 10:26 PM
BDW Online content
BDW  Online Content
Swapped in a 518 and could never EVER go back to a 727.
3:73 gears, only 2500 RPM at 80
Re: 4.10 Rear Gears [Re: 69hemibeep] #3124481
02/25/23 12:17 PM
02/25/23 12:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Agreed , the guy either has never done one or just doesn't want to make money unless it's a job he can charge book time for that he can do for less. I bought a case spreader just so I can do them myself .
Mark swap a ford 9" in and I bet the guys answer will change ...
Re: 4.10 Rear Gears [Re: Kudakidd] #3124584
02/25/23 06:16 PM
02/25/23 06:16 PM
So is a ten bolt and twelve bolt GM rear end, any non drop out rear end has to have the gears set up in the rear end housing, I bought the tools, bearing puller and pinion depth tools to do my own. I take the housing out of the car and set the new gears up in the shop so I can keep it clean, warm or cool and take my time doing it correctly. I did make some set up bearings also, which helps a bunch on setting the rear ends up up wrench
Page 2 of 3 1 2 3
