07 Hemi and trans in a 87 pickup #3121860
02/15/23 08:32 PM
02/15/23 08:32 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Probably been talked about before but is possible? I have wiring harness but no PCM. I know the obvious like mechanical stuff but electrical gets me.
Re: 07 Hemi and trans in a 87 pickup [Re: cudaman1969] #3122023
02/16/23 01:12 PM
02/16/23 01:12 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
Holley makes swap kits for that, I'd check them out
Re: 07 Hemi and trans in a 87 pickup [Re: cudaman1969] #3122053
02/16/23 02:08 PM
02/16/23 02:08 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I found my notes from when I did mine. I picked up an '05 computer and confirmed it had NO anti-theft system w/ Joe @ 918/456-2541, I have NO recollection of who Joe was/is or who he worked for. The computer I picked up had "in system vehicle locate tracking", again, I've forgotten what significance that was or even was significant.
The computer had to be flashed for my truck, axle ratio, tire size, etc.
Street and Performance deleted the downstream O2 sensors when they did mine, that caused me some grief later on.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 07 Hemi and trans in a 87 pickup [Re: Dart 500] #3122063
02/16/23 02:18 PM
02/16/23 02:18 PM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
Some of the kits I believe are on back-order until mid March.
Re: 07 Hemi and trans in a 87 pickup [Re: 3hundred] #3122067
02/16/23 02:20 PM
02/16/23 02:20 PM
Middle of A Field
O
O
Middle of A Field
What type of grief are talking about with regards to deleting the Downstream O2 Sensors from the programming?
Re: 07 Hemi and trans in a 87 pickup [Re: OrangeProwler] #3122081
02/16/23 02:43 PM
02/16/23 02:43 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Seems like it was something to do with Texas emission testing, can't imagine what else it could have been. There were times I got by with the dyno test for OBD1 vehicles, and other times they checked for codes due to the newer engine. If I remember, there were codes set for no downstream sensors. By the time the truck turned 25 years old and exempt from emission control testing, the gas tank started deteriorating to the point I couldn't put 10 gallons in without immediately leaking, so I drove it VERY little until I lost all interest and sold it.
'69 300 Convertible
'16 300 S Hemi
Re: 07 Hemi and trans in a 87 pickup [Re: 3hundred] #3122326
02/17/23 01:22 PM
02/17/23 01:22 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Looks like that might be Joe Perry at Tommy Nix Auto Group, this is a Chevrolet dealer but they also have a Chrysler dealership. They are in Tahlequah, OK
JOE PERRY
Assistant Parts Manager
AUTOMOTIVE EXPERIENCE: 29 years CERTIFICATION STATUS: GM & Chrysler Certified
Re: 07 Hemi and trans in a 87 pickup [Re: Dart 500] #3122374
02/17/23 04:41 PM
02/17/23 04:41 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Re: 07 Hemi and trans in a 87 pickup [Re: migsBIG] #3122391
02/17/23 05:17 PM
02/17/23 05:17 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Originally Posted by migsBIG
[quote=Dart 500]Holley makes swap kits for that, I'd check them out
Now that's interesting. I never knew the 545RFE and 46RH(E) used the same mount. So if you can score a junkyard crossmember from an overdrive equipped truck and want to use the 545RFE, as I did, you're golden. The shift linkage for the 545RFE requires fabrication, (which S&P DIDN'T do) unless you want drive on the shift quadrant to show up as neutral. Essentially, without a little fabrication the entire shift range shows up as park through drive (that would be first gear) on the quadrant and the effort to shift is high.
The drivers side requires headers, or a Jeep Grand Cherokee drivers side exhaust manifold, most anything fits the passenger side. They cut the top flange of my frame trying to get the truck manifold to fit. rant
I believe my engine was in the stock position, so the 45 degree adapter wasn't ever an issue for me. Since my engine was '07, it could use ANY of the older mopar or Ford filters. 2008 they changed the pipe size to metric.
The rest is pretty much wiring, save for the PS pump. Pressure is too high for the old box. I "think" they used a GM pump and did use a custom remote reservoir, which I hated, because it leaked, not terribly, just enough to be really annoying and have to top off periodically.
Almost forgot, I lost my cruise control, later S&P (read: hotwireauto) told me they figured out how to make it work, but I never pursued it. I was completely fed up with their antics by then.
I hope they've come up with a good way to drive the speedometer, I got sick of the wonky electronic adapter they used and mounted a GPS.
'69 300 Convertible
'16 300 S Hemi
Re: 07 Hemi and trans in a 87 pickup [Re: 3hundred] #3122435
02/17/23 08:28 PM
02/17/23 08:28 PM
south louisiana
lowell66dart Offline
south louisiana
Can't you just get a PCM from a 07 car from your local pull-a-part? Might as well get a gauge cluster too. I have a 2007 Charger that I am playing with. Bought a used, unmarried Diablo and used the canned tune and it worked nice. Deleted MDS. Then I removed the cats and EGR and got an email tune. No codes. By the way. this is my first time tuning anything.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: 07 Hemi and trans in a 87 pickup [Re: lowell66dart] #3122576
02/18/23 04:15 PM
02/18/23 04:15 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
K I S S principle keep it simple and carbureted
Re: 07 Hemi and trans in a 87 pickup [Re: volaredon] #3123070
02/20/23 01:23 PM
02/20/23 01:23 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Not sure carbureted is the simple way with these. Not many intake choices available, and you still have to deal with other unavoidable sensors.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 07 Hemi and trans in a 87 pickup [Re: 3hundred] #3123638
02/22/23 11:43 AM
02/22/23 11:43 AM
Middle of A Field
O
O
Middle of A Field
It took me a few days to reply. Ah, emissions testing that would make sense. I've heard different tricks for the downstream O2 sensors and they use to sell O2 Simulators back years ago but, they don't anymore. The gas tank might have a been a simple but, costly solution.
Re: 07 Hemi and trans in a 87 pickup [Re: A39Coronet] #3124078
02/23/23 06:22 PM
02/23/23 06:22 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I wasn't necessarily saying to run a hemi with a carb.... I'm getting as tired of seeing a new generation hemi in an older chassis as I am all the LS swapping going on.......
Stick with what has worked for eons.
