Shock upgrade recommendations #3071793
08/27/22 11:24 AM
08/27/22 11:24 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Took a long drive Thursday and realized I was not happy with the ride control from OE type shocks.
These are now 10 year old NAPAs that seemed OK then.
This on a 70 RT slightly hopped up with 465 HP, tied frame, torque boxes
But I know there are better shocks out there. I just don't want to spend $600 on a set.
My bars are one size up and rear springs seem to have sufficient arc.
Sooo, If you have any suggestions for a street only application, I'm all ears.
Thanks, Joe
Re: Shock upgrade recommendations [Re: jlatessa] #3071976
08/28/22 02:55 AM
08/28/22 02:55 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks, Joe
What exactly is the size of your Torsion bars?
One size up torsion bars from a stock 383 .90” would be .92” 440/Hemi size.
But to some that might mean the 1.00” common found upgrade bars that PST and other general suspension places sell.
Talked about this in another forum and I think Bilstein RCD shocks are now $550+.
Less than $400/set I think nowadays leaves you with:
KYB
Monroe Matic
Gabriel Classic
All those about $25 +/-
Re: Shock upgrade recommendations [Re: autoxcuda] #3072049
08/28/22 12:13 PM
08/28/22 12:13 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
You should be looking for NOS HD shocks if you don't want to pay for the good shocks. Adjustable shocks are amazing............
There are more than several flavors of oem mopar nos hd shocks that will work for you but i am not doing the homework [research] for you. Rear is easy, front=depends on application
We used to use chevy shevelle [sic] shocks for the 73 up B body front shocks platform - the shocks fit the tight confines and all that needed to be done was change the lower mount interface over to mopar from the chevy = press out the chevy part and press n the mopar part.
Re: Shock upgrade recommendations [Re: ThermoQuad] #3121107
02/13/23 11:31 AM
02/13/23 11:31 AM
Canada
Ghoste Offline
Ghoste  Offline
Canada
Tailgating onto this thread as it's basically the same question but what are shock recommendations fir a primarily street driven four speed car? RT Charger, 69, stock springs and torsion bars.
I see a light at the end of the tunnel, and it's... ELECTROLUMINESCENT!
Re: Shock upgrade recommendations [Re: Ghoste] #3121439
02/14/23 01:39 PM
02/14/23 01:39 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Bilstein Shocks from FirmFeel.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Shock upgrade recommendations [Re: Ghoste] #3121757
02/15/23 02:42 PM
02/15/23 02:42 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree I typed up a long winded message, but if sticking with nonadujstable, Bilstein is hard to beat. But I also thought parts store stock replacements were fine. I guess I’m not a skilled enough driver to appreciate the difference shruggy
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Shock upgrade recommendations [Re: metallicareload] #3121767
02/15/23 03:35 PM
02/15/23 03:35 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
For a street cruiser Bilsteins are overkill. For the OP's budget considerations Bilsteins are a bad recommendation and exactly what the OP asked not to get.
Re: Shock upgrade recommendations [Re: Sniper] #3121775
02/15/23 03:58 PM
02/15/23 03:58 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
With shocks... you pay for what you get.
Re: Shock upgrade recommendations [Re: Mopar Mitch] #3121795
02/15/23 05:07 PM
02/15/23 05:07 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
With Moparts you get the answer no one asked for.
Go back and read what the OP was asking for.
Re: Shock upgrade recommendations [Re: Sniper] #3121811
02/15/23 06:10 PM
02/15/23 06:10 PM
Kirkland, Washington
Pacnorthcuda Offline
If you hate stiff shocks, go with Monroe. If you like stiff shocks, KYB. If you want a quality shock at a better price than Bilsteins, look at Koni.
Re: Shock upgrade recommendations [Re: Ghoste] #3121839
02/15/23 07:50 PM
02/15/23 07:50 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
For a stock suspended, street cruiser that has no race plans, Monroe or Gabriel gas shock are a decent step up over stock oil shocks to provide a noticeably improved ride without being harsh or costing a chunk of money. These are still good for one step up from stock rates, but they must be gas charged. Once you get up to 1.0" t-bars, they won't have enough control to provide the best results and you need to prepare to fork over some money.
With that said, I will point out that the shocks are the heart of a suspension system and they define its control range and performance. Like a camshaft controls the performance range of an engine, so do shocks make a suspension great or lousy if they are not all set up to compliment each other.
Re: Shock upgrade recommendations [Re: jlatessa] #3122454
02/17/23 10:46 PM
02/17/23 10:46 PM
AndyF Offline
AndyF  Offline
Thanks, Joe
My recommendation is to buy a set of Koni shocks for the front. I know they are more expensive than you want to pay but once you drive the car with the Koni front shocks you'll be convinced. And they'll basically last forever on a street driver, especially if you keep the car in a garage.
Re: Shock upgrade recommendations [Re: AndyF] #3122507
02/18/23 11:54 AM
02/18/23 11:54 AM
GA
roadrunninMark Offline
GA
How about the Hotchkis street performance shocks? Not much more than the Konis.
Which model Konis are the ones being mentioned?
Re: Shock upgrade recommendations [Re: roadrunninMark] #3122577
02/18/23 04:17 PM
02/18/23 04:17 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
If you can still find them I have had the best luck over the years with Gabriel shocks.
Re: Shock upgrade recommendations [Re: roadrunninMark] #3122647
02/18/23 08:57 PM
02/18/23 08:57 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
I don't think he'll find more than one model Koni for '70
Facts are stubborn things.
Re: Shock upgrade recommendations [Re: jlatessa] #3125060
02/27/23 04:18 PM
02/27/23 04:18 PM
What do you want the car to do with the shock change, soft ride, better cornering, acceleration or ?
Re: Shock upgrade recommendations [Re: Cab_Burge] #3125127
02/27/23 09:27 PM
02/27/23 09:27 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I've always had the beat ride out of the top of the line Gabriel's.
monroe shocks universally suck.
