Re: 71 barracuda fuel tank, 4 vents on right quesiton
[Re: Kern Dog]
#3121606
02/14/23 09:28 PM
02/14/23 09:28 PM
Posts: 20,700 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
[Re: Neil]
#3121623
02/14/23 10:18 PM
02/14/23 10:18 PM
Posts: 2,953 GA
roadrunninMark
GA
I have the big tube that is in the trunk.
IMGTX - Ok, so if I understand correctly, the 4 lines are not necessary and the 1 vent tube is plenty. For the 1 vent tube style, it loops up into the trunk, back down through the plate. Where does it go after it goes back through the oval plate? Oh, which parts houses carry that single vent line setup?
[Re: roadrunninMark]
#3121629
02/14/23 11:02 PM
02/14/23 11:02 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
The vapor separator tank was required for all 1970 model year cars with N95 code which would include all CA sold cars. In 1971 Federal mandates required them in all 1971 model year cars.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
#3121760
02/15/23 03:17 PM
02/15/23 03:17 PM
Posts: 12,238 Looking for a way out of Middl...
IMGTX
The 4 line systems are not bad but most 70's came with the single vent line which is apparently what Holley is making the tanks for. On my Challenger the vent line starts at the top of the filler neck and goes through the plate and into the frame rail. Any fuel that gets through the tube would be dripped into the inside of the frame rail and vapors would be vented to the air inside the frame rail. On my Barracuda it starts from the single vent line on the tank. Goes through the plate, loops in the trunk, and goes back through the plate. I have not looked, so I am not positive, but I would imagine it would go into the frame also. I will try to look at my Barracuda when I get home. On a side note they got rid of the 4 line ECS used in 70/71 in 72 because it vented into the crankcase. In 72 it vents into a charcoal canister. I have heard rumors of gas fumes in the crankcase igniting and popping valley pan seals and valve covers. I have never seen it but I have heard rumors. As far as the gas cap, it is different between the systems. I know they made different latches on the necks of the Challengers but I forgot if it is a year thing or a type of cap thing. On the barracuda's the cap can not leak under acceleration with either type cap, so a vented cap should work fine if it is made for a barracuda/cuda. I know several places make the kits. This is company that has everything you need in one kit. Look at part number EFV7001OM https://www.sstubes.com/collections/fuel-lines-vent-line/Plymouth-Barracuda-1970On a side thought, you could run one line to one of the 4 lines in the ECS vent/separator then cap the other 3. It should work fine.
[Re: IMGTX]
#3122106
02/16/23 04:23 PM
02/16/23 04:23 PM
Posts: 2,953 GA
roadrunninMark
GA
That is a good idea, I think I will do this as the tank is on sale for a great price. Just ordered, 109 bux with Holley's winter sale.
[Re: IMGTX]
#3122267
02/17/23 10:34 AM
02/17/23 10:34 AM
moparmarks
Actually they didn't get rid of it. In 72-up the 4 lines are on the front of the tank and go to a small vapor tank mounted up on the shock cross member. Also in 72 the charcoal canister was Added to the system.
[Re: moparmarks]
#3122299
02/17/23 12:18 PM
02/17/23 12:18 PM
IMGTX
Actually they didn't get rid of it. In 72-up the 4 lines are on the front of the tank and go to a small vapor tank mounted up on the shock cross member. Also in 72 the charcoal canister was Added to the system. Very true. I was trying to point out the 70/71 vented to the crankcase and in 72 they vent to a charcoal canister. I worded it wrong. Good Catch. I am curious where you are getting a Holley Fuel tank for $108
[Re: IMGTX]
#3122433
02/17/23 08:18 PM
02/17/23 08:18 PM
Posts: 2,953 GA
roadrunninMark
GA
Holley is having their winter sale. Get while supplies last. They have a bunch of stuff at nice prices. If you search by vehicle, it lists it as an “A” body in title but that is incorrect. The description is for the cuda. When I looked up the a body tank, it is different number and it has a reduced area for the spare tire.
Just saw this too, sign up for emails and get an extra 10% off. You can get tank for under 100!
