Page 3 of 4 1 2 3 4
Re: Stealth Heads, Max Wedge vs Std Port [Re: FastmOp] #3120768
02/11/23 08:33 PM
02/11/23 08:33 PM
qc
mxbeep Offline
mxbeep  Offline
qc
Stealth heads are a great improvement over a stock head and very affordable. They can easilly be ported for more flow,
Just dont make the mistake i did of sending them to KG engines for their CNC porting , they came back butchered. [censored] porting,spring heights not properly done and worst of all they ruined the valve seats. Owner gave me every excuse in the book and never re imbursed a penny of the $1500.00 i paid .
Lesson learned, never deal with KG engines again and make sure no one else gets taken like me.
Re: Stealth Heads, Max Wedge vs Std Port [Re: mxbeep] #3120884
02/12/23 12:24 PM
02/12/23 12:24 PM
Central NC
gch Offline
gch  Offline
Central NC
I have a set of 440 source cnc heads I bought from a member here years ago. Times got tough and I sold them to the guy who bought my old 68 Chrysler 300 20+ years ago. Last year I bought the Chrysler 300 back from him and bought those same cnc source heads from the mechanic he sold a motor to that had them on it. So in the next month my old heads are going on my old car with a fresh 440 and the comp xe274 cam out of the motor the heads were on. Not a race car by any means but should move the old c body pretty well even with 3.23 gears. The car does have a nitrous system for extra giggles.
I look forward to finally using them after all of these years.
Re: Stealth Heads, Max Wedge vs Std Port [Re: gch] #3120891
02/12/23 12:43 PM
02/12/23 12:43 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Ootb Stealths Flow right around 260 on my bench.
Recut the seats, back cut the valves, blend the bowls and SSR, they’re basically right at 280.
Whittle down the guide boss, open the pinch a bit, relieve the chamber wall adjacent to the intake valve....... puts it right at about 290.
I suspect that from that point, increasing the size of the opening to MW size would be worth less than 10cfm.
The set from the pic below went on a build that was going to be using a factory x-ram.
Re: Stealth Heads, Max Wedge vs Std Port [Re: fast68plymouth] #3120902
02/12/23 12:56 PM
02/12/23 12:56 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Stealth Heads, Max Wedge vs Std Port [Re: pittsburghracer] #3121351
02/14/23 01:39 AM
02/14/23 01:39 AM
Colorado
GPSflyer Offline
GPSflyer  Offline
Colorado
Modern did mine max wedge size. Gave me a flow sheet at 348 cfm. I was trying to keep my 512” max wedge looking stockish. So stealth heads were my best option.
79F9AFB2-5E8D-4E62-96EE-5144D734177E.jpeg64F79C0D-9056-4379-86F9-84727DA5100B.jpegECB9E5CA-BA3C-45A2-8C60-0F900043F233.jpeg9A16525F-9CE5-48B0-B43C-9F44546EC33B.jpeg
Re: Stealth Heads, Max Wedge vs Std Port [Re: GPSflyer] #3121352
02/14/23 01:45 AM
02/14/23 01:45 AM
Colorado
GPSflyer Offline
GPSflyer  Offline
Colorado
I’ve been very happy with all of the parts I’ve ordered from 440 source. I had one issue with the lightened crank. They thru drill the end of the crank, and install a freeze plug. It leaked oil out the back of the crank after I put it in the car. Had to pull the trans to fix it. Not the end of the world.
1AEDCFD9-DCD5-4079-BD4B-5C505C9298D8.jpegC40370E2-718C-4CE9-80C7-50126EBF2803.jpegFF00D13A-A8ED-4294-B497-0A6F9D0BE494.jpeg
Re: Stealth Heads, Max Wedge vs Std Port [Re: GPSflyer] #3121509
02/14/23 04:54 PM
02/14/23 04:54 PM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
Those are some impressive flow numbers for a short valve head, love the look of that engine compartment!
How does it run?
Re: Stealth Heads, Max Wedge vs Std Port [Re: powertrip] #3121520
02/14/23 05:33 PM
02/14/23 05:33 PM
Colorado
GPSflyer Offline
GPSflyer  Offline
Colorado
It hasn’t been to the track yet. Mostly just a street car.
Old engine was a high compression 413 max wedge, and the car went 12 flats. But I got sick of having to go buy race fuel.
New stroker is pump gas friendly, and has way more power. Stroker didn’t like the old “J” converter that I had in there. seemed like it was driving through it. I recently put in a tighter TCI converter and it feels way better. Might get rid of the 4.30 gears too, the bigger engine doesn’t seem like it needs them as much as the 413 did. When the track opens back up in the spring I’ll take it and see what it runs with the 4.30s, before I mess with them though.
Still not sure on the cam either, nobody had cores to cut a cam when I was putting the engine together and I was kind of in a time crunch. I bought a used roller off of eBay, and stuffed it in there. Runs good, but I’m not sure it was exactly the right specs. It was what I could get right then. lol
Re: Stealth Heads, Max Wedge vs Std Port [Re: GPSflyer] #3121527
02/14/23 06:27 PM
02/14/23 06:27 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Very cool car!
'63 Dodge 330
11.19 @ 121 mph
Re: Stealth Heads, Max Wedge vs Std Port [Re: GPSflyer] #3121528
02/14/23 06:28 PM
02/14/23 06:28 PM
A727Tflite Offline
A727Tflite  Offline
I would imagine you have to sit in the back seat when driving - with the length of your legs and all. whistling
Re: Stealth Heads, Max Wedge vs Std Port [Re: A727Tflite] #3121533
02/14/23 06:41 PM
02/14/23 06:41 PM
Colorado
GPSflyer Offline
GPSflyer  Offline
Colorado
I should’ve gotten a C-body….
Who is this?
Re: Stealth Heads, Max Wedge vs Std Port [Re: GPSflyer] #3121544
02/14/23 07:10 PM
02/14/23 07:10 PM
A727Tflite Offline
A727Tflite  Offline
Who is this?
I reported your flow numbers a while back during another discussion.
Seems some people didn’t believe me or the flow numbers.
Re: Stealth Heads, Max Wedge vs Std Port [Re: A727Tflite] #3121549
02/14/23 07:26 PM
02/14/23 07:26 PM
Colorado
GPSflyer Offline
GPSflyer  Offline
Colorado
Yeah, that’s the numbers I was given. That’s all I know.
I’m happy with them, I wanted to keep it looking halfway stock under the hood, and was going to open up the intake ports myself to max wedge size, until modern told me they already had a file for that on stealth heads.
Re: Stealth Heads, Max Wedge vs Std Port [Re: GPSflyer] #3121602
02/14/23 09:24 PM
02/14/23 09:24 PM
A727Tflite Offline
A727Tflite  Offline
By comparison, a nice stock legal set of Stage 3 MaxWedge heads with a S/S legal valve job flowed 278 at .700”, standard valve size.
Re: Stealth Heads, Max Wedge vs Std Port [Re: A727Tflite] #3121636
02/14/23 11:25 PM
02/14/23 11:25 PM
Colorado
GPSflyer Offline
GPSflyer  Offline
Colorado
Do you happen to remember what unported stage III heads flowed? My old engine has untouched heads on it, after I pulled it out of the car it got rebuilt and stuck in the corner of the garage. It ran good, but nothing like the new engine. I’m sure my dad or I will come across some car to stick it in.
Re: Stealth Heads, Max Wedge vs Std Port [Re: GPSflyer] #3121641
02/15/23 12:01 AM
02/15/23 12:01 AM
A727Tflite Offline
A727Tflite  Offline
The numbers I mention above your post are unported MaxWedge.
Re: Stealth Heads, Max Wedge vs Std Port [Re: GPSflyer] #3121684
02/15/23 10:31 AM
02/15/23 10:31 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Very cool build and engine compartment looks super clean with nice retro features. Always loved the 62 Dart.
2 kids and a dog
Re: Stealth Heads, Max Wedge vs Std Port [Re: fast68plymouth] #3121854
02/15/23 08:13 PM
02/15/23 08:13 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
So I went and pulled my MCH data comparing CNC “std. port” and MW CNC w/ 2.19.
The MW w/ 2.19s was about 11 cfm better @ 0.200”, 0.300” and 0.400”, 7.5 cfm @ 0.500”, 6.5 cfm @ 0.600, and 3.5 cfm @ 0.700”.
I assume the low lift improvement was due to the larger valve.
Re: Stealth Heads, Max Wedge vs Std Port [Re: GPSflyer] #3121939
02/16/23 06:13 AM
02/16/23 06:13 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
There is a black 62 dart roller for sale in k falls.
On topic, does anyone currently offer a MW program for the Stealths? I have a set that needs some love.
Re: Stealth Heads, Max Wedge vs Std Port [Re: BSB67] #3121972
02/16/23 10:49 AM
02/16/23 10:49 AM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
I take it the std port CNC port still had the 2.14 valve?
Page 3 of 4 1 2 3 4
