Graveyard cars repaired 383 MASSIVE CRACKS
#3120446
02/10/23 01:21 PM
02/10/23 01:21 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Pretty impressive the shop that repaired that 383, thing many years ago would be JUNK. They cut out the bad spots completely out, ground them down, and brazed them together, and they held to a running engine, AND they looked good on the outside! very impressed they managed to not only fix the cracks, fix the lifter valley blow outs, re square the block, but did it in a way that honestly being a welder myself, looks to be very very reliable. I wish they would have plugged that repair shop in the show.
Re: Graveyard cars repaired 383 MASSIVE CRACKS
[Re: Moparnut426]
#3120474
02/10/23 03:11 PM
02/10/23 03:11 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I'd like to see that bill.
Shop must have refused a freebie for a plug.
[Re: Moparnut426]
#3120493
02/10/23 04:07 PM
02/10/23 04:07 PM
Posts: 43,230 Bend,OR USA
Cab_Burge
Pretty impressive the shop that repaired that 383, thing many years ago would be JUNK. They cut out the bad spots completely out, ground them down, and brazed them together, and they held to a running engine, AND they looked good on the outside! very impressed they managed to not only fix the cracks, fix the lifter valley blow outs, re square the block, but did it in a way that honestly being a welder myself, looks to be very very reliable. I wish they would have plugged that repair shop in the show. I've had a lot of cranks repair by several different good machine shops, none of them ever brazed a crack in a crank, NEVER. There is a welding rod that looks like brazing that I have seen used by good crank shops when they added weight onto a counterweight to finishing the balancing
[Re: Moparnut426]
#3120510
02/10/23 05:22 PM
02/10/23 05:22 PM
Posts: 1,365 Out of the State of Confusion
blue_stocker
I'd like to watch that episode...which was it? Back in the day, an old welder at MINSY told me a story of him welding a steel plate on the side of a 440 block that had been in a Calif HP, having crashed and had an actual hole in the block. He 'claimed' it never leaked! Being an old-time shipyard welder, you never know as some of those old-timers had tricks even weld engineers can't figure out...and that is a fact!
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
[Re: ksj]
#3120575
02/10/23 10:06 PM
02/10/23 10:06 PM
Frackster
[Re: dart games]
#3120630
02/11/23 10:45 AM
02/11/23 10:45 AM
Posts: 10,735 North Dakota
6PakBee
North Dakota
I was more impressed with the sections on the Daytona clone. First time I have ever seen it mentioned that the stock headlight buckets have to be removed from the front fenders.
[Re: Moparnut426]
#3120634
02/11/23 11:12 AM
02/11/23 11:12 AM
Posts: 146 Missouri
randavis
Missouri
He did say several times that it was a numbers matching block and it cost somewhere in the neighborhood of $20 grand for the engine build. After the extreme heat on the block during welding, it required the cam bore and main bore to be re-bored and the block head surfaces had to be squared. It was overbored .040. It had bushings in the lifter bores. That's a lot of cash to save an old 383 block. Also mentioned was that the transmission was not original. Worman kept saying the original block would increase the value $50 grand, which I find hard to believe, especially since the transmission wasn't original.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: B1Frank]
#3120654
02/11/23 12:30 PM
02/11/23 12:30 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Depending on the year of the car, someone has surely figured out how to create a "numbers" block. And the result would be better than a patched up piece.
I've heard of that being done on other make engines.
"Numbers" trans should also not be difficult.
Disclaimer: I'm not advocating fraud. Just commenting on the possibilities.
[Re: Cab_Burge]
#3120668
02/11/23 01:04 PM
02/11/23 01:04 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
He did say several times that it was a numbers matching block and it cost somewhere in the neighborhood of $20 grand for the engine build. After the extreme heat on the block during welding, it required the cam bore and main bore to be re-bored and the block head surfaces had to be squared. It was overbored .040. It had bushings in the lifter bores. That's a lot of cash to save an old 383 block. Also mentioned was that the transmission was not original. Worman kept saying the original block would increase the value $50 grand, which I find hard to believe, especially since the transmission wasn't original. When people over state the actual market value they are either stupid or greedy Me thinks they are greedy Since this is a TV show, add pandering to that. TV shows over inflate and exaggerate reality to make a better story and grab viewers attention. In this case I'd call them all three: Stupid, Greedy, and Pandering.
[Re: Cab_Burge]
#3120680
02/11/23 01:37 PM
02/11/23 01:37 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
He did say several times that it was a numbers matching block and it cost somewhere in the neighborhood of $20 grand for the engine build. After the extreme heat on the block during welding, it required the cam bore and main bore to be re-bored and the block head surfaces had to be squared. It was overbored .040. It had bushings in the lifter bores. That's a lot of cash to save an old 383 block. Also mentioned was that the transmission was not original. Worman kept saying the original block would increase the value $50 grand, which I find hard to believe, especially since the transmission wasn't original. When people over state the actual market value they are either stupid or greedy Me thinks they are greedy The two are not mutually exclusive. In fact, they often go hand in hand Cab.
[Re: autoxcuda]
#3120684
02/11/23 01:49 PM
02/11/23 01:49 PM
Posts: 20,825 A collage of whims
topside
A collage of whims
Yeah, it doesn't add up - $50K boost for a fairly average 383 car (and I like 383s) for a matching engine? And the trans doesn't match anyway? $20K for the repair? At the least, to me that came across as defending the restoration bill for the car. And the repaired area on the outside of the block was fairly obvious; without any guarantee that the repair would hold up, it doesn't seem like a wise use of money. I think most folks would put a stroker low-deck in, save the damaged block, and enjoy the car...I would...
Back in the early '70s, we used to buy ported race heads from Traco that had cracks in the combustion chambers, and take 'em to Cyclone Excel-weld in L.A. for repairs. IIRC, they were the best guys in the area at repairing cast iron. Pretty smokin' deal all done and they worked fine in the drag cars; saved the car owners lots of $. May not make sense nowadays with the proliferation of good heads, and in aluminum to boot, which are easier to repair.
Agree on the reduced schtick lending a better presentation; I found the math & backwards intake segments pretty funny, though the intake raises questions about paying attention. Seemed to me the lifters on that 383 were noisy for a long time on the run-in stand, but maybe that was just the microphone?
[Re: 69Cuda340S]
#3120836
02/12/23 04:44 AM
02/12/23 04:44 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Agree 100% on the 400 block.
There is a lot of logging and rail industry in central Oregon that might do cast iron block work.
I used to take my clutch and pressure plates to Eugene on the Amtrak. That section of the business was bought out and collapsed to Portland.
