Page 2 of 3 1 2 3
Re: Another Kablooey 727 [Re: Mr PotatoHead] #3120094
02/08/23 09:47 PM
02/08/23 09:47 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Knowledge is lacking in today’s world, people wrenching on a car-trans and can’t tell a 9/16” wrench from a 1/2” then blame it on the front drum.
Re: Another Kablooey 727 [Re: CMcAllister] #3120102
02/08/23 10:03 PM
02/08/23 10:03 PM
CA
crackedback Offline
crackedback  Offline
CA
Originally Posted by CMcAllister
I made a guy pull a 904 and bring it to me once. He had broken a rear, fixed it, and was driving the car around on the street. Everything seemed okay and it was going to the track. I insisted he pull it.
Half of the springs were mashed flat by the rollers when the rear broke. The rollers were loose in the assembly. The other half were still functioning enough to drive the car around. It would not have survived the first hit.
You need a high rpm engine to blow up an OEM 904 drum. It's a non issue.
Re: Another Kablooey 727 [Re: crackedback] #3120104
02/08/23 10:07 PM
02/08/23 10:07 PM
How high is high RPM?
I'm getting ready to build a 1965 Valiant SB stroker turbo car with a 904 in it, I'll probably have Pro Trans build a 904 tranny for me, but it would be nice to know what RPM the 904 drums are sensitive to work help
Re: Another Kablooey 727 [Re: Cab_Burge] #3120119
02/08/23 11:23 PM
02/08/23 11:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've never heard of it happening. But I also want to avoid breaking a trans on the starting line.
Re: Another Kablooey 727 [Re: Blusmbl] #3120169
02/09/23 09:07 AM
02/09/23 09:07 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
Originally Posted by Blusmbl
I wonder how long that sprag had been hurt, or if he did the damage on the first burnout in 1st gear where it seemed like he pedaled it and also shifted to second.
That's my worst nightmare with a non-LBA valve body. I don't do first gear burnouts but it still worries me.
Can a non-LBA valve body be replaced with an LBA valve body without any other changes, or is it best to pull the trans when you swap them?
You should be able to swap a non LBA valve body with a LBA valve body with no other changes.
Re: Another Kablooey 727 [Re: JohnRR] #3120176
02/09/23 09:48 AM
02/09/23 09:48 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
71Demon- thanks. I need to start collecting 727 parts, have seen too many of these and I'm worried about mine.
Crackedback.... LOL! good point, at least ours scatter when the car isn't going to end up in the wall.
Originally Posted by JohnRR
listening to the guy it sounded like he saw he put it into manual low and shifted to second , at least he thought he did that .
I'm still trying to figure out how the trans shifted it self into park after it went boom with the shift linkage ripped off.
That makes sense, the manual low burnouts seem like bad news, especially with that stock drum!
Maybe when parts scattered, the drum hit the shift linkage just right and pulled it?
Re: Another Kablooey 727 [Re: Blusmbl] #3120209
02/09/23 12:07 PM
02/09/23 12:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A manual low burnout with a stock type valvebody will apply the low band so it technically should not hurt the sprag because the sprag isn't really holding the rear drum from spinning ... if the band is adjusted properly ...
With that in mind when the trans in manual low it is the furthest from being in park but the explosion probably ripped the park rod off the VB and with it pulled out of position into park the trans will go ...
as far as parts you need to be safe , it's really just 1 , but I would spend the extra and get 2 ...
Billet front drum is a must , and an A+A SUPER Sprag , it has more rollers and can't easily be rolled over , if at all.
Re: Another Kablooey 727 [Re: JohnRR] #3120211
02/09/23 12:19 PM
02/09/23 12:19 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
The internet, youtube, etc. has brought about so many people who believe they have talent, are funny or have some entertainment value of some sort and need to put it out there for everyone to see. All these Roadkill, Last Stop Garage, Azz Monkey Garage etc. wannabes. whiney This trans was probably rigged to do that for the video.
Facts are stubborn things.
Re: Another Kablooey 727 [Re: larrymopar360] #3120401
02/10/23 08:37 AM
02/10/23 08:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Did you see the hole in the floor and the trans fliud on the drivers side window ???? If it was rigged for that it would have had a blanket on it , only an idiot would rig something like that and then get in it and make it go boom.
Re: Another Kablooey 727 [Re: JohnRR] #3120419
02/10/23 10:48 AM
02/10/23 10:48 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
World is full of idiots
Re: Another Kablooey 727 [Re: Sniper] #3120425
02/10/23 11:37 AM
02/10/23 11:37 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Been racing my whole life since 16 and have never grenaded a torque flight. Yes, I have broken converters, front pump seals, lost second gear a couple of times but never had one explode. Just build them with good parts.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Another Kablooey 727 [Re: CMcAllister] #3120451
02/10/23 01:31 PM
02/10/23 01:31 PM
PA
Scully Offline
Scully  Offline
PA
You can feel and hear a healthy sprag from a damaged one pretty easily by turning the driveshaft with your hands but if possible it's certainly a good idea to pull the trans.
Re: Another Kablooey 727 [Re: cudaman1969] #3120453
02/10/23 01:41 PM
02/10/23 01:41 PM
PA
Scully Offline
Scully  Offline
PA
I got my B&M LBA valve bodies back in 73 for pushbutton and the later. I tried the TA one for a year or so and damaged a sprag when I broke an axle, out it came and the old B&M went back in. A&A is going to make me one for my third car this year.
Re: Another Kablooey 727 [Re: Scully] #3120463
02/10/23 02:30 PM
02/10/23 02:30 PM
A727Tflite Offline
A727Tflite  Offline
This method will certainly bite you in the a$$. Eventually.
There are a few failure modes - bad springs and rollers are one.
Re: Another Kablooey 727 [Re: JohnRR] #3120466
02/10/23 02:41 PM
02/10/23 02:41 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Awesome, thanks. I need to start ordering parts. I assume the higher the rpm that it lets go in 1st gear, the worse the shrapnel is!
Also agree, there is no way that was staged. And, at least Tony offered to help him rebuild his spare or use a trans he had in the shop.
Re: Another Kablooey 727 [Re: 6PKRTSE] #3120470
02/10/23 03:00 PM
02/10/23 03:00 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Blowing up a 727 is kind of like shooting someone accidentally. A number of mistakes and broken rules have to happen first. But it happens,
Second gear burnouts. Take it out and look at it if something in the driveline breaks under power in low gear, regardless what kind of valve body is in it. Good front drum.
Miss one. Probably okay. Miss a few, better have a shield on it.
Re: Another Kablooey 727 [Re: Blusmbl] #3120471
02/10/23 03:03 PM
02/10/23 03:03 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Broke sprag last September due to a worn out transmission case. Very fortunate I have a A&A aluminum drum, or it could have been catastrophic. Went right to the Rev limiter 6700. Dummy me tried it again on return road.
https://youtube.com/watch?v=WdgwaO7IK9I&si=EnSIkaIECMiOmarE
Re: Another Kablooey 727 [Re: A727Tflite] #3120472
02/10/23 03:07 PM
02/10/23 03:07 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Driving it around, functioning and seeming to be okay is not a valid test.
Having half the springs smashed will certainly change how it feels when spinning the output shaft. But I'm not going to trust that one either. Take it out and look at it, or roll the dice.
Re: Another Kablooey 727 [Re: CMcAllister] #3120500
02/10/23 04:36 PM
02/10/23 04:36 PM
A727Tflite Offline
A727Tflite  Offline
Correct. The springs and rollers are only part of the equation. Propelling functioning and sounding on jack stands isn’t a test and driving seemingly ok isn’t either.
Re: Another Kablooey 727 [Re: JohnRR] #3120503
02/10/23 05:04 PM
02/10/23 05:04 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
You said it not me.
I don't know. Like I wrote, I guess I'm strange. I'm also suspicious of most things internet and very tired of all the "car people" that have come out of the woodwork and found their way to the internet and tv. A great majority are not entertaining to ME. Fake drama, not funny as they seem to think they are, and just plain dumb. Maybe they did destroy a 727. That doesn't make it worthy of youtube or whatever. Hey, that's just ME and my opinion which is not worth a nickle.
I wish Wayne Carini did Mopars. I could watch him all day long.
Page 2 of 3 1 2 3
