26 Inch Rad Upper Hose #3120167
02/09/23 08:58 AM
02/09/23 08:58 AM
Canada
Ghoste Offline OP
Ghoste  Offline OP
Canada
What is the difference between the 440 hose and the Hemi hose for the upper rad hoses in a 69 B body with a 26 inch radiator? Part number and price obviously but other than that, would they not be the same?
I see a light at the end of the tunnel, and it's... ELECTROLUMINESCENT!
Re: 26 Inch Rad Upper Hose [Re: Ghoste] #3120178
02/09/23 09:49 AM
02/09/23 09:49 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Shape
Re: 26 Inch Rad Upper Hose [Re: gtx6970] #3120187
02/09/23 10:23 AM
02/09/23 10:23 AM
Canada
Ghoste Offline OP
Ghoste  Offline OP
Canada
Ok thanks.
Re: 26 Inch Rad Upper Hose [Re: gtx6970] #3120201
02/09/23 11:45 AM
02/09/23 11:45 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I think there are two upper radiator hoses for the 440 also ???? One for an A/C 440 and of course non-A/C. The A/C hose has a little rise to it for alternator to A/C belts pulley or am I mistaken?
Re: 26 Inch Rad Upper Hose [Re: A12] #3120207
02/09/23 11:56 AM
02/09/23 11:56 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm not sure . And no longer have a parts book that new to ck.
Only parts books I have are 66 and 67
Re: 26 Inch Rad Upper Hose [Re: gtx6970] #3120218
02/09/23 12:34 PM
02/09/23 12:34 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I know this is a 383 but I had this issue when I first ordered a replacement upper hose for it, that's when I found out there was a different upper hose for A/C cars. They have the rise for the A/C belts for maximum slack or belt wear. The non-A/C hose will work with A/C but it's close with loose belts, and not correct for the anal purists grin wink
Re: 26 Inch Rad Upper Hose [Re: A12] #3120388
02/10/23 12:47 AM
02/10/23 12:47 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
BTW the HEMI has the timing and idle rpm label on the wrong side for a 1968 model year and the judges never docked him or anyone else for that. So why was it moved to the driver's side on the '69 B-body Plymouths? (I know and that's why my '68 RR in the photo has it on the right passenger's side.)
