MSD box #3119772
02/07/23 09:50 PM
02/07/23 09:50 PM
New Kent, Va.
bobbyb Offline OP
bobbyb  Offline OP
New Kent, Va.
I was wondering if you can use a MSD box with the Mopar electronic conversion kit and not use the MSD distributor?
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: MSD box [Re: bobbyb] #3119774
02/07/23 09:53 PM
02/07/23 09:53 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Yes, absolutely.
Re: MSD box [Re: GomangoCuda] #3119814
02/07/23 11:48 PM
02/07/23 11:48 PM
Originally Posted by GomangoCuda
Yes, absolutely.
iagree Done it many times, fix the wiring harness for the Mopar mag pick up and get it done wrench up
Re: MSD box [Re: Cab_Burge] #3119918
02/08/23 12:41 PM
02/08/23 12:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
On a street car I think the MSD is a waste of money that could be better spent elsewhere. In addition IF it screws up, you can be screwed yourself twocents popcorn
Re: MSD box [Re: TJP] #3119984
02/08/23 02:57 PM
02/08/23 02:57 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I generally trigger my MSD units with a Mopar electronic distributor - it's in their instructions, which are also online.
All my MSDs have been 6A or 6AL.
Best coil to use is a parts-store 89-90-ish Ford F150 epoxy coil; they have an HEI post and require a bracket (easy to fab) and a pigtail (parts store).
Been using the MSD/MP setup for over 30 years with only 1 problem from an oil-filled Blaster coil.
It's been a great system for my street and/or strip cars.
Re: MSD box [Re: topside] #3120424
02/10/23 11:34 AM
02/10/23 11:34 AM
New Kent, Va.
bobbyb Offline OP
bobbyb  Offline OP
New Kent, Va.
Thanks guys for the info, I’ve been owning old mopars since the 70’s and never used a MSD box, so I was thinking about using one to improve my ignition. Thanks
