Re: Drag Car and Deep Sump Pans
[Re: Mopar.70]
#3119445
02/06/23 10:48 PM
02/06/23 10:48 PM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
If my pan was JUST 2" lower than my K member, I wouldn't know how to act. Have to be real carefull at some tracks. I actually dragged my pan going into my shop one time. Fixed that. I also can't run short front tires either.
Brian
[Re: Mopar.70]
#3119714
02/07/23 06:47 PM
02/07/23 06:47 PM
'72CudaRacer
Mooresburg, Tn
72CudaRacer, I've got the same body, guessing for about the same ET as well. How far below the K member is your pan if you don't mind me asking and what front shocks are you running? Thanks! The engine is out of the car on a stand, but by my calculations, the sump is roughly 6"-6 1/2" lower than the bottom of the K member. Front shocks are (gasp!) cal-trac's 90/10. (obviously, they don't work) Brian
[Re: Mopar.70]
#3119768
02/07/23 09:45 PM
02/07/23 09:45 PM
Posts: 43,298 Bend,OR USA
Cab_Burge
I started using the stock type Mopar 6 quart street hemi and 440 Six Pack oil pan with the stock 3/8 440 oil pickup in a lot of my street and strip builds years ago with great results My pump gas Duster motor was a 400 block stroker motor that was 517 C.I. with that pan and pickup and ran a bunch of 10.00 at 134.+ MPH through the complete 3.0 inch exhaust system to the rear bumper and air cleaner on The only problem I had was if I let the oil level get down one full quart while drag racing it at a 1/4 mile track, the oil pressure would start to drop off after I let off the throttle completely about 200 to 300 ft. past the 1/4 mile finish line It wouldn't drop to zero, maybe down to 30 to 40 lbs. and then come back up within 3 to 5 seconds, faster if I tapped the throttle a little bit, it would do that only if was 1 quart or more low I would make sure it was at the full mark before racing it at the 1/4 mile tracks, those are GREAT oil pans
[Re: Mopar.70]
#3119867
02/08/23 09:32 AM
02/08/23 09:32 AM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
