Best Price on Titanium 2.45 Intake Valves? #3119074
02/05/23 01:41 PM
02/05/23 01:41 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Who do you guys like for Titanium intake valves? I gota say, the prices I have found so far from Ferrea are not agreeable with my pocket book...
Re: Best Price on Titanium 2.45 Intake Valves? [Re: Dragula] #3119080
02/05/23 02:08 PM
02/05/23 02:08 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Try Manly. Use racer net should get some off
Re: Best Price on Titanium 2.45 Intake Valves? [Re: FastmOp] #3119146
02/05/23 05:44 PM
02/05/23 05:44 PM
Dragula Offline OP
Dragula  Offline OP
So I went on the Manley website. A standard SS valve for a G2 Hemi is 138grams......A damn Titanium one for a a BAE is 137grams....granted the stems are a tad different in size is .003 different, they are listed as the same weight...
Ferrea does not give the weights...How do even compare?
Re: Best Price on Titanium 2.45 Intake Valves? [Re: Dragula] #3119193
02/05/23 08:59 PM
02/05/23 08:59 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I've always liked Victory valves for titanium valves. I don't know if they're the cheapest, but they've been the best for my money
Alan Jones
Re: Best Price on Titanium 2.45 Intake Valves? [Re: LA360] #3119212
02/05/23 10:26 PM
02/05/23 10:26 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We run them all depending on application. Ferrea, Manley, Trick Titanium (Scitek), Xceldyne, Del West. About in that order price wise.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Best Price on Titanium 2.45 Intake Valves? [Re: 6PKRTSE] #3119218
02/05/23 10:48 PM
02/05/23 10:48 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I use REV https://revvalves.com/ Ti intake valves are $140
Joe
Without Data, you’re just another guy with an opinion.
Re: Best Price on Titanium 2.45 Intake Valves? [Re: sr4440] #3119220
02/05/23 11:07 PM
02/05/23 11:07 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Have to ask, you referenced a 6200 shift point in your other thread.
Is your plan to keep it there? If so, IMO, would not be worth the cost to go to a Ti valve.
You could save a bunch of weight with a smaller diameter spring and ti retainers/locks. (that's what I did)
Re: Best Price on Titanium 2.45 Intake Valves? [Re: INTMD8] #3119237
02/06/23 08:22 AM
02/06/23 08:22 AM
Dragula Offline OP
Dragula  Offline OP
Retainers & locks are already Titanium.
And, this is the second time I have killed the intake valve springs. I do not know the weight difference between a SS Hemi 2.25 stock valve and a SS 2.40, but it must be enough, along with lack of oil on the valve springs to wipe everything out each year....So in the interest of possibly saving the intake valve springs, I am looking into 2.40 to 2.45 Titanium valve springs regardless of shift point.
I also bought a newer cam that has a milder ramp rate and only requires 180lbs closed..Its -.030 lift as well, but at this point, if I can't drive it or race it, any move in the positive direction is good.....I will be checking my current ones, but I think they are north of 220lbs closed. So I will also need new springs as well, and watching Steve Tech, he did not give any brand names out that use the newer designs, so that might be a crap shoot. If I have triple springs, I will look for a set of doubles. I think I should have paid more attention to the setup and parts selected than I did. For racing, eveything would probably be just fine, but add in all the street miles, and things change drastically.
Re: Best Price on Titanium 2.45 Intake Valves? [Re: Dragula] #3119384
02/06/23 06:38 PM
02/06/23 06:38 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
I put victory's in my hemi, but they where 2.40. fwiw i wouldnt do a valve that big in S.S. Put proper seats in it, and they work just fine.
Re: Best Price on Titanium 2.45 Intake Valves? [Re: cuda499] #3119437
02/06/23 10:06 PM
02/06/23 10:06 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
I also run Victory Titanium Valves, but only on Intakes, exhausts are in ones, Victory quality is exceptional, but price can hit your wallet .
I have Berryilium valve seats, as material suits Titanium & also Berryliuum also helps dissipate heat, which helps my turbo application.
Titanium does not cool off as quickly as Stainless, so weight saving is a partial trade off to running hotter valves
Re: Best Price on Titanium 2.45 Intake Valves? [Re: Dragula] #3119773
02/07/23 09:50 PM
02/07/23 09:50 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
My Manley 2.250s weigh in at 146 grams
Re: Best Price on Titanium 2.45 Intake Valves? [Re: Hot 340] #3119775
02/07/23 09:54 PM
02/07/23 09:54 PM
Dragula Offline OP
Dragula  Offline OP
Are those SS or Ti?
Re: Best Price on Titanium 2.45 Intake Valves? [Re: Dragula] #3119778
02/07/23 09:59 PM
02/07/23 09:59 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Are those SS or Ti?
SS
Re: Best Price on Titanium 2.45 Intake Valves? [Re: Hot 340] #3119944
02/08/23 01:35 PM
02/08/23 01:35 PM
Dragula Offline OP
Dragula  Offline OP
Called Brian at Victory and had a really good conversation about this.....My thoughts are the older 2.25 valves were never too heavy to cause an issue, and the new 2.40 stainless valves are that much heavier that this has become an issue....When I look at ALL the BB drag and drive engines out there, at least when they post the specs, they all have Titanium intake valves at this size. The new GM 632 crate motor has them for both intake, and exhaust...So it seems like its one of those hidden necessities....I don't know, but that is where my thinking is headed.
He quoted me:
$134/valve
$40/coating the whole valve (no lash caps needed)
$22/Retainer
$7/Lock
X8_____________
$1624 for 8 new intake valves, locks & retainers
Re: Best Price on Titanium 2.45 Intake Valves? [Re: Dragula] #3119968
02/08/23 02:12 PM
02/08/23 02:12 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
He quoted me:
$134/valve
$22/Retainer
$7/Lock
X8_____________
Always cheaper to do it the right way once.
Re: Best Price on Titanium 2.45 Intake Valves? [Re: Dragula] #3120245
02/09/23 02:18 PM
02/09/23 02:18 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
He quoted me:
$134/valve
$22/Retainer
$7/Lock
X8_____________
I personally like lash caps, especially the style which are held in place by the retainer/locks.
Did he not recommend a valve seat for Titanium Valves, maybe because mine is a turbo application it has Berrilium Seats. I know it helps with heat dissipation
