Re: Markup on parts
[Re: cudaman1969]
#3118299
02/02/23 01:17 PM
02/02/23 01:17 PM
Posts: 2,119 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Markup on parts
[Re: W.I.N. Racing]
#3118304
02/02/23 01:29 PM
02/02/23 01:29 PM
Posts: 11,695 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Big difference between good stuff and China junk. Pay half price, get what you pay for. Amazon will probably get you counterfeit stuff. Get hooked up with Randy's. Do 10 or 15K a year+ and get a deal. ATech will save you a few pennies but free freight takes a lot more then $99. Whoopie. There are no deals on parts anymore. Unless you buy in to the deep deal at the source. Even owning a shop gets you very little off of what Harry the Homeowner gets walking in off the street. It ain't 1969 anymore.
Re: Markup on parts
[Re: moparx]
#3118330
02/02/23 02:27 PM
02/02/23 02:27 PM
Posts: 1,848 South Bend
John Brown
South Bend
143% increase in pricing is much more common in the autoparts business than the 200% increase is.
So, a part that cost a seller $10.00 would be marked up to $14.30, not $20.00.
Take this from a 30+ year parts guy / sales rep.
Re: Markup on parts
[Re: CMcAllister]
#3118357
02/02/23 03:57 PM
02/02/23 03:57 PM
Posts: 8,345 fredericksburg,va
cudaman1969
fredericksburg,va
Big difference between good stuff and China junk. Pay half price, get what you pay for. Amazon will probably get you counterfeit stuff. Get hooked up with Randy's. Do 10 or 15K a year+ and get a deal. ATech will save you a few pennies but free freight takes a lot more then $99. Whoopie. There are no deals on parts anymore. Unless you buy in to the deep deal at the source. Even owning a shop gets you very little off of what Harry the Homeowner gets walking in off the street. It ain't 1969 anymore. Summit and Jegs had same price as Amazon, same brand. They came from a national name brand store, they sponsor a national Event. I’m amazed every time he gets me a part or parts. We’re not talking penny’s here. Heck I’m thinking of getting a job there just for that benefit.
Re: Markup on parts
[Re: cudaman1969]
#3118365
02/02/23 05:01 PM
02/02/23 05:01 PM
Posts: 20,906 A collage of whims
topside
A collage of whims
I managed an AutoZone store for awhile, and employees got a 25% discount; the mentality their upper management has tells me that was of little concern to them. Name-brand US-made or offshore origin, same deal. Wouldn't surprise me if their mark-up was 100%; they have to eat a lot of stuff when Customers buy the wrong part, try to hammer it in, then return for the full refund. AZ returns those to the manufacturer and they end up eating that expense instead of AZ..."cost of doing business". Storefronts are expensive to build, operate, and staff, plus the advertising/promotion, loaner tools, and there are several layers (seemed at least 3) of management. The cost for plowing snow one month was around $1,200, but that was a pretty heavy winter. A buddy of mine who makes tools sells directly to Summit, Jeg's, Speedway, etc, but IIRC Summit's stuff mainly comes from/through A-Tech; maybe Jeg's & etc, too. He actually makes a bigger % than they do, but he buys mostly offshore and does his own assembly, quality control/testing, and some packaging. IIRC, the stuff retails at about 75 - 100% markup above what he gets.
Re: Markup on parts
[Re: topside]
#3118367
02/02/23 05:08 PM
02/02/23 05:08 PM
Posts: 4,703 Wichita
GY3
Wichita
You guys think the automotive markup is bad, try the HVAC industry.
The manufacturer sells it to the distributor who marks it up (won't say how much because I'm a distributor) who then sells it to the contractor who often has a markup of 1.7 to 2 times what they purchased it for.
Re: Markup on parts
[Re: GY3]
#3118382
02/02/23 06:28 PM
02/02/23 06:28 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Markup % depends mainly upon the distribution channel.. Goes from the OE supplier to distributor to retail seller, so from prime OE cost the part is marked up 4X/5X times.. Just my $0.02...
Re: Markup on parts
[Re: cudaman1969]
#3118390
02/02/23 07:06 PM
02/02/23 07:06 PM
Posts: 4,211 New York
polyspheric
New York
I got counterfeit Norelco electric razor blades in sealed "factory" boxes from Amazon!
Of course, the other scam is a HIGH price ("this can't be Chinese!").
Boffin Emeritus
Re: Markup on parts
[Re: cudaman1969]
#3118420
02/02/23 08:59 PM
02/02/23 08:59 PM
Posts: 12,268 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
There are different levels of precision within the same part number of bearings. Which impacts the price outside of ' markup' and even brand. ' Some applications demand a high level of precision that cannot be achieved with standard tapered roller bearings. This includes many machining, printing press and rolling mill applications where combinations of tight tolerances, high speeds and radial and thrust loads are present. For more than 50 years, The Timken Company has offered a wide array of precision-class tapered roller bearings that deliver superior accuracy and control in critical applications.
Different Levels of Precision Meet Critical Needs The more demanding the precision objective, the more accurate the bearing must be. Timken provides four precision classes, in both metric and inch systems, that cover the full range of precision application requirements. In ascending order of accuracy, they are identified in the metric system as Class C, B, A and AA, while in the inch system as Class 3, 0, 00 and 000. The chart below summarizes the accuracy of Timken precision bearings as compared to standard bearings. All Timken precision bearings have an electrolyte acid dot etched on both faces of each cone and cup. This dot indicates the high point of the cone and cup run-out, respectively, and is used when mounting to obtain the best performance' www.timken.com/resources/precision-tapered-roller-bearings-brochure' The Annular Bearing Engineering Committee (ABEC) created a rating system that has become the industry standard for ball and roller bearing tolerances. ABEC includes five tolerances classes: 1, 3, 5, 7, and 9 with 1 being the widest and 9 the tightest. Thus, bearings with a higher ABEC rating have tighter tolerances, and that means better precision, higher efficiency, and the potential to accommodate applications requiring high speeds.
It is important to note that a bearing in a higher ABEC class does not imply that the bearing can carry a higher load, rather it can carry the same load as an analogous bearing with a lower rating but at higher speed, thanks to its more controlled runout and smaller endplay. ISO has an equivalent standard (ISO 492) for bearing tolerances that corresponds to the ABEC ratings as follows: normal class 6x (tightest), 6, 5, 4, and 2.
The ABEC tolerance classifications specify both tolerances of size and form for the individual inner and outer rings. The critical features of the rings include the bore (or inner diameter of the inner ring), the outer diameter of the outer ring, the ring widths, and the raceways of each ring. Tolerances of form include roundness, taper, runout, and parallelism.' https://blog.emersonbearing.com/blo...wisely-how-fast-your-bearings-need-to-go
Master, again and still
Re: Markup on parts
[Re: DaveRS23]
#3118437
02/02/23 09:27 PM
02/02/23 09:27 PM
Posts: 43,295 Bend,OR USA
Cab_Burge
The ABEC tolerance classifications specify both tolerances of size and form for the individual inner and outer rings. The critical features of the rings include the bore (or inner diameter of the inner ring), the outer diameter of the outer ring, the ring widths, and the raceways of each ring. Tolerances of form include roundness, taper, runout, and parallelism.' https://blog.emersonbearing.com/blo...wisely-how-fast-your-bearings-need-to-go I saw this on my airplane wheel bearings that had to have a bearing part # with a G suffix on it to be FAA legal, 4 times more money than the standard automotive wheel bearings
Re: Markup on parts
[Re: GY3]
#3118445
02/02/23 09:42 PM
02/02/23 09:42 PM
cudaman1969
fredericksburg,va
The manufacturer sells it to the distributor who marks it up (won't say how much because I'm a distributor) who then sells it to the contractor who often has a markup of 1.7 to 2 times what they purchased it for. I can vouch for that, just had the blower replaced on inside unit. Motor is about the size of a gallon can, took him 20 minutes to replace and put all back together, $1309, had to have it because it was cold (22) outside. But I’ve probably done $100,000s worth of cabinets in his houses and garages, his mothers house and his wife’s mother’s house. We’re Mopar buddies too but he’s RICH!
Re: Markup on parts
[Re: cudaman1969]
#3118462
02/02/23 10:45 PM
02/02/23 10:45 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I have been a WD or better almost 30 years. I purchase several hundreds of thousands of dollars of race parts a year. It is amazing the cost savings we get off of retail or list pricing on so many parts.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Markup on parts
[Re: 6PKRTSE]
#3118533
02/03/23 10:33 AM
02/03/23 10:33 AM
Posts: 10,757 North Dakota
6PakBee
North Dakota
The way I look at it, buying new parts is no different than buying used parts. Pay the price or go without. Period.
Re: Markup on parts
[Re: John Brown]
#3118568
02/03/23 11:48 AM
02/03/23 11:48 AM
Posts: 3,024 NY
B1duster
NY
Take this from a 30+ year parts guy / sales rep. Wouldn’t a 143% increase in price on a $10 item be $24.30 ?
Re: Markup on parts
[Re: B1duster]
#3118617
02/03/23 03:03 PM
02/03/23 03:03 PM
Posts: 20,200 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Have you ever watched Shark Tank and see what markup was. How do you think the rich get richer
Re: Markup on parts
[Re: B1duster]
#3118623
02/03/23 03:10 PM
02/03/23 03:10 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Take this from a 30+ year parts guy / sales rep. Wouldn’t a 143% increase in price on a $10 item be $24.30 ? Yes. 100% of $10 is $10. 43% of $10 is $4.30. So, 143% of $10 is $14.30. The part cost $10 100% markup would add $10 43% markup would add $4.30 Final price would be $24.30.
