Score of scores!! not a car.... #3117953
01/31/23 05:05 PM
01/31/23 05:05 PM
Finally a HUSKER again
Moparnut426 Offline OP
So Having an acreage, 3 acres, a commercial Diesel mower, my lil tractor, and my nice cars I have been looking for a Hotsie, Alkota, diesel fired heated power wash machine, I cant afford a new one and justify the 8800 they get for a decent one, but have been keeping my feelers out. Im scrolling local listings on facebook, and there is a local guy roughly 25 miles from me who has an older machine for 250 bucks, but the burner dosn't work. Being a mechanic I figured I cant go wrong, Its an Alkota 518X4 belt driven diesel, or kerosene 220 power washer. Pretty good specs, 6hp, 4.8 GPM 1800PSI up to 120-200 degree water temp, set at 130 now. So I get it home, start to tinker on it, change fuel lines, clean fuel tank, and change fuel filter cause owner said it hasnt burned fuel in 3-4 years. Ive already talked to a local service guy about the machine, and the first thing he told me was to look at the vacuum switch....
I decided to take the cover off of the switch to find a rubber grommet had gotten pushed into the housing from an electrician poking a wire in there for a cord, and deciding that was the wrong place to go I guess??? But regardless it freed up the hand plunger on that switch. I decided to fire it up, and boom, it all works, but the burner only works if I mess with that switch, I did a couple things to diagnose the issue, called the tech again, and he told me to check a water screen as that could hinder water flow across the switch. Made sense to me. So tonight Ill see if its the screen or a bad switch. Even if its a switch, that is only 30 bucks, and this particular power washer sold new for almost 9K with the HD pump, and the cart it is on. The paint on the pulleys isnt even worn off, there is a little blackening from the belts, but that is it.. Its still got orange colored paint on the heater water coil!!
To say Im beyond lucky is a huge under statement!!
Free carwashes this summer!!!!!!! come with beer!
LOL
Re: Score of scores!! not a car.... [Re: Moparnut426] #3117974
01/31/23 07:11 PM
01/31/23 07:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Re: Score of scores!! not a car.... [Re: topside] #3118005
01/31/23 10:03 PM
01/31/23 10:03 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Atta boy! Gotta look regularly on marketplace because treasures are out there.
Keep old mopars alive.
Re: Score of scores!! not a car.... [Re: Moparnut426] #3118016
01/31/23 10:51 PM
01/31/23 10:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If it doesn't work out for you I have a REAL nice Hotsy, with very little use, 220v Diesel or kerosene, 220 heat and lot's of pressure. It'll peel paint and as one of my moron employees discovered, insulation on wiring as well spank
I can get the model number and spec's if interested. beer
Re: Score of scores!! not a car.... [Re: TJP] #3118037
02/01/23 12:54 AM
02/01/23 12:54 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I've worked at 2 places that had Hotsy washers in industrial wash bays. I always thought for what they were subjected to they held up really well.
Re: Score of scores!! not a car.... [Re: TJP] #3118266
02/02/23 11:49 AM
02/02/23 11:49 AM
I think I saw yours listed on Facebook. This one works pretty good, Have to vacuum switch off now, and my Father in law is running it up to Orchard for me this monday. hopefully its just this little 45 dollar part to make it work as its designed.
