Angle on the rear axel perch #3117886
01/31/23 12:16 PM
01/31/23 12:16 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Hey folks question for ya. I’m getting the Dana under the Duster and need to know if the angle is the same for S/S springs and the Calverts Mono spring. IIRR stock is 5 degrees? Does that need to change? Also on trial fit the housing needs to be shifted about 1/4” to the passenger side. Is this normal?
Edit, talking about the saddle that’s welded to housing
Re: Angle on the rear axel perch [Re: cudaman1969] #3117912
01/31/23 02:18 PM
01/31/23 02:18 PM
CA
crackedback Offline
crackedback  Offline
CA
5 is correct for stock.
Best to get it loaded at fully weight and set it.
Re: Angle on the rear axel perch [Re: crackedback] #3117918
01/31/23 02:54 PM
01/31/23 02:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Stock angle of the perch is 5 degrees pointing up towards the pinion. I've had luck setting them at 3 up. The best way to get the angle perfect is leave them unwelded, clamp them in the car, mark them, then weld. However if you are building a new housing it's always nice to weld the ends on last in case there are any alignment issues from welding. If it's an existing housing make short 1" welds on th eperches and allow to cool betewwen welds.
Doug
Re: Angle on the rear axel perch [Re: dvw] #3117931
01/31/23 03:24 PM
01/31/23 03:24 PM
fredericksburg,va
fredericksburg,va
Thank you both, what I was thinking also. 9x30 tire fits real good, 1” on front and back, spring is about 1/2 to 5/8 “ from sidewall
Re: Angle on the rear axel perch [Re: cudaman1969] #3117942
01/31/23 04:06 PM
01/31/23 04:06 PM
moparx Offline
moparx  Offline
it's also entirely normal for the side to side measurement to vary up to 3/4" [yes, i have seen three quarters of an inch ! ] from side to side measurements.
1/4 and 3/8" are very common. just the quality control of the era.
also, who knows what has happened to a particular vehicle in the 50-60 years since it was built ?
beer
Re: Angle on the rear axel perch [Re: cudaman1969] #3118021
01/31/23 11:16 PM
01/31/23 11:16 PM
pa
gregcharger72 Offline
pa
the pinion will be need changed the calvert mono leaf is basicly flat where the ss is arched i just did this exact swap. i ordered up a moser fab housing and axle package and had the perch angle set at the stock angle . then installed the cal tracks mono springs . i needed a 4 degree wedge to get the negative three degree pinion angle recommended by calvert. i should have had the pinion angle set on the housing at 0 then i would not need the wedge to correct the pinion angle.
Re: Angle on the rear axel perch [Re: gregcharger72] #3118041
02/01/23 01:20 AM
02/01/23 01:20 AM
fredericksburg,va
fredericksburg,va
Is this a B-Body or A-Body car? Leaning more now to wait for the springs before welding up
Re: Angle on the rear axel perch [Re: cudaman1969] #3118042
02/01/23 01:28 AM
02/01/23 01:28 AM
AndyF Offline
AndyF  Offline
No, the angle is not the same between SS springs and Calvert mono springs. SS springs require a lot of angle while the Calverts are almost flat. You need to mock it up with the car near full weight before you can figure out the perch angle.
Re: Angle on the rear axel perch [Re: cudaman1969] #3118046
02/01/23 04:19 AM
02/01/23 04:19 AM
I wouldn't worry so much about the spring perch angle, I would set the pinion angle compared to the driveshaft at rest with the normal weight you will drive the car with and adjust that angle as needed and then weld the perches on twocents scope weld
Re: Angle on the rear axel perch [Re: Cab_Burge] #3118053
02/01/23 08:18 AM
02/01/23 08:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I agree with the 1/4 panels being off. Now is the time to offfset the housing for clearance. For instance; a 3/4" bigger gap on one side can be corrected by moving the spring perches 3/8" inward on one side and outward on the other. My wifes Challenger was off 5/8"
Doug
Re: Angle on the rear axel perch [Re: cudaman1969] #3118063
02/01/23 09:48 AM
02/01/23 09:48 AM
pa
pa
it is a b body, a 72 charger to be exact. if you are not impatient like me, it will be less work to wait. LOL
Re: Angle on the rear axel perch [Re: gregcharger72] #3118064
02/01/23 09:58 AM
02/01/23 09:58 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
what ever happened to quicktree .. ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Angle on the rear axel perch [Re: gregcharger72] #3118085
02/01/23 11:36 AM
02/01/23 11:36 AM
fredericksburg,va
fredericksburg,va
I will wait, for now getting tires in right spot for clearance. Now I’ll do the T alignment (chalk lines and plumb bob) on floor to get the axel square to body
Re: Angle on the rear axel perch [Re: bigdad] #3118133
02/01/23 03:45 PM
02/01/23 03:45 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
haha
Re: Angle on the rear axel perch [Re: JohnRR] #3118230
02/02/23 08:07 AM
02/02/23 08:07 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
haha
x2, I miss a lively pinion angle debate!
I just put caltracs and split monos on my car, Calvert's instructions said between 2-4* nose down in relation to the trans. I put a 4* shim on it and it ended up where I needed to be, but now I'm probably replacing the rearend so I'll have to redo it all.
