One way screen for windage tray
#3117105
01/27/23 04:23 PM
01/27/23 04:23 PM
Posts: 553 Kentucky
clovis
Kentucky
I see where you can buy the screen from Summit or Jeg's for $65 but was curious if there was an Amazon option someone has used with success. Does it have to be one way? https://www.jegs.com/i/Moroso/710/2...X6Mno_AIV5xbUAR0XxgS9EAQYAiABEgKQ8_D_BwE
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: One way screen for windage tray
[Re: clovis]
#3117129
01/27/23 06:18 PM
01/27/23 06:18 PM
Posts: 4,206 New York
polyspheric
New York
if there was an Amazon option someone has used with success Not that I know of
if there was an Amazon option someone has used with success. Does it have to be one way? Yes
Boffin Emeritus
[Re: gearhead01]
#3117199
01/28/23 12:34 AM
01/28/23 12:34 AM
Posts: 11,570 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Expanded metal and perforated metal are not the same thing.
Lots of options on the internet. Thickness, holesize, flattened or raised,cut size. Do you know these things if you are trying to match the Moroso stuff? Prices I see at McMaster and other places would make me just get the Moroso stuff if you just need it for one pan.
Otherwise, I would still want to have a piece of the correct stuff to measure, so I know exactly what I'm looking for.
[Re: clovis]
#3117309
01/28/23 04:48 PM
01/28/23 04:48 PM
polyspheric
New York
The one-way effect is to permit oil in the screen to drain (almost) normally, but frustrate oil flung up by the crank from passing through the wrong way. A hole formed with a punch makes a funnel shape with concave sides, the lip protrudes underneath.
Boffin Emeritus
[Re: polyspheric]
#3117330
01/28/23 07:27 PM
01/28/23 07:27 PM
Posts: 553 Kentucky
clovis
Kentucky
Looking to do something like what is pictured. What is pictured looks more like a woven mesh that punched. Just didn’t know if there was a size of mesh that allowed dropped oil through easily but resisted oil being sucked up from the crank.
[Re: clovis]
#3117406
01/29/23 12:34 AM
01/29/23 12:34 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The raised expanded metal screen is directional. It has many little scrapers edges with drain holes. Not effective if installed wrong.
