Picture of Original Clutch Fork Adjust Linkage/Rod #311599
05/08/09 11:58 AM
05/08/09 11:58 AM
Anonymous OP
Anonymous OP
Could someone post a picture of what the original '70 E Body clutch fork adjust rod,nut,beveled spacer,etc look like?I know the Mopar Performace kit works,but some of the parts are different I think.Thanks !!
Re: Picture of Original Clutch Fork Adjust Linkage/Rod #311600
05/08/09 09:34 PM
05/08/09 09:34 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
I'm interested too.The original had a type of machined rounded end ball that slide over the adjustment rod,but beyond that I am not sure.I'd like to see a original/correct set up also.Anybody?
Re: Picture of Original Clutch Fork Adjust Linkage/Rod [Re: 44D6PAKCUDA] #311601
05/08/09 10:55 PM
05/08/09 10:55 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Hey Jim,
I put an NOS original in my Charger. To bad I didn't take a pic of it before I did that. The ones from Mopar will work , but there are slight differences. The convex washer and hard black rubber spacer that Mopar still sells are 100% correct. I have seen that ball socket looking thing before and it is likely a truck part.
Re: Picture of Original Clutch Fork Adjust Linkage/Rod [Re: hemi70se] #311602
05/08/09 11:04 PM
05/08/09 11:04 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Here is a pic of a used original (bottom) and a new MP one (top). An original has a slight hockey stick type bend to it whereas the MP one is perfectly straight. I made the mistake of trying to put a bend into an MP one and it broke, so be careful if you try.
Re: Picture of Original Clutch Fork Adjust Linkage/Rod [Re: hemi70se] #311603
05/08/09 11:05 PM
05/08/09 11:05 PM
Lebanon CT.
moparjoe4406 Offline
Joe the plumber
Joe the plumber
Lebanon CT.
The newer Year One catalog has a good detail picture of the clutch fork.
Re: Picture of Original Clutch Fork Adjust Linkage/Rod [Re: moparjoe4406] #311604
05/08/09 11:23 PM
05/08/09 11:23 PM
Cleveland, OH
TWS Offline
TWS  Offline
Cleveland, OH
