Re: W9 Small Block - Quest for the 9's
[Re: Moparrob68]
#3115007
01/20/23 10:25 PM
01/20/23 10:25 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I talked to Dom at Thumper carbs the other night. He said that he could build a 1000ish 4150 BLP based carb for this manifold. Would we be better off building a 1050 Dominator with adaptor and have the option to open up the manifold to 4500 opening later? To take full advantage of a Dominator I'd either buy another intake or modify mine to a Dominator flange. When I was planning my 434 I talked to Brett a couple times on the phone, his advice was that if I was going to run a 4150 intake to run a 4150 carb, not an adapter and a Dominator. This is the carb Dom built me, I already had the main body, so I sent it to him, and he built me a carb.
[Re: Moparrob68]
#3115021
01/20/23 11:12 PM
01/20/23 11:12 PM
Posts: 4,208 New York
polyspheric
New York
I really don't understand all the sharp edges in the pix of chamber, air horn etc. Anything wider than 15° transition "trips" flow; the cure is a small radius, up to 3/8".
Boffin Emeritus
[Re: polyspheric]
#3115080
01/21/23 11:04 AM
01/21/23 11:04 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I'm sure you're really frustrated/disapointed in the results. But you have a lot of good pieces there that you're absolutely right the car should be way into the 9's.
130mph @ 3275 is only showing about 550hp at the crank. Could the carb or converter be better/different? Sure. Is it going to pick up the 150hp+ that missing? I highly doubt it.
It seems that there is something more majorly wrong... I would start with the basics.
1) Is the Throttle all the way open. I know that's a dumb thing, but certainly done it, and seen others do it before. 2) Do a leak down on all 8 cylinders. Maybe it tagged a valve or two on accident. 3) How close is the carb to the scoop? Is it sealed to the carb? You might want to try either running the car without the spacer to get more room for the air to make the turn, or without the hood completely as a trial. 4) Calculate the converter slip at the stripe. What RPM is it crossing the line at (needs to be a very accurate number to do this, you can' guess). That will at least give you one piece of info on the "health" of the converter. 5) Is the timing curve stable (any chance this thing has a programable MSD that could accidentally have a wonky curve in it?) 6) Try sweeping the timing a little further. In my experience moving timing around, if 1 degree moved the car a full tenth, it's WAY off. It's possible it wants more, but maybe didn't have enough octane in it? (grasping at straws a big here). 7) Have you tried different fuel all together? I've seen a bad batch and or wrong octane really hurt power on occasion.
Obviously its a major pain in the ass as a last resort to yank the motor and dyno it. But if you do get to that point, at least you'll know if you should be chasing the motor or the car once you see a dyno sheet.
[Re: Moparrob68]
#3115114
01/21/23 12:57 PM
01/21/23 12:57 PM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Man I just looked your slips over again and man you gotta have a few issues going on. My sons duster that weights 3200 pounds ran 10.11 with my old 408 that I pulled out for its fourth rebuild. This was at keystone in summer heat. Edelbrock headed 408 with around 11.1 compression, 650 lift roller cam, 750 alcohol carb, 727 with 4.10 gears, 5600 stall. Shifting at 6700-6800 rpm. With his old stock crank 360 that ran 10’s he gained .5 going from a 4600 stall to a 5600 stall.
[Re: Moparrob68]
#3115116
01/21/23 01:03 PM
01/21/23 01:03 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Through the years I have dyno tested several engines that came out of cars with very similar stories.
It was almost 100% of them making noticeably less power than expected......... and the car running on par with the results from the dyno test. I can think of a couple where the owners each spent several thousands on parts for the car in an attempt to find the missing ET.
The other side of that story is....... one of my friends had a converter fail on his S/G car. Bought a new high dollar unit from a big name supplier. Car was waaaay down everywhere. Sent it back, they adjusted it...... no change. This happened several times. Everything was off. 60’, ET, Speed. Had this been a new untested combo........ we would have suspected the combo was just off. But the car had run way better for years previously, and ran what it “should” have.
Eventually, a converter was sourced from a different supplier, and the 60’ and ET came back. Speed was still down........new converter had enough slippage that the engine was on the limiter before the finish line. With the original converter, the speed was up 4mph and the engine never touched the limiter.
My suggestion is to dyno the engine. At least then you’ll have the info needed to know what the car “should” run.
Two comments about what I see.......
Nowhere near enough stall(5000)
Looks like the bump steer situation really could use some attention
[Re: Moparrob68]
#3115154
01/21/23 02:56 PM
01/21/23 02:56 PM
polyspheric
New York
Do you have a CCP reading? Tell me your intake closing @ nominal ABDC (not .050") and rod length (4.00" stroke, 13.2 static CR), and I'll try to predict it.
Boffin Emeritus
[Re: Moparrob68]
#3115517
01/22/23 08:31 PM
01/22/23 08:31 PM
Posts: 1,559 New Smyrna Beach FL
scottb
New Smyrna Beach FL
My old W9 motor was 14.1 roller was a little bigger with a 1250 APD carb 456 gear 6500 converter went 117 in the 1/8 so your down on power somewhere are the pistons a dome or flat top with the small chamber heads good luck with your new combo after rereading your post I see your using a dish piston my brother I’ll law ran the same piston in his W8 motor the car ran good but never like it should have when he started to look the motor over again he came up with maybe 10-1 compression not 12.5 like he was told
[Re: Dragula]
#3115702
01/23/23 02:58 PM
01/23/23 02:58 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Hey Rob,
Something to think about. Earlier in the thread there was mention of combustion chamber efficiency/shape effecting timing. My 416 liked 29 degrees of timing on the dyno with my Brodix B1-BA heads anything over 31 degrees the HP really fell off. Worth a try.
Also about the Innovate unit I have. The new LM-2 "Basic" Kit (Single Wideband O2) ONLY includes the LM-2 meter, Bosch wide-band oxygen sensor, 8 ft sensor cable, cigarette-lighter power adapter, USB cable for PC connection, weld-in bung and plug ,and manual. *Note: The LM-2 "Basic" Kit out of the box only includes accessories to display your Air/Fuel Ratio either on the meter and/or on your PC. To log RPM, or to Output the wideband signal to an external device you'll need the LM-2 Analog IN/OUT Cable (P/N: 3811) optional accessory. For OBD-II features you'll need the LM-2 OBD-II Cable (P/N: 3809) optional accessory. To record internally to your LM-2 you'll need the SD Card (P/N: 3787) optional accessory. This unit also comes in a cardboard box, the black hard case is an optional accessory LM-2 Carrying Case (P/N: 3836)*
KEY FEATURES 100 pct. Digital Wideband Air/Fuel Ratio Technology Built-In RPM Converter [Direct Freq. or w/Opt. Inductive Clamp] Large High-Contrast Graphics LCD Log Directly To SD Card OBDII Scan Tool-Read/Clear DTCs and Log Up to 16 Channels Patented DirectDigital™ Wideband Sensor Control Playback Log Data On Screen And/Or w/Powerful LogWorks Software Single or Dual Channel A/F Version Available Wideband O2 Compatible w/All Fuel Types
[Re: Dragula]
#3115931
01/24/23 09:16 AM
01/24/23 09:16 AM
Posts: 13,198 aZLiViN
J_BODY
aZLiViN
Rob,
I can lend you that 1250 I have....Maybe the carb IS suffocating it. Considering I did my first hits using an ancient BG 750 and ran 9.6s short shifting I’d be amazed if the carb swap did anything for it. I ran a 598/4150 intake for years with a carb 1.48 venturi 1.79 throttle blade. We were pretty much 9.4-9.5 anywhere we’d go. On a heads up challenge race we entered I decided to try the old 4500/1050 we used on our W5 mill so I matched the 2” adapter to the intake and went to the track finding out we gained pretty much nothing and actually the 60 slowed over time slips from the previous visits. It’s unfortunate that I changed intakes and carb the same time I went from my 727 to 904 because it really picked up across the board. It’s now pretty much a 9.2 car but we’ve gone 9.09. Just shy of needing a chute.
[Re: dvw]
#3115932
01/24/23 09:20 AM
01/24/23 09:20 AM
J_BODY
aZLiViN
These two runs with 165lbs of ballast. After the 2nd run we discovered a broken converter. The 1st pass was quicker than we had anticpated. We were trying to slow to 9.25 index. One pass killed it. Doug
Doug I’d FREAK the **** out if I lost that much on one pass….. I’d definitely be thinking “engine” issue off the top of my head.
