Re: 5/16 fuel line on mild 440
[Re: Nick Mineau]
#311374
05/07/09 11:47 PM
05/07/09 11:47 PM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
Try it,if not put a Carter elec. fuel pump on it to push it through.
'71 383HP FJ6 Charger SE
[Re: 1_WILD_RT]
#311379
05/08/09 12:24 AM
05/08/09 12:24 AM
Posts: 350 CT USA
Nick Mineau
CT USA
thanks for the history. that is exactly what i was looking for
[Re: Nick Mineau]
#311380
05/08/09 03:11 AM
05/08/09 03:11 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
My sons .030 over 400 Dart still has the factory 5/16 line and has run 11.40's at 117 with no problems. Should be fine. Ron
[Re: dOc …]
#311382
05/08/09 08:04 AM
05/08/09 08:04 AM
Posts: 4,924 new berlin wisconsin
Mr T2U
i have a buddy who has a 07 mustang that makes 800hp at the rear wheels. he has the stock 5/16" fuel lines and pump. then again newer mustangs have high pressure pumps. his best time is a 10.2 @ 139 mph
perception is 90% of reality
[Re: 1_WILD_RT]
#311383
05/08/09 08:36 AM
05/08/09 08:36 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
The A12 cars (69 440-6) only had a 5/16 line, no problem...
no problems...seem 440-6 cars run 11.80's w/ them.
[Re: Crizila]
#311385
05/08/09 09:53 AM
05/08/09 09:53 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I know my 67 B-body 440 cars have the 3/8 fuel pump over the non BB cars 5/16th pump. I have never measured the fuel line, but I would guess it is 3/8 not 5/16.. However, like everyone has said here before me, you will have no problems running 5/16 line.
RS23L7 4-Speed
[Re: Mopar_Mike]
#311386
05/08/09 10:24 AM
05/08/09 10:24 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
if you need more fuel, you could run an electric pump and get more pressure, then step it down with a regulator at the carb, using 3/8 from the reg to the carb, and you should be ok that way too.
**Photobucket sucks**
