Re: msd ignition
[Re: cornet684me]
#311306
05/07/09 10:11 PM
05/07/09 10:11 PM
Posts: 20,213 Park Forest, IL
slantzilla
Park Forest, IL
MSD's website has instructions for all their products you can download.
Re: msd ignition
[Re: cornet684me]
#311308
05/07/09 10:29 PM
05/07/09 10:29 PM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
ok, i have the diagram, now i have a stupid question, it shows the connector to the dist. hookup, the white not used, the red to the positive on the coil, the orange to the ground of the coil, and a 12volt wire coming from the ignition to the postitive on the coil and i am done, my question is what happens to the ballastor, what happens to the voltage regulator? and the ecu box, do i take all this off when i put the MSD 5900 blaster on car? ![](/ubbthreads/images/graemlins/grin.gif) :
Re: msd ignition
[Re: FrankenScamp]
#311311
05/08/09 08:12 AM
05/08/09 08:12 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
when installing MSD with a stock harness. a good place to hook up the key power, small red wire, is to the blue or brown wires leading to the ballast. then jump the blue wire to the brown. the blue wire has power at the key on position. the brown has power at the key start position. when hooked together you will have power at all times the key is turned on.
perception is 90% of reality
Re: msd ignition
[Re: HealthServices]
#311315
05/08/09 03:01 PM
05/08/09 03:01 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Are you wiring this under the hood or under the dash?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
Re: msd ignition
[Re: cornet684me]
#311317
05/08/09 11:58 PM
05/08/09 11:58 PM
Posts: 7,759 So Cal
HealthServices
So Cal
If you do not disconnect the wires from the resistor you can grab either the Blue with the tracer or the Brown wire from the ignition switch. These wires lead from the ignition switch to the middle of the bulkhead at the firewall. Now remember this, if you remove the wires from the resistor you must connect the Blue with the tracer or the Brown wire together. Otherwise the motor will fire up only when cranking or only when you let go of the ignition switch. Not both. ![](http://i69.photobucket.com/albums/i69/bluemandm/mopar/th_69RRignitionB14-1.jpg) Notice these wires do not go to the fuse box.
Allen
