Big Block Edelbrock RPM Valve Stem Diameter?
#3112413
01/16/23 09:50 AM
01/16/23 09:50 AM
Posts: 32 Pennsylvania
19_Dart_68
Pennsylvania
The Edelbrock website says .3438" ...What are they in 'Merican fraction size? Is that 11/32" ?
TIA
68 Dart - 440 Swap in Progress...please stand by
Re: Big Block Edelbrock RPM Valve Stem Diameter?
[Re: lewtot184]
#3112439
01/16/23 11:05 AM
01/16/23 11:05 AM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The “actual” measured size for Ede valves is a nominal .3405”
[Re: Stanton]
#3112482
01/16/23 12:27 PM
01/16/23 12:27 PM
19_Dart_68
Pennsylvania
Let's see ... one divided by thirty-two multiplied by eleven ... what's that give you ??
OR
Google: display .3438 as a fraction 11 divided by 32
