Re: recommend me a quality street/strip converter
[Re: mxbeep]
#3111964
01/14/23 08:24 PM
01/14/23 08:24 PM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
I use and recommend Ultimate Converter Concepts 843-264-5448
[Re: AndyF]
#3111973
01/14/23 09:05 PM
01/14/23 09:05 PM
11secdart
new jersey usa
Turbo - Action is also very good .. both my 8 inch converters were originally made by them .. redone for my combo by Ultimate . I have T/A valve bodies in my 904s and their shifter
[Re: mxbeep]
#3112026
01/15/23 12:03 AM
01/15/23 12:03 AM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
I ran a Hughes 3000 stall behind a 440 in a 67 Dart, and was happy with it. I got it via Summit. Besides the price (it was a long time ago but back then was one of the lower priced options), and ability to use coupons to make the price even lower, Summit (at least for me) has always provided great customer service should anything go wrong. My dad has a 2500 stall Hughes behind his 440 and it's been fine too. We're not racing and haven't compared to others, but they drive well on the street and are plenty fast when called on. I've also run an Edge racing out of Florida that I got on ebay, 3800 stall. Other than higher stall speed, they are all the same in terms of being problem free for street driving and occasional blasts.
For my most recent, though still about 5 years ago, I got a Dynamic converter. Pretty sure it was around the 600 range for a 4200 stall 9.5" back then.
[Re: mxbeep]
#3112029
01/15/23 12:23 AM
01/15/23 12:23 AM
Posts: 3,243 Md.
carnut68
Md.
I'm running an 8 in ATI works great.
America First!
[Re: Cab_Burge]
#3112045
01/15/23 07:14 AM
01/15/23 07:14 AM
Posts: 8,033 Tulsa OK
Bad340fish
Tulsa OK
Been real happy with my Turbo Action 8" converters. My car is street driven and has been all over the country with an 8" TA that flashes 6400 in my fat A body.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3112083
01/15/23 11:12 AM
01/15/23 11:12 AM
Posts: 4,579 Motor City
6PKRTSE
Motor City
I have PTC converters in three of my cars. I am happy with all of them. All street friendly for cruisin and flash where expected at the strip. I have a 9" 5600 in my Challenger, a 10" 4000 in my Roached Runner and a 10" 3600 in my Charger.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: mxbeep]
#3112089
01/15/23 11:32 AM
01/15/23 11:32 AM
Posts: 12,243 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
searching for a quality street/strip torque converter, not looking to cut corners or cheap out, which brands need to be avoided and which are recommended.
going into a well built 727 behind a 512ci A-body with 3.55's, 28 inch rear tires, 3000 to 6000 rpm range. i'm considering a 3000 rpm stall speed, your opinions?
thanks Getting a converter to flash as much as you want with your combo will be no problem. And getting an efficient converter is not hard either. The biggest problem with converters on a street combo like yours is getting a converter that doesn't drive like a weak clutch on the street. 3.55s behind your high torque engine will mean that with any throttle on street pavement, you are either gonna hit the tires hard enough to not go anywhere, or flash the converter up. The comfort zone on this is a matter of personal preference. Many guys lean towards the race feel of these converters just like they are okay with big bumpy cams. But the more a guy wants a stock feel to the car on the street, the harder it becomes to get a converter tight enough. I have struggled with this for years. First with the 500 wedge and then with the 540 Hemi. With light throttle, the converters would move the car out just fine. But if I crowded it, they would usually flash to 4,000+. PTC was my go-to builder. I talked to them and others about this and they said the problem was that there just weren't any cores big enough to hold our big torque combos down. After several converters and many conversations, I ended up sending my PTC converter (which they had tried twice to get where I wanted it) to Lenny at UCC. In the end, Lenny said that there was a limit of how tight they could build converters for this application because there just aren't the cores and parts to do it. What he did was to tweak what I already had (no real secrets or anything) and told me to run a BIG cooler to keep the fluid as cool as possible to maintain as much viscosity as possible. The final piece of advice from him was for me to run John Deere Hy-Guard summer fluid with just a touch of ATF to give it some color. He said that most hydraulic fluids are a compromise on viscosity with only one grade. JD's summer is a higher viscosity and as you know thicker fluid lowers the flash and 'tightens' the converter overall. As a result, the car is much tighter around town. At low speeds, I can crack the throttle and the car lurches forward much more like the OE stuff did. Not as tight as OE, but noticeable better than before and maybe as good as I can get. In that 1,500 to 3,500 RPM range where we spend a lot of time in casual driving, the car just feels crisper and more responsive to the throttle. You did not say how you were looking for the car to drive around town, so this may not even matter to you. And most discussions are centered on flash and stall and such. But those do not really tell the tale of how the converter feels down low when tooling around town. Getting a converter for your combo to do almost anything you want is not a problem. Except for getting a tight, crisp feel down low. Again, this is all a matter of personal comfort and preference. Not a matter of right and wrong. I was just hoping to show a side of this that is often not discussed. In case it matters.
Master, again and still
[Re: DaveRS23]
#3112093
01/15/23 11:41 AM
01/15/23 11:41 AM
Posts: 1,624 qc
mxbeep
qc
thanks Getting a converter to flash as much as you want with your combo will be no problem. And getting an efficient converter is not hard either. The biggest problem with converters on a street combo like yours is getting a converter that doesn't drive like a weak clutch on the street. 3.55s behind your high torque engine will mean that with any throttle on street pavement, you are either gonna hit the tires hard enough to not go anywhere, or flash the converter up. The comfort zone on this is a matter of personal preference. Many guys lean towards the race feel of these converters just like they are okay with big bumpy cams. But the more a guy wants a stock feel to the car on the street, the harder it becomes to get a converter tight enough. I have struggled with this for years. First with the 500 wedge and then with the 540 Hemi. With light throttle, the converters would move the car out just fine. But if I crowded it, they would usually flash to 4,000+. PTC was my go-to builder. I talked to them and others about this and they said the problem was that there just weren't any cores big enough to hold our big torque combos down. After several converters and many conversations, I ended up sending my PTC converter (which they had tried twice to get where I wanted it) to Lenny at UCC. In the end, Lenny said that there was a limit of how tight they could build converters for this application because there just aren't the cores and parts to do it. What he did was to tweak what I already had (no real secrets or anything) and told me to run a BIG cooler to keep the fluid as cool as possible to maintain as much viscosity as possible. The final piece of advice from him was for me to run John Deere Hy-Guard summer fluid with just a touch of ATF to give it some color. He said that most hydraulic fluids are a compromise on viscosity with only one grade. JD's summer is a higher viscosity and as you know thicker fluid lowers the flash and 'tightens' the converter overall. As a result, the car is much tighter around town. At low speeds, I can crack the throttle and the car lurches forward much more like the OE stuff did. Not as tight as OE, but noticeable better than before and maybe as good as I can get. In that 1,500 to 3,500 RPM range where we spend a lot of time in casual driving, the car just feels crisper and more responsive to the throttle. You did not say how you were looking for the car to drive around town, so this may not even matter to you. And most discussions are centered on flash and stall and such. But those do not really tell the tale of how the converter feels down low when tooling around town. Getting a converter for your combo to do almost anything you want is not a problem. Except for getting a tight, crisp feel down low. Again, this is all a matter of personal comfort and preference. Not a matter of right and wrong. I was just hoping to show a side of this that is often not discussed. In case it matters. thanks fornyour detailed response, i ahgree with you 100% and plan on having the same struggles, i also am looking for a fairly ''tight'' converter that i can drive around town or the highway at 2400-2600 rpm without slipping
[Re: DaveRS23]
#3112104
01/15/23 12:12 PM
01/15/23 12:12 PM
Posts: 1,765 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
...The biggest problem with converters on a street combo like yours is getting a converter that doesn't drive like a weak clutch on the street. 3.55s behind your high torque engine will mean that with any throttle on street pavement, you are either gonna hit the tires hard enough to not go anywhere, or flash the converter up. ... I have struggled with this for years. First with the 500 wedge and then with the 540 Hemi. With light throttle, the converters would move the car out just fine. But if I crowded it, they would usually flash to 4,000+. ... Lenny at UCC. ... In the end, ...final piece of advice from him was for me to run John Deere Hy-Guard summer fluid with just a touch of ATF to give it some color. He said that most hydraulic fluids are a compromise on viscosity with only one grade. JD's summer is a higher viscosity and as you know thicker fluid lowers the flash and 'tightens' the converter overall... This is a superb explanation and highlights the key points of what us the street (90-95%) and strip (5% at best lol) folks face. I have read a number of references to the John Deere fluid...can you provide more specifics as to what you use? My 9.5" 4k stall Dynamic is a great WOT piece and actually feels pretty nice on the street as well...but the throttle crispness I felt with the previous 2800 stall is long gone...wouldn't mind some of that back...and a fluid change is a worthy (and a fairly inexpensive) experiment!
