71 Charger Brake pedal "sticks"
#311140
05/07/09 08:16 PM
05/07/09 08:16 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
I have a 71 Charger SE with power disc front brakes and the pedal stays down when applied. I have to use my foot to "Lift up" on the pedal to release brakes, and more notably, it seems the rear wheels stick more than the front. There is no air leaks or noises from the power booster and she stops firmly. I bought this car last year and it was sitting in a garage for mostly over the past few years. I'm thinking rear brake cylinders... Anyone Experience these symptoms before? Many thanks!
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: 71 Charger Brake pedal "sticks"
[Re: 71 FJ6 Charger]
#311144
05/08/09 09:36 AM
05/08/09 09:36 AM
RapidRobert
split the booster/M/C & pull the M/C forward a bit & hit the pedal again. this will tell you which one is acting up(& might check the pushrod clearance while you are in there)
[Re: Crizila]
#311147
05/08/09 12:43 PM
05/08/09 12:43 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
my brake booster does have a spring what does help on get the diaphragm to rest position inside. I guess would return the pedal back too. WHAT ABOUT THAT ?
The rod what push the master cilinders pistons is not FIXED or bolted or whatever to the pistons so even with stuck master cilinder, the rod should get out to rest position I think, by this spring
[Re: NachoRT74]
#311148
05/08/09 12:46 PM
05/08/09 12:46 PM
NachoRT74
Valencia, España
PLUS Booster rods, front and rear, ( and rest of linkage ) are able to get stuck if they are dirty or rusty... some grease to seals/rods will help.
