71 Charger Brake pedal "sticks" #311140
05/07/09 08:16 PM
05/07/09 08:16 PM
S.E. Conn
Hoof Hearted Offline OP
S.E. Conn
I have a 71 Charger SE with power disc front brakes and the pedal stays down when applied.
I have to use my foot to "Lift up" on the pedal to release brakes, and more notably, it seems the rear wheels stick more than the front.
There is no air leaks or noises from the power booster and she stops firmly.
I bought this car last year and it was sitting in a garage for mostly over the past few years.
I'm thinking rear brake cylinders...
Anyone Experience these symptoms before?
Many thanks!
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: 71 Charger Brake pedal "sticks" [Re: Hoof Hearted] #311141
05/07/09 09:12 PM
05/07/09 09:12 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I had that problem once years ago with a 71 Duster, pedal sagged and wouldn't return on its own. Turned out to be a bad master cylinder.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 71 Charger Brake pedal "sticks" [Re: GO_Fish] #311142
05/07/09 09:23 PM
05/07/09 09:23 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I would bet your linkage and bushings need cleaning, regreasing, and/or replacement of the bushings.... the grease gets hard.. did on mine..
Re: 71 Charger Brake pedal "sticks" [Re: GO_Fish] #311143
05/07/09 11:50 PM
05/07/09 11:50 PM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
This was my problem.
'71 383HP FJ6 Charger SE
Re: 71 Charger Brake pedal "sticks" [Re: 71 FJ6 Charger] #311144
05/08/09 09:36 AM
05/08/09 09:36 AM
split the booster/M/C & pull the M/C forward a bit & hit the pedal again. this will tell you which one is acting up(& might check the pushrod clearance while you are in there)
Re: 71 Charger Brake pedal "sticks" [Re: Hoof Hearted] #311145
05/08/09 10:55 AM
05/08/09 10:55 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
In my experience a sticking brake pedal is usually caused by rust in the master cylinder.
Re: 71 Charger Brake pedal "sticks" [Re: 71 FJ6 Charger] #311146
05/08/09 12:10 PM
05/08/09 12:10 PM
Az
Crizila Offline
Crizila  Offline
Az
and when the pedal doesn't return fluid can't get back in to the master resevoir because the compinsator ports stay closed.
Fastest 300
Re: 71 Charger Brake pedal "sticks" [Re: Crizila] #311147
05/08/09 12:43 PM
05/08/09 12:43 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
my brake booster does have a spring what does help on get the diaphragm to rest position inside. I guess would return the pedal back too. WHAT ABOUT THAT ?
The rod what push the master cilinders pistons is not FIXED or bolted or whatever to the pistons so even with stuck master cilinder, the rod should get out to rest position I think, by this spring
Re: 71 Charger Brake pedal "sticks" [Re: NachoRT74] #311148
05/08/09 12:46 PM
05/08/09 12:46 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
PLUS Booster rods, front and rear, ( and rest of linkage ) are able to get stuck if they are dirty or rusty... some grease to seals/rods will help.
Re: 71 Charger Brake pedal "sticks" [Re: NachoRT74] #311149
05/08/09 10:28 PM
05/08/09 10:28 PM
S.E. Conn
S.E. Conn
Thanks, Thanks and more thanks! Keep the experienced advice comming!
Gotta love Moparts!
2005 300C Hemi
