Terminal Relocation kit - Big Block with mini starter #3111109
01/12/23 09:55 AM
01/12/23 09:55 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I have this kit shown in the picture but it's not really what I need primarily because my battery is located in the trunk so my hot cable comes in from the front side of the starter.
What is everyone using to safely relocate these terminals so that the cables are safely away from each other and also the engine block ?
Re: Terminal Relocation kit - Big Block with mini starter [Re: lostdog] #3111128
01/12/23 10:56 AM
01/12/23 10:56 AM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
Our minis we installed we just trimmed a bit off the large terminal Small one was ok.Mines been on since 2000 My kids on the 413 was on for a good 12 years when he sold it.
Chrysler Firepower
Re: Terminal Relocation kit - Big Block with mini starter [Re: therocks] #3111131
01/12/23 11:06 AM
01/12/23 11:06 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Just ground the studs down a bit to make them shorter. After that they cleared the block fine on my 440 with headers.
That adapter is a cool piece. But those studs are WAY longer than they need to be, for example.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Terminal Relocation kit - Big Block with mini starter [Re: wingman] #3111195
01/12/23 02:16 PM
01/12/23 02:16 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I need the stud length because I have power feed from the trunk going to starter then one feed from starter to my relay. Once I had it all bolted up i stuck a pry bar in there and bent it down a little for clearance
On the trigger wire, I turned the pole upside down which means I had to tighten the nut from the bottom, but it seems fine I may not ever be satisfied with how it looks but as long as it's tight I'll probably just leave it as is
Re: Terminal Relocation kit - Big Block with mini starter [Re: lostdog] #3111211
01/12/23 02:36 PM
01/12/23 02:36 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I don't know if there is a variance between manufacturers buy a few of the new starters that I have owned had a bolt on extension. I simply removed it since the extensions are what made contact with the block. The terminals are then directly on the starter body itself.
Re: Terminal Relocation kit - Big Block with mini starter [Re: Kern Dog] #3111282
01/12/23 05:14 PM
01/12/23 05:14 PM
Alabama
W
WarEagle1 Offline
WarEagle1  Offline
W
Alabama
Powermaster makes a version with the lug positions swapped (large lug farther away from block). This really helped me when using with a MP 4.5" bore RB block. High torque (they're kinda proud of em though).
Not sure if that helps your situation, but thought I'd chime in.
Re: Terminal Relocation kit - Big Block with mini starter [Re: lostdog] #3111464
01/13/23 08:22 AM
01/13/23 08:22 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Stop the power feed at he firewall with this bulkhead. Then all power can come from it instead of the starter. Much easier and cleaner connection at the starter. Look by the column in the pic.
https://www.summitracing.com/parts/sum-g1431-red?seid=srese1&gclid=EAIaIQobChMI0ZC898PE_AIVyAtMCh1pJwcOEAQYASABEgKxxvD_BwE#:~:text=Search%20by%20Make/Model,Connectors%20SUM%2DG1431%2DRED
Doug
Re: Terminal Relocation kit - Big Block with mini starter [Re: dvw] #3111645
01/13/23 03:36 PM
01/13/23 03:36 PM
The starter draws the most amps when spinning the motor over so make sure you're feeding it with a big enough cable to not restrict the current flow work
I like and use #2 gauge to the starter from the battery. up
Re: Terminal Relocation kit - Big Block with mini starter [Re: dvw] #3111669
01/13/23 04:34 PM
01/13/23 04:34 PM
moparx Offline
moparx  Offline
i agree with Cab. don't skimp on cable size.
also, if making up a cable, use quality ends that you can positively [biggrin] ensure are connected to the cable well.
and above all, do NOT use those [temporary] "bolt on" battery terminal ends !
beer
