Re: Flagship One PCM ?
[Re: GarageDodge]
#3110896
01/11/23 04:30 PM
01/11/23 04:30 PM
Posts: 20,753 A collage of whims
topside
A collage of whims
Thanks, ordered one from them, fingers crossed.
As for the junk one from All Computer, FWIW: Their "support" guy deflects my questions/concerns, won't respond to the photos sent, basically a stone wall. 4 days of getting jerked around. So, I'm sending their unit back & disputing the charge to my card. This is what I received: does it look remanufactured to you guys ? Dirty, including contacts, was bead-blasted at some point before oil stain...
[Re: topside]
#3110946
01/11/23 07:21 PM
01/11/23 07:21 PM
Posts: 476 Central NY
GarageDodge
Central NY
Yea their are a couple other places that do that also,and yes it don't look rebuilt.I have had good luck with solo computers out of florida,i did have to send a couple back because they set internal failure codes,but they took care of it.I buy from flagshipone,because their closer&i haven't had any problems.
I
[Re: GarageDodge]
#3111033
01/11/23 11:47 PM
01/11/23 11:47 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I used Flagship 1 for my sons ‘06 Lincoln Zephyr and it works fine. I took achance, as I did research and did see a mix of good and bad reviews. It came in a nice wrappedbag, and it looked pretty nice from what I could see. They are about 10 minutes away from where I live. My good friend needed a pcm from his 94 jeep cherokee. I recommended them to him, and after he went there, he didn’t like the feeling he got so he cancelled his order with them and got one elsewhere. Totally different experience than I had. I can only say positive things about them based on my dealings snd results with them.
