Re: Any guesses on Horsepower before the dyno?
[Re: hudsonhornet7x]
#3110554
01/10/23 11:51 AM
01/10/23 11:51 AM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
Good luck, Sounds like a screamer. Wish I knew first hand but I have no idea.
Rich H.
Esse Quam Videri
#3110559
01/10/23 12:16 PM
01/10/23 12:16 PM
Posts: 16,929 NC
440Jim
NC
Trick Flow 270 heads with Harland sharp rockers( 1.5 ratio)
Trick flow intake port matched to the 270 heads. Can you post any pictures and/or info on the port matching? I believe the 270 heads are MaxWedge (1.34 x 2.63/2.65) openings, and the intake is originally std port opening ( about 1.26 x 2.30).
#3110580
01/10/23 01:27 PM
01/10/23 01:27 PM
Posts: 43,263 Bend,OR USA
Cab_Burge
550 to 575 at or around 5800 RPM. Did you degree the cam? If so where is the intake lobe center installed in relation to TDC? I'm thinking it may make more torque than HP with that compression ratio, maybe not. All the pump gas motors I've built and dyno that had less than 10.5 to 1 comp. ratio made more torque than HP, above 10.5 to 1 made more HP than torque Let us know what yours does please
[Re: Cab_Burge]
#3110583
01/10/23 01:34 PM
01/10/23 01:34 PM
Posts: 1,543 USA
hudsonhornet7x
USA
550 to 575 at or around 5800 RPM. Did you degree the cam? If so where is the intake lobe center installed in relation to TDC? I'm thinking it may make more torque than HP with that compression ratio, maybe not. All the pump gas motors I've built and dyno that had less than 10.5 to 1 comp. ratio made more torque than HP, above 10.5 to 1 made more HP than torque Let us know what yours does please Here is the cam card and the info I have. Hope it helps and I will report back when I know more.
[Re: AndyF]
#3110593
01/10/23 02:21 PM
01/10/23 02:21 PM
Posts: 1,543 USA
hudsonhornet7x
USA
Should make 600 hp. For max power you need a MW intake with the 270 heads, but the standard port intake with work okay with the 270 heads. During the 470 dyno tests that I did my Wilson ported standard intake made more power than the as cast Indy max wedge intake. So a good std intake will work just fine. I think I picked up around 20 hp when I had the Indy max wedge intake ported to work with my 270 heads. But that was a Dominator intake so not really apples to apples.
I made the most power with a 264/268 roller but you should still be able to make 600 hp with that cam. Not sure where the peak will be, maybe 6200 to 6500 rpm. Good luck, should be fun. Thanks for the info Andy. I don't have a particular horsepower/E.T. goal in mind but if it gets anywhere near that I will be pleased. I was able to get the Trick flow intake so I went with that. I can look into a low deck Max wedge intake. I would have liked to do a roller cam but had to cut costs where I could. Figured that a solid flat tappet would be a decent compromise.
[Re: fast68plymouth]
#3110627
01/10/23 04:42 PM
01/10/23 04:42 PM
Posts: 9,881 Weddington, N.C.
Streetwize
Weddington, N.C.
For a 505 to make almost 700 with the Trick Flow (Howards) HR cam that is on the small side at 243/247 @.050 and ~.600 lift and only a little over 10:1 is pretty impressive.
In a way the smallish cam would help the upper bottom without really Killing much on the top end. It would be interesting to compare the same basic combo with a 240 small port with a slightly say +10-12 bigger cam @.050 to offset the smaller ports.
I know Andy motor did this to an extent but I think the cam was considerably larger.
From a pure streetability perspective it would be interesting to see what the SMALLEST cam duration you could run and still make say 700 hp with the 2 different head combos.
But with your combo if the intake is ported you should still make about 620 I would think. the .450-.500 flow numbers for the 270's should put you there even with a fairly low lift cam...the intake is going to be your limiting factor if the runners cant keep up with the Heads.
The issue with port matching a 906 to a MW isn't really the gasket match, it's making sure the mouth of the plenum to each runner can outflow the head flange enough to feed the head at the torque peak. I used to spend hours working on Street Dominators back before we had much in the way of MW manifolds. Anybody else remember those days?
#3110629
01/10/23 04:48 PM
01/10/23 04:48 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
575-600hp my 440 with 270 heads (10.75:1) , Victor intake and 1050 4500 , 258/258 .520 nett lift sft went 10.70 in my Satellite @ 3690lb race weight . Eagle crank factory rods SRP pistons . Wallace shows 595HP
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
#3110658
01/10/23 07:17 PM
01/10/23 07:17 PM
Posts: 3,237 Md.
carnut68
Md.
Not to hijack the thread, how do Indy EZ heads MW ported compare to the TF 270?
America First!
[Re: carnut68]
#3110806
01/11/23 12:07 PM
01/11/23 12:07 PM
Posts: 16,929 NC
440Jim
NC
Not to hijack the thread, how do Indy EZ heads MW ported compare to the TF 270? From each manf web sites:
[Re: AndyF]
#3110821
01/11/23 12:43 PM
01/11/23 12:43 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Imo, the EZ295 is the direct competition for the TF270.
In true “ootb” form, I would expect the TF to win that shootout.
With the EZ295 valve job redone and blended, on a build with enough cubes to tax the area, and making enough power to really use up the heads (725hp+), my expectation would be that the power would be pretty close. I think It would make for a great test.
#3110844
01/11/23 01:55 PM
01/11/23 01:55 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
Hello.
I am having a 470 built for my car, and before it gets put on the dyno I was wondering what you guys think it will make. This is far from an all out build, just a fun street /strip engine designed for pump 93.
470" short block with Ross pistons, Eagle rods and Molnar crank. ( Molnar rods were not available when it was built)
10.5:1 Compression
Holley 950 HP carb
Comp 23-233-4 Cam, solid flat tappet, 252/260 @ .050, .540/.588 lift, 110 LSA ( XS290S grind)
Any guesses?
Any idea what the venturi size is on that 950 HP?
