Re: Cam position relative to lifter bore
[Re: RATTRAP]
#3110384
01/09/23 04:42 PM
01/09/23 04:42 PM
Posts: 4,457 Washington
madscientist
Washington
Is there a way to move the cam fwd in the block to get the cam lobes lined up center to the lifter bores? My cam looks like it needs to go about .125 to .25 fwd to line the lobes with the lifter bores If it’s a flat tappet cam they can’t be lined up. If it’s a roller then yes, they should be centered.
[Re: madscientist]
#3110479
01/10/23 12:11 AM
01/10/23 12:11 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
If you do this, check timing set gear alignment. I guess do it anyway. I needed to shim my crank sprocket for timing set in order to align with cam timing gear.
[Re: hemienvy]
#3110516
01/10/23 09:44 AM
01/10/23 09:44 AM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I thought flat tappet lifters were offset from the lobe centerline to make them spin. Nope. The bevel on the lobes and the convex face of the lifter are what do that.
[Re: RATTRAP]
#3110517
01/10/23 09:53 AM
01/10/23 09:53 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
My cam looks like it needs to go about .125 to .25 fwd to line the lobes with the lifter bores The key words here are "looks like". Moving the cam either way will move the oil feed holes in the cam relative to the ones in the cam journal decreasing or cutting off oil to the top end. It will move the oil pump drive gear contact point. And then there's the timing set which will probably now hit the cover and possibly not allow the balancer to properly seat which will change all your pulley alignment. Why don't you take your issue to the right place ... the cam manufacturer !!
[Re: Stanton]
#3110529
01/10/23 10:36 AM
01/10/23 10:36 AM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
My cam looks like it needs to go about .125 to .25 fwd to line the lobes with the lifter bores The key words here are "looks like". Moving the cam either way will move the oil feed holes in the cam relative to the ones in the cam journal decreasing or cutting off oil to the top end. It will move the oil pump drive gear contact point. And then there's the timing set which will probably now hit the cover and possibly not allow the balancer to properly seat which will change all your pulley alignment. Why don't you take your issue to the right place ... the cam manufacturer !! You bring up some very good points, I will do some more measurement's before I go after the cam manufacturer, could be the lifter bores in the block were drilled incorrect.
[Re: RATTRAP]
#3110905
01/11/23 04:56 PM
01/11/23 04:56 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
So my next question is it a new or older version
[Re: Al_Alguire]
#3111159
01/12/23 12:58 PM
01/12/23 12:58 PM
RATTRAP
N/E, Michigan
So my next question is it a new or older version this is a 2012 alum block from KB
