HELP WITH PUSH RODS WITH 440 #311033
05/07/09 05:27 PM
05/07/09 05:27 PM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
RUNNING COMP CAM ROLLER ROCKERS ON A 440 I HAD A PROBLEM WITH 9.20 PUSH RODS NOT SHOWING ENOUGH THREADS ON THE BOTTOM OR THE ADJ. RUNNING COMP CAM 488 491 ANY IDEAS
Re: HELP WITH PUSH RODS WITH 440 [Re: FOXY312] #311034
05/07/09 07:54 PM
05/07/09 07:54 PM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
You could try a -.050 valve lock, if you have the clearance. Should be good for at least an extra thread.
Re: HELP WITH PUSH RODS WITH 440 [Re: momopar] #311035
05/07/09 08:17 PM
05/07/09 08:17 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
How much thread was showing? Between 1 and 2 is what most guys shoot for.
Re: HELP WITH PUSH RODS WITH 440 [Re: Classof70Chally] #311036
05/07/09 08:35 PM
05/07/09 08:35 PM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
SOME ROCKERS HAVE ONE TO TWO THREADS SHOWING AND SOME HAVE NONE
Re: HELP WITH PUSH RODS WITH 440 [Re: FOXY312] #311037
05/07/09 09:11 PM
05/07/09 09:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Please kill the caps. yelling is impolite. Thanks.
Re: HELP WITH PUSH RODS WITH 440 [Re: stumpy] #311038
05/07/09 09:15 PM
05/07/09 09:15 PM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
SORRY ABOUT THAT THANK YOU FOR YOUR HELP
Re: HELP WITH PUSH RODS WITH 440 [Re: FOXY312] #311039
05/07/09 10:44 PM
05/07/09 10:44 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Guessing it's a hyd cam? What heads? How are you adjusting the preload? Use the int. opening/ex. closing method. My best guess is...either they are not adjusted correctly or the valve stem heights are way out of wack. Again it's only a guess based on the limited info from your original question.
Re: HELP WITH PUSH RODS WITH 440 [Re: Dcuda69] #311040
05/07/09 10:55 PM
05/07/09 10:55 PM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
YES ITS HYD CAM, EE RPM 84CC, MOTOR IS ALL NEW NOT FIRED YET. STARTING AT 0 LASH USING OPENING CLOSING METHOD ALSO CHECK ALL THE VALVE STEM HEIGHTS TOO THERE OK
