tire section width and rim width question.
#311007
05/07/09 04:26 PM
05/07/09 04:26 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
Do any of you happen to know if the measured section width of a tire will change at all when simply changing a wheel/rim width. I have mach'd up a 15X8 wheel with a 275-60/15 Drag radial and it looks as though a 15X10 may be a better wheel for this tire. I just dont want the section width to get stretched all that much more than it is already. Is that even possible?
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
Re: tire section width and rim width question.
[Re: PUNK]
#311008
05/07/09 04:32 PM
05/07/09 04:32 PM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A close estimate is the section width grows half the increase in wheel width. In this case, two inches more rim equals an inch more total tire width at its' widest.
