Page 3 of 4 1 2 3 4
Re: If you were buying white-letter radials which one? [Re: TC@HP2] #3106927
12/31/22 12:14 PM
12/31/22 12:14 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
I wish someone would reproduce the Super Stock Formula 1 tires.Coker? Please!!! drinking
Re: If you were buying white-letter radials which one? [Re: 70VcodeCoronetRT] #3107016
12/31/22 04:32 PM
12/31/22 04:32 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The redline radial tires I got from Diamondback for mine are a Milesteel carcass.
The lettering is blacked out , otherwise look like so on the other side
https://cdn.discounttire.com/sys-ma...t-product-default-format_dt-product-Zoom
I have no complaints with ride or handling
Re: If you were buying white-letter radials which one? [Re: DAYCLONA] #3107048
12/31/22 06:38 PM
12/31/22 06:38 PM
USA
Grizzly69 Offline
Grizzly69  Offline
USA
Originally Posted by DAYCLONA
Originally Posted by 469runner
Originally Posted by MOPARMIKE69
When they turn brown just break out the lacquer thinner and a rag and wipe them off. The BFG's with all their shortcomings is still the best looking tire for our cars IMHO.
I have BFG, GoodYear, and repro Polyglas RWLT's on my toys that all brown......no paint pen needed, Trichloroethylene, a rag and one's finger, whitens the crap out of the letters
Is there a specific brand that you use ?
How about this one:
https://www.amazon.com/Trichloroethylene-Purity-Solvent-500ml-Model/dp/B013P3OL30/ref=sr_1_6?
I've tried everything on my BFG's
Brake cleaner, lacquer thinner, bleach white, goof off - tried all with a rag, paper towel and red scotchbrite.
The best I've been able to achieve was a light tan color.
Turned sh*tty brown again in just a few days, not being driven-just sitting in the garage.
Re: If you were buying white-letter radials which one? [Re: Grizzly69] #3107238
01/01/23 02:08 PM
01/01/23 02:08 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
When mine was built back in 2010 I went with the Mastercraft Avengers...
I needed/wanted a very tall wide 17" tire on the rear and a normal sized 15" tire on the front...
Back then there were no other options to have both raised white letters and a matching tread pattern...
When these wear out or have to be changed I don't know what I'll do... shruggy
...FAFO...
Re: If you were buying white-letter radials which one? [Re: skicker] #3107400
01/02/23 01:06 AM
01/02/23 01:06 AM
manitoba canada
BleedDodge Offline
BleedDodge  Offline
manitoba canada
Bought cooper cobras to replace the BFG radial t/a’s on my car recently.
Re: If you were buying white-letter radials which one? [Re: BleedDodge] #3107772
01/02/23 07:07 PM
01/02/23 07:07 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
Has anyone tried the Vitour Galaxy Radial G/T?
They have 7 different 15 inch sizes and have a V rating on the 60 series and an H on the 70 series.
https://www.prioritytire.com/vitour-galaxy-r1-radial-g-t-255-60r15-102v-as-a-s-all-season-tire/
Re: If you were buying white-letter radials which one? [Re: skdmark] #3107852
01/02/23 10:50 PM
01/02/23 10:50 PM
Alberta
440_Offroader Offline
Alberta
When you scroll down on that link, there is the 'customers also viewed' area. There are 9 different options for 15" wheels, including the Firestone Firehawks... Pretty good selection, but some I've never heard of.
Re: If you were buying white-letter radials which one? [Re: skdmark] #3107903
01/03/23 05:35 AM
01/03/23 05:35 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
I have them on my Charger in 235/60R15 (front) and 295/50R15 (rear) and they are waaay better than the BFGs and Coopers I had previously on the Charger. I see in your link that the 275 and 295 tires aren't listed - they are available though, maybe they can order them.
Re: If you were buying white-letter radials which one? [Re: DGS] #3108241
01/03/23 06:47 PM
01/03/23 06:47 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Nice thread pattern!
Re: If you were buying white-letter radials which one? [Re: DGS] #3108265
01/03/23 08:12 PM
01/03/23 08:12 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Can you post any pics of them on your Charger?
Re: If you were buying white-letter radials which one? [Re: Suregrip391] #3108273
01/03/23 08:41 PM
01/03/23 08:41 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
@DGS Thanks for the feedback.
I was checking around local shows this past year and had yet to run across anyone using them. .
I'm not a fan of BFG radials (S rating), browning of letters, and real bad when wet out. Been there and done that.
The Cooper Cobras have S and T ratings and Mastercraft Avenger have M and S ratings.
So far the Vitour's are the only ones I found with a V rating (60 series)
Re: If you were buying white-letter radials which one? [Re: Suregrip391] #3108455
01/04/23 02:47 PM
01/04/23 02:47 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Re: If you were buying white-letter radials which one? [Re: DGS] #3108578
01/04/23 07:49 PM
01/04/23 07:49 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Mickey Thompson SRs and Maxxis Marauders are both H speed rated. The Maxxis has a pretty high UTQG rating. The SRs have no UTQG rating but MT is claiming they are only good for 20-25k miles which would mean they are somewhat soft. Neither of these come with white letters.
I didn't see a UTQG rating on the Galaxys. With the closed should tread block, I wonder how they do in water? Also, is it my imagination, or is their tread lettering not equally spaced on all tires?
Re: If you were buying white-letter radials which one? [Re: TC@HP2] #3108584
01/04/23 08:18 PM
01/04/23 08:18 PM
Alberta
Alberta
It sure looks like the front tire is off on the spacing. I didn't notice at first, because I was drooling over the car. That's a beautiful Charger! drool
Re: If you were buying white-letter radials which one? [Re: RJS] #3108585
01/04/23 08:25 PM
01/04/23 08:25 PM
West Central Indiana
PROSTOCKTOM Offline
PROSTOCKTOM  Offline
To me there is only one choice for white letter tires.
B.F. Goodrich TA's
Tom
Molnar Technologies Full Service Dealer - Crankshafts & Connecting Rods
Re: If you were buying white-letter radials which one? [Re: PROSTOCKTOM] #3108592
01/04/23 08:45 PM
01/04/23 08:45 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
I think they look great in the pictures above but up close I think the lettering is too big. I found this image online.
Re: If you were buying white-letter radials which one? [Re: mopars4ever] #3108597
01/04/23 08:51 PM
01/04/23 08:51 PM
San Antonio, Tx
bulletpruf Offline
bulletpruf  Offline
San Antonio, Tx
BFG Radial T/A. Pictured here on my old '68 hemi RR.
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: If you were buying white-letter radials which one? [Re: DGS] #3108615
01/04/23 09:22 PM
01/04/23 09:22 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I would like a RWL radial in like a 305 60 15 but that doesn't exist in RWL. The 295 50 is not tall enough in my opinion. I like the letter paint but my hands would not be steady enough for perfect results.
Keep old mopars alive.
Re: If you were buying white-letter radials which one? [Re: 2boltmain] #3108761
01/05/23 03:44 AM
01/05/23 03:44 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
You are correct, the spacing of the lettering is different on the fron an rear - rear is opposite, front is off (in the "empty" section it says Vitour but you can't really tell cause the lettering is black). No clue why they did it that way (the offset lettering is on the small width tires - I think 255 and up have it on the opposite side).
Performance in rain is good (better than the BFGs or Coopers) but you still have to be careful with a high hp RWD car in the rain - nature of the game I'd say.
Re: If you were buying white-letter radials which one? [Re: DGS] #3108763
01/05/23 04:57 AM
01/05/23 04:57 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
On this thread I found very interesting two deals…
1-it seems Indy500 tires are available again?
2-radial RWL tires on 15” with a modern thread pattern and V speed rated are available now!!!
Page 3 of 4 1 2 3 4
