You are right I am not real familiar building a custom brake system that's why I am taking a close look at my car and asking questions
since I don't really know if the guy or guys who put this car together had the knowledge either.
bottom like my a$$ is the one that's on the line if something isn't right or fails.
After talking with Wilwood tech, he says that for a drag race car having more brake in the rear is good since a drag car has much more tire on the rear than the front.
1500 lbs according to him is a bit much so I will adjust some to the front. only a 100 lbs or so.
The system has 7/8 front and rear master cylinders he says that is also good for a drag race car. It appears that the system is pretty close.
One thing I don't understand WHY is:
the front brake line {20 inches} from the master cylinder to the line lock is 1/4 inch tubing and the rest of the system is 3/16 tubing?
does anyone know if there was a reason for this being plumbed this way, or would it make any difference?
thanks
