correct distributor for my 71 Super Track Pack
#3107915
01/03/23 08:35 AM
01/03/23 08:35 AM
Posts: 102 eastern L.I. ,NYC
kingdragon
eastern L.I. ,NYC
Looking for expert advice on the probable distributor for my 71 Charger R/T w/ A36 with 4 barrel. Car is a super track pack automatic and I cant tell if it was original electronic or single points distributor. Is there particular holes on the firewall that I should look for that would give me a tell-tale that it had electronic control box? I dont have the build sheet and the original engine harness was chopped up for racing ignition. Its my understanding that the sixpack cars got a dual point system but I dont know if the 4barrel super track pack cars would've came with. I'm eager to hear from you all. Thank you. -KD
I only buy MADE IN USA.
Re: correct distributor for my 71 Super Track Pack
[Re: moparmarks]
#3107962
01/03/23 11:12 AM
01/03/23 11:12 AM
kingdragon
eastern L.I. ,NYC
Thanks for this. If I read you right 1971 440hp 4bbl had no option for electronic ignition.
[Re: moparmarks]
#3107968
01/03/23 11:37 AM
01/03/23 11:37 AM
Posts: 6,224 JERSEY
RJS
JERSEY
Single points. For 71 the electronic ignition was an option on 340 cars. 72 was an option on all cars and 73 it was standard. I believe 1972 first year for standard electronic ignition. Ron
[Re: RJS]
#3108209
01/03/23 05:47 PM
01/03/23 05:47 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Single points. For 71 the electronic ignition was an option on 340 cars. 72 was an option on all cars and 73 it was standard. I believe 1972 first year for standard electronic ignition. Ron My father bought a 72 Duster twister , 318 , built in late nov/dec 1971 , it had points.
[Re: kingdragon]
#3108243
01/03/23 06:52 PM
01/03/23 06:52 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
1971 440 HP with Automatic
Distributor 3438694 Points
The distributor will have the electronic box retard feature attached to the vacuum advance
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: JohnRR]
#3108573
01/04/23 07:29 PM
01/04/23 07:29 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Single points. For 71 the electronic ignition was an option on 340 cars. 72 was an option on all cars and 73 it was standard. I believe 1972 first year for standard electronic ignition. Ron My father bought a 72 Duster twister , 318 , built in late nov/dec 1971 , it had points. I have/had several 72's with points.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: bee1971]
#3108574
01/04/23 07:32 PM
01/04/23 07:32 PM
moparmarks
The distributor will have the electronic box retard feature attached to the vacuum advance Correct
[Re: bee1971]
#3111118
01/12/23 10:28 AM
01/12/23 10:28 AM
kingdragon
eastern L.I. ,NYC
Thanks Bee71 this is great help. Can you explain what this electronic vacuum advance is/does please
[Re: kingdragon]
#3111298
01/12/23 06:16 PM
01/12/23 06:16 PM
bee1971
Sobieski Wi
1971 - DISTRIBUTOR SOLENOID All 383 and 440 engines (except the 440 3-2V) have a solenoid incorporated in the distributor vacuum advance mechanism to retard the ignition timing when the throttle is closed. At closed throttle, electrical contacts on the carburetor throttle stop and with idle adjusting screw in the closed position, causes the dis- tributor solenoid to energize. This retards the ignition timing to provide reduced exhaust emissions under hot idle conditions. Cold or part throttle starting is not penalized because the distributor solenoid is not energized unless the hot idle adjusting screw is against the throttle stop contact. Timing must be set at closed throttle to give ignition full retard. Read all about it here https://www.forbbodiesonly.com/moparforum/threads/vacuum-advance-w-solenoid.171617/
