Who makes builds the Most dependable/accurate distributor? #3106242
12/29/22 12:16 AM
12/29/22 12:16 AM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
So I’ve kind of wondered who make a good distributor that will last season to season, pass after pass without needing a full tear down. Also wondering if those same distributors are accurate for racing or better off as street car dizzy. Whould like to hear what Mopar members have gone through with their big/small block distributors.
Re: Who makes builds the Most dependable/accurate distributor? [Re: migsBIG] #3106258
12/29/22 01:11 AM
12/29/22 01:11 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Crank trigger with a gutted lean burn distributor (no advance) to spin the rotor in the cap.
Re: Who makes builds the Most dependable/accurate distributor? [Re: migsBIG] #3106262
12/29/22 02:24 AM
12/29/22 02:24 AM
I've used more than one stock OEM magnetic pickup Mopar aluminum recurved (I shorten up the mechanical advance so it idles between 14 to 18 BTDC idling and has 34 to 36 degrees total advance: up:) in my race motors with good success using MSD 7 series race ECU with the proper coils up scope up
Re: Who makes builds the Most dependable/accurate distributor? [Re: Cab_Burge] #3106296
12/29/22 09:57 AM
12/29/22 09:57 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
I've never had any issues w/ MSD pro billet distributors.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Who makes builds the Most dependable/accurate distributor? [Re: an8sec70cuda] #3106299
12/29/22 10:07 AM
12/29/22 10:07 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Any gutted cheap distributor with a crank trigger. Mine uses a 440 source. Going on 11 years 850+ passes. Never an issue. Cost wise isn't much different.
Doug
Re: Who makes builds the Most dependable/accurate distributor? [Re: dvw] #3106306
12/29/22 10:41 AM
12/29/22 10:41 AM
tboomer Online work
tboomer  Online Work
Doug...How do you ID the 440 source distributor? I have an aluminum one here but I can't find any markings on it. Sorry for the hi-jack!
Re: Who makes builds the Most dependable/accurate distributor? [Re: migsBIG] #3106311
12/29/22 10:50 AM
12/29/22 10:50 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I pull apart stock OEM distributors and thoroughly clean and lube the weight pivots and mechanism.
I put in Mr. Gasket #925B lightweight springs (mainly to aid in starting as full advance is all in at low rpm), set the reluctor wheel gap and put on a new Hillman nylon collar (available at Lowes). You can always lock out the mechanical advance mechanism if so desired.
We couple these with an MSD 6AL box and also add timing control (retard only).
This has been simple, super reliable and has given zero issues over the last 7 years with lots of street driving and dragstrip passes (read: abuse!).
I originally set this up with the thought process that if I did a drag and drive event I could easily get parts at any corner auto parts store. Unfortunately, it's getting harder and harder to get OEM electronic pickups, caps and rotors as time goes on. Best to have a stash of duplicates.
'63 Dodge 330
11.19 @ 121 mph
Re: Who makes builds the Most dependable/accurate distributor? [Re: GY3] #3106317
12/29/22 11:06 AM
12/29/22 11:06 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Same here. Stock mag pickup distributor, the Mr. Gasket spring kit, a 6AL and a 2 step retard box that activates for either start retard or when triggered by an external source. I use my NOS mini progressive to trigger the timing retard, and it pulls out 9* when the WOT switch activates. Unless the bushings or collar are worn, there isn't much to actually fail inside them.
Re: Who makes builds the Most dependable/accurate distributor? [Re: an8sec70cuda] #3106390
12/29/22 02:29 PM
12/29/22 02:29 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Same here up
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Who makes builds the Most dependable/accurate distributor? [Re: an8sec70cuda] #3106394
12/29/22 02:40 PM
12/29/22 02:40 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Nor Me, other than the annoying ozone corrosion, I clear lacquered it last time and it's held up OK. I also use a crank trigger. I don't gut the dizzy. In the past I've had to revert to using the trigger in the dizzy when the crank sensor has failed, simply a case of swapping the lead up
Re: Who makes builds the Most dependable/accurate distributor? [Re: BloFish] #3106407
12/29/22 03:04 PM
12/29/22 03:04 PM
Same here up
Which part number MSD BB Mopar distributors had the interior corrosion problems that MSD had to fix?
Re: Who makes builds the Most dependable/accurate distributor? [Re: Cab_Burge] #3106444
12/29/22 05:28 PM
12/29/22 05:28 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I use an MSD Pro Billet with the advance permanently locked out. Works fine - only downside is that it might rub your valve covers a little at that corner (440).
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Who makes builds the Most dependable/accurate distributor? [Re: 19swinger70] #3106446
12/29/22 05:34 PM
12/29/22 05:34 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I too have a MSD Pro-billet and it's been great for about 23 years now
eBay-cdwmotorsports
Re: Who makes builds the Most dependable/accurate distributor? [Re: Cab_Burge] #3106447
12/29/22 05:34 PM
12/29/22 05:34 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Same here up
I have 2. MSD part # 8456. Red caps. Both had the same rust issue on the reluctor wheel and pickup, they still functioned OK. The newest one was bought in 2014, oldest in 2011. I now use the black caps on them, they use brass (or stainless) high tension posts instead of aluminium. HTH's up
Re: Who makes builds the Most dependable/accurate distributor? [Re: Tig] #3106451
12/29/22 05:52 PM
12/29/22 05:52 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I had a MSD for a while, but they're big, annoyingly big, have to remove the cap to take the rocker covers off big. I recently bought a Summit pro billet distributor & its a good piece. Cap doesn't get in the way of the rocker covers & it uses the Chrysler style trigger. Comparing the prices of all the distributors on the market, I feel these are good value for money.
Re: Who makes builds the Most dependable/accurate distributor? [Re: rebel] #3106455
12/29/22 06:05 PM
12/29/22 06:05 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The Summit ProBillet is the same as the one that Fire Core used to sell - it will self destruct sooner or later! I have had three of them - all did the same thing - pure Junk
Re: Who makes builds the Most dependable/accurate distributor? [Re: DoubleD] #3106464
12/29/22 06:30 PM
12/29/22 06:30 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
How do they self destruct? The Mechanix of it is the same as a std mopar unit & they last forever, im sure Noah had one on his Ark.
Re: Who makes builds the Most dependable/accurate distributor? [Re: rebel] #3106470
12/29/22 07:12 PM
12/29/22 07:12 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have tried the MSD Billet distributor on two different occasions in my small blocks , both suffered from the corrosion issue . I went back to a stock type distributor and its been fine. I also use a MSD coil and 7AL2 both have had zero problems
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Who makes builds the Most dependable/accurate distributor? [Re: 11secdart] #3106486
12/29/22 08:45 PM
12/29/22 08:45 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've been running MSD distributors for years with no issues.
If it was the reluctor this will fix it.
https://www.amazon.com/dp/B001GA82Q...AXXTN&psc=1&ref_=lv_ov_lig_dp_it
Re: Who makes builds the Most dependable/accurate distributor? [Re: justinp61] #3106501
12/29/22 09:45 PM
12/29/22 09:45 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Since I’m bad with my hands and rode the little yellow school bus til college, I won’t be working on a distributor myself. laugh2
There used to be about 1/2 dozen distributors used since the 1990’s, but looks like MSD is the more popular, dependable unit. It’s the big dollar, but worth it if it work as intended (or better). If the relict or seems to corroded a lot, are this in areas with lots of snow, rain and salt in the winter seasons?
