Re: Who makes builds the Most dependable/accurate distributor?
[Re: migsBIG]
#3106258
12/29/22 01:11 AM
12/29/22 01:11 AM
Posts: 11,608 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Crank trigger with a gutted lean burn distributor (no advance) to spin the rotor in the cap.
[Re: migsBIG]
#3106262
12/29/22 02:24 AM
12/29/22 02:24 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3106296
12/29/22 09:57 AM
12/29/22 09:57 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I've never had any issues w/ MSD pro billet distributors.
[Re: dvw]
#3106306
12/29/22 10:41 AM
12/29/22 10:41 AM
Posts: 25,951 United Socialist States of Ame...
tboomer
Doug...How do you ID the 440 source distributor? I have an aluminum one here but I can't find any markings on it. Sorry for the hi-jack!
[Re: migsBIG]
#3106311
12/29/22 10:50 AM
12/29/22 10:50 AM
Posts: 4,684 Wichita
GY3
Wichita
I pull apart stock OEM distributors and thoroughly clean and lube the weight pivots and mechanism.
I put in Mr. Gasket #925B lightweight springs (mainly to aid in starting as full advance is all in at low rpm), set the reluctor wheel gap and put on a new Hillman nylon collar (available at Lowes). You can always lock out the mechanical advance mechanism if so desired.
We couple these with an MSD 6AL box and also add timing control (retard only).
This has been simple, super reliable and has given zero issues over the last 7 years with lots of street driving and dragstrip passes (read: abuse!).
I originally set this up with the thought process that if I did a drag and drive event I could easily get parts at any corner auto parts store. Unfortunately, it's getting harder and harder to get OEM electronic pickups, caps and rotors as time goes on. Best to have a stash of duplicates.
[Re: GY3]
#3106317
12/29/22 11:06 AM
12/29/22 11:06 AM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
We couple these with an MSD 6AL box and also add timing control (retard only). Same here. Stock mag pickup distributor, the Mr. Gasket spring kit, a 6AL and a 2 step retard box that activates for either start retard or when triggered by an external source. I use my NOS mini progressive to trigger the timing retard, and it pulls out 9* when the WOT switch activates. Unless the bushings or collar are worn, there isn't much to actually fail inside them.
[Re: an8sec70cuda]
#3106390
12/29/22 02:29 PM
12/29/22 02:29 PM
Posts: 16,487 On the run…
BloFish
On the run…
I've never had any issues w/ MSD pro billet distributors. Same here
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: an8sec70cuda]
#3106394
12/29/22 02:40 PM
12/29/22 02:40 PM
Posts: 2,924 A shed in England
Tig
A shed in England
I've never had any issues w/ MSD pro billet distributors. Nor Me, other than the annoying ozone corrosion, I clear lacquered it last time and it's held up OK. I also use a crank trigger. I don't gut the dizzy. In the past I've had to revert to using the trigger in the dizzy when the crank sensor has failed, simply a case of swapping the lead
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: BloFish]
#3106407
12/29/22 03:04 PM
12/29/22 03:04 PM
Cab_Burge
I've never had any issues w/ MSD pro billet distributors. Same here Which part number MSD BB Mopar distributors had the interior corrosion problems that MSD had to fix?
[Re: Cab_Burge]
#3106444
12/29/22 05:28 PM
12/29/22 05:28 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
I use an MSD Pro Billet with the advance permanently locked out. Works fine - only downside is that it might rub your valve covers a little at that corner (440).
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: Cab_Burge]
#3106447
12/29/22 05:34 PM
12/29/22 05:34 PM
Tig
A shed in England
I've never had any issues w/ MSD pro billet distributors. Same here Which part number MSD BB Mopar distributors had the interior corrosion problems that MSD had to fix? I have 2. MSD part # 8456. Red caps. Both had the same rust issue on the reluctor wheel and pickup, they still functioned OK. The newest one was bought in 2014, oldest in 2011. I now use the black caps on them, they use brass (or stainless) high tension posts instead of aluminium. HTH's
[Re: rebel]
#3106455
12/29/22 06:05 PM
12/29/22 06:05 PM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
I had a MSD for a while, but they're big, annoyingly big, have to remove the cap to take the rocker covers off big. I recently bought a Summit pro billet distributor & its a good piece. Cap doesn't get in the way of the rocker covers & it uses the Chrysler style trigger. Comparing the prices of all the distributors on the market, I feel these are good value for money. The Summit ProBillet is the same as the one that Fire Core used to sell - it will self destruct sooner or later! I have had three of them - all did the same thing - pure Junk
[Re: DoubleD]
#3106464
12/29/22 06:30 PM
12/29/22 06:30 PM
Posts: 4,647 aotearoa
rebel
aotearoa
I had a MSD for a while, but they're big, annoyingly big, have to remove the cap to take the rocker covers off big. I recently bought a Summit pro billet distributor & its a good piece. Cap doesn't get in the way of the rocker covers & it uses the Chrysler style trigger. Comparing the prices of all the distributors on the market, I feel these are good value for money. The Summit ProBillet is the same as the one that Fire Core used to sell - it will self destruct sooner or later! I have had three of them - all did the same thing - pure Junk How do they self destruct? The Mechanix of it is the same as a std mopar unit & they last forever, im sure Noah had one on his Ark.
[Re: rebel]
#3106470
12/29/22 07:12 PM
12/29/22 07:12 PM
Posts: 4,987 new jersey usa
11secdart
new jersey usa
I have tried the MSD Billet distributor on two different occasions in my small blocks , both suffered from the corrosion issue . I went back to a stock type distributor and its been fine. I also use a MSD coil and 7AL2 both have had zero problems
[Re: 11secdart]
#3106486
12/29/22 08:45 PM
12/29/22 08:45 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I have tried the MSD Billet distributor on two different occasions in my small blocks , both suffered from the corrosion issue . I went back to a stock type distributor and its been fine. I also use a MSD coil and 7AL2 both have had zero problems I've been running MSD distributors for years with no issues. If it was the reluctor this will fix it. https://www.amazon.com/dp/B001GA82Q...AXXTN&psc=1&ref_=lv_ov_lig_dp_it
[Re: justinp61]
#3106501
12/29/22 09:45 PM
12/29/22 09:45 PM
Posts: 21,648 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Since I’m bad with my hands and rode the little yellow school bus til college, I won’t be working on a distributor myself. There used to be about 1/2 dozen distributors used since the 1990’s, but looks like MSD is the more popular, dependable unit. It’s the big dollar, but worth it if it work as intended (or better). If the relict or seems to corroded a lot, are this in areas with lots of snow, rain and salt in the winter seasons?
