E body - tire and wheel size
#3105353
12/24/22 11:26 PM
12/24/22 11:26 PM
Posts: 4,728 Moved to N.E. Tennessee
GomangoCuda
I am putting the Dr diff 1" offset spring hangers and 67 Dana60 in my Barracuda this winter. What size DOT drag radial or bias ply slick is a good fit?
Re: E body - tire and wheel size
[Re: GomangoCuda]
#3105364
12/25/22 03:17 AM
12/25/22 03:17 AM
Posts: 43,215 Bend,OR USA
Cab_Burge
I am putting the Dr diff 1" offset spring hangers and 67 Dana60 in my Barracuda this winter. What size DOT drag radial or bias ply slick is a good fit? 29.5x10.5x15 bias ply on a ten inch wide rim What year Cuda and are the leaf springs in the stock location still?
[Re: GomangoCuda]
#3105377
12/25/22 07:46 AM
12/25/22 07:46 AM
Posts: 2,924 A shed in England
Tig
A shed in England
We used to run a 10 x 15 with a 5" back spacing with the old mopar offset kit and a 29.5 x 10.5 bias ply. The tyres would stick out of the bodywork 1/2" and we'd have 3/8" clearance (min) to the leafs, this was with an E body width Dana. Street tyres were ok but the slicks would rub sometimes when turning, mainly catching on the spring. We then moved the front spring mounts to the frame rails and put spacers and longer bolts in the shackles to give everything another 1 1/4" clearance, we also narrowed the axle 1" per side to b body width. With the same size and back spacing wheels, the tyres tuck nicely under the arch, which was good since we lowered the rear 1 1/2" at the same time. We now use a radial slick which is narrower than its bias ply counter part of the same designated size. Tyre is still close to the body work (outset) but doesn't rub since the car has plenty of rise in the rear, no rubbing on the springs either. This on a '74 Dodge Challenger (European Export model if that makes any difference) Anyway, HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3105406
12/25/22 11:20 AM
12/25/22 11:20 AM
Posts: 4,569 Motor City
6PKRTSE
Motor City
We mini tubbed mine and relocated the springs to the frame rails. I have Caltracs with -1" split mono leafs. I have 15x12 wheels with 315/60/15 Drag Radials and also run 29.5x10.5W slicks as well.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Cab_Burge]
#3105412
12/25/22 11:36 AM
12/25/22 11:36 AM
GomangoCuda
I am putting the Dr diff 1" offset spring hangers and 67 Dana60 in my Barracuda this winter. What size DOT drag radial or bias ply slick is a good fit? 29.5x10.5x15 bias ply on a ten inch wide rim What year Cuda and are the leaf springs in the stock location still? 70 Barracuda. Stock location springs, Caltracs, 275-60 dot drag radials for the last 20 years. Next time it's back sitting on tires it will have the springs 1" inboard per side and a 67 Dana. I think it will fit 295-65 when done.
[Re: Uncle Barry]
#3105813
12/26/22 10:23 PM
12/26/22 10:23 PM
Posts: 3,896 St. Louis, MO
Blues_Cuda
St. Louis, MO
A 295/65/15 on a 15x8 w/ 4.5 backspace fits really nice with no rubbing, even with 5 people in the car. A 69 B-Body Dana and Dr. Diff offset hangers/shackles makes it all possible.
The 2nd pic is with 275/60 ET Streets using the same size wheel. They are rather small in comparison.
[Re: GomangoCuda]
#3105861
12/27/22 10:06 AM
12/27/22 10:06 AM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
I am putting the Dr diff 1" offset spring hangers and 67 Dana60 in my Barracuda this winter. What size DOT drag radial or bias ply slick is a good fit? 29.5x10.5x15 bias ply on a ten inch wide rim What year Cuda and are the leaf springs in the stock location still? 70 Barracuda. Stock location springs, Caltracs, 275-60 dot drag radials for the last 20 years. Next time it's back sitting on tires it will have the springs 1" inboard per side and a 67 Dana. I think it will fit 295-65 when done. How good is the 67 Dana? I’m looking for one to change over from my 69 Dana axel in my 66 car
[Re: GomangoCuda]
#3106105
12/28/22 12:42 PM
12/28/22 12:42 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I'm running that same DrDiff set-up on my '70 with 325/50-15's. I did clearance the fender lip slightly just in case. I also used steel 1/4" spacers that I double checked fitment on the rim's mounting flange to fine tune the tire location within the wheel well. I also had to grind the leaf spring on the side slightly to add more clearance. They don't rub anywhere.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#3106298
12/29/22 10:07 AM
12/29/22 10:07 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I use a stock width E body Dana, 3/4" offset rear shackles, stock front spring hangers. 15x8 rim, 4.5" backspace, 295-65 radial. Had to trim the top inside of the wheel lip for clearance, but otherwise it fits good.
Using the B body rear and the Dr Diff kit is the way to go though. Eventally I'll narrow my Dana and use that kit to fit a 10" wheel.
[Re: an8sec70cuda]
#3106441
12/29/22 05:24 PM
12/29/22 05:24 PM
Posts: 707 California
BigDaddy440
California
Using the B body rear and the Dr Diff kit is the way to go though. Eventally I'll narrow my Dana and use that kit to fit a 10" wheel. First of all, I love this thread. Just what I needed to know / confirm. I'll be using a B body width Dana 60 with disc brakes and a 1" off-set system. I dig your car 8sec70Cuda. Mr. Porter used your engine / cam & car in our conversations to help me dial in the cam specs for my 540ci Hemi. I'm not shooting for 8's though, definitely a milder combo for mostly street and some strip use. If I run a low 10s or high 9s I'll be super happy. -Dan
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: cudaman1969]
#3107002
12/31/22 03:44 PM
12/31/22 03:44 PM
GomangoCuda
I am putting the Dr diff 1" offset spring hangers and 67 Dana60 in my Barracuda this winter. What size DOT drag radial or bias ply slick is a good fit? 29.5x10.5x15 bias ply on a ten inch wide rim What year Cuda and are the leaf springs in the stock location still? 70 Barracuda. Stock location springs, Caltracs, 275-60 dot drag radials for the last 20 years. Next time it's back sitting on tires it will have the springs 1" inboard per side and a 67 Dana. I think it will fit 295-65 when done. How good is the 67 Dana? I’m looking for one to change over from my 69 Dana axel in my 66 car Cudaman - PM sent
[Re: GomangoCuda]
#3107341
01/01/23 08:55 PM
01/01/23 08:55 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I like the looks of the 275/60/15 drag radial. I use a 15x9 wheel, my leaf springs are in stock location.
