72 Cuda Holley ECM location #3105032
12/23/22 08:27 PM
12/23/22 08:27 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
Well back on the Cuda after sitting a while cause of life interruptions . Car is 72 cuda with a 6.4 hemi and a 833 trans. Cat is going to have vintage air also. Holley prefers you mount the ECM inside car and cut a 2" hole in firewall. Wander if anyone has done this already and any pictures of install? Going to mount battery in stock location and make intake work. Also wandering where you mounted the fuel regulator ? What kind of fuel filter did you use? I ran stock fuel/return lines, and will adapt to hard pipe. Thanks for any inputs.
If want drop me an email
promano1958@gmail.com
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 72 Cuda Holley ECM location [Re: hulmule] #3105492
12/25/22 04:17 PM
12/25/22 04:17 PM
BDW Offline
BDW  Offline
Depends on the harness, I asked this same question with no response.
There's only 1 option for the Mopar harness, without completely redoing it.
Even with removing most of the tape, and rerouting, only spot available was right next to the AC box by gas pedal.
Harness just isn't long enough for any other spot inside car, without adding length.
Holley harness may be another story.
Another issue is whether the car has AC or not. Just not a lot of room.
Re: 72 Cuda Holley ECM location [Re: BDW] #3105617
12/26/22 09:58 AM
12/26/22 09:58 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
I removed the air inlet door assembly, (above the parking brake pedal)
I made a plexiglass block off and mounted my MSD 6AL to it.
I hope this helps
Re: 72 Cuda Holley ECM location [Re: UCUDANT] #3105807
12/26/22 10:12 PM
12/26/22 10:12 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
on my 70 E-Body I placed it passenger side interior under the glove box. Mine is a FAST ECU though, I had plenty of wiring to place it within the interior.
My Monster are real!
Living within your means makes life pretty easy.
