Re: The piston ring
[Re: GY3]
#3105021
12/23/22 07:46 PM
12/23/22 07:46 PM
Posts: 4,457 Washington
madscientist
Washington
It accounts for 40% of all engine friction according to Lake Speed Jr.! More than that if you still run tractor rings.
Re: The piston ring
[Re: GY3]
#3105049
12/23/22 09:17 PM
12/23/22 09:17 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
It accounts for 40% of all engine friction according to Lake Speed Jr.! The sizes and type rings will vary on the breakaway torque and the rotational torque, the finish on the cylinder walls will also affect the friction amount The last race motor I assemble for myself had 1.5,1.5 x3.0 MM low drag race rings in it as I was running a vacuum pump, it was very easy to start rotating and rotate it
Re: The piston ring
[Re: GY3]
#3105070
12/23/22 10:32 PM
12/23/22 10:32 PM
Posts: 10,735 North Dakota
6PakBee
North Dakota
It accounts for 40% of all engine friction according to Lake Speed Jr.! Hmm. Is that 40% of the frictional losses or 40% of all losses? I would think that the oil pump, water pump, and valve train contribute to the majority of mechanical losses, not necessarily frictional.
Re: The piston ring
[Re: 6PakBee]
#3105111
12/24/22 06:37 AM
12/24/22 06:37 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I often wonder why Ross, Diamond, etc. have not moved their shelf pistons over to a metric ring pack. My guess is availability of the 1.5/1.5/3.0 ring packs for certain bore sizes. Back when we did the 511" short blocks (2013ish) there were no metric ring packs available in 4.375 beyond the standard moly ring sets. I would not do a hotrod engine without upgrading the ring pack.
That brings me to a different topic. Why in the heck don't the piston manufacturers offer a separate part number for piston kits with an upgraded ring package. You have two choices, one of which is calling the piston manufacturer and paying more than Summit or whoever. The other option that is typically quicker and cheaper is buying the piston kit and upgraded ring kit from Summit and just eat a set or at least a 1/3 of a set of rings. Reason I specified 1/3 of a set is because Mahle, who I believe is currently the best value in Mopar stroker piston kits, sells thie GNS stainless ring set only as the top rings. You end up reusing the 2nd ring and oil slinky from the piston kit.
Theee is still nothing wrong with a good moly ring. I have seen moly rings take some serious abuse in a power adder combo that was .022-.024 end gap at 4.375".
Re: The piston ring
[Re: Jeremiah]
#3105133
12/24/22 09:15 AM
12/24/22 09:15 AM
madscientist
Washington
Theee is still nothing wrong with a good moly ring. I have seen moly rings take some serious abuse in a power adder combo that was .022-.024 end gap at 4.375". A 1.5 millimeter ring is basically.060 and you already have that. They need to go to 1.0/1.0/2.0 and catch up from being 25 years behind. I have been on the ass of UEM to make their Icon line the 1.0/1.0/2.0 ring pack but they say it would cost too much (thats a lie) and that not many guys would buy a piston for that ring pack because they think it won’t seal up (thats the truth). As for Diamond, Ross and the rest of them…who knows WTH they are waiting for. It’s not ring availability either. That ring pack is very popular.
Re: The piston ring
[Re: GY3]
#3105164
12/24/22 11:20 AM
12/24/22 11:20 AM
Posts: 4,209 New York
polyspheric
New York
What are they waiting for? Evidence of high enough sales volume to justify the production cost. Sell 100: $1,000 each Sell 10,000: $100 each
It's a business, not a hobby.
Boffin Emeritus
Re: The piston ring
[Re: GY3]
#3105209
12/24/22 12:57 PM
12/24/22 12:57 PM
Posts: 1,761 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Here are the turning torque readings I got while assembling my 408 SB stroker:
TURNING TORQUE - MAINS ONLY: 8 - 10 in-lbs TURNING TORQUE - 1 PISTON : 10 - 12 in-lbs (0.85 ft-lbs) TURNING TORQUE - 8 PISTONS : 105 - 150 in-lbs (8 - 12 ft-lbs)
That combo is fitted with Mahle PowerPak stroker piston kit (930271030) components, of which the rings (4035MS-112) are: 4.030" + 0.005" file fit set, 1.0 mm top ring, 1.0 mm second ring (HV385 steel/steel), 2.0 mm oil ring (Napier w/ standard tension).
Keep in mind, this was as "scientific" as a DIY guy like me could get. I literally went through multiple attempts with my in-lbs dial readout torque wrench to see what the steady-state turning torque reading was. So there is a bit of +/- in there.
