Moving leaf springs into the frame. 1993 Dakota #2613212
01/27/19 09:43 PM
01/27/19 09:43 PM
Memphis,TN
J. Hammer Offline OP
Memphis,TN
I have a 1993 Dakota that I drive on the street and bracket race. I want to move the leaf springs into the frame rails and looking for methods others have used to get it done. I'm thinking I'll make front hanger boxes like the MP kit for A bodys(using thicker material) and sliders on the rear. Anyone have any advice? Pics? Thanks
Re: Moving leaf springs into the frame. 1993 Dakota [Re: J. Hammer] #2613284
01/27/19 11:58 PM
01/27/19 11:58 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Are you intending on using the factory Dakota fuel tank? The left spring front bracket will be getting pretty close to the fuel tank. Your going to have to at least drop the tank to do much welding on that spring perch area.
The MP kit is designed to fit inside a tube frame and uses the inside part of the rail to mount the kit. A Dakota is a "C" channel where the spring brackets attach and the vertical wall is on the outside. You would probably have to box the frame, and remove the bottom section, at which point you may be farther ahead just drilling holes through the frame and inner boxing to bolt the front spring to.
The pictures are a 91 standard cab, long box, but other then the length, a 93 is the same frame design, and the fuel tank mounting compared to the front spring perch is the same, regardless of the frame length. Sorry I don't have any pictures of the exact area. Gene
Re: Moving leaf springs into the frame. 1993 Dakota [Re: J. Hammer] #2615148
01/31/19 04:00 PM
01/31/19 04:00 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
If you're willing to go thru with the frame modifications to move the springs in board, I would suggest kicking around the idea of 4 linking it and using coil overs rather than leaf springs.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Moving leaf springs into the frame. 1993 Dakota [Re: shanker] #2615191
01/31/19 05:27 PM
01/31/19 05:27 PM
begood Offline
begood  Offline
That's what I did.
THERE IS NO SUCH THING, AS TOO MUCH HORSEPOWER
Re: Moving leaf springs into the frame. 1993 Dakota [Re: begood] #3104688
12/22/22 08:36 PM
12/22/22 08:36 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I am definitely replying to an old thread. But I have soon will have a 95 Dakota and want maximum rear tire clearance at minimal effort. I saw 2 items that I think would accomplish that. So for the front I thought about welding the pictured pair of brackets to the frame for the front of the leaf springs. For the rear of the leaf spring the "Slider " brackets would be welded to the frame. Then a partial boxing in of the frame where those new brackets are welded.
Keep old mopars alive.
Re: Moving leaf springs into the frame. 1993 Dakota [Re: J. Hammer] #3121639
02/14/23 11:51 PM
02/14/23 11:51 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Here are some pictures I kept from a post a guy on Facebook made when he did his. I don't have Facebook anymore and lost his contact info.
Screenshot_20230202_222958_Photos.jpgScreenshot_20230202_223019_Photos.jpgScreenshot_20230202_223010_Photos.jpgScreenshot_20230202_223010_Photos.jpg
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Moving leaf springs into the frame. 1993 Dakota [Re: mopar65] #3121725
02/15/23 01:10 PM
02/15/23 01:10 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I am entertaining what was done in the above pics as well. The truck in the pics was well done. Thank you for posting them. If the springs are moved completely inside the frame Ill have to get a fuel cell to mount in the bed.
