Re: 6 Pack I.D.
[Re: 71ragtop]
#3104424
12/22/22 02:50 AM
12/22/22 02:50 AM
Posts: 43,230 Bend,OR USA
Cab_Burge
GM 427 Corvette Tri Power base, maybe Not like any Mopar I've seen for any productions cars, 440 or 340 Maybe early 390/406/27 Furd
Re: 6 Pack I.D.
[Re: Cab_Burge]
#3104428
12/22/22 06:02 AM
12/22/22 06:02 AM
Posts: 6,418 Abilene, Texas
fastmark
Abilene, Texas
I’ve never seen a Ford or Chevy base like those. The one with the small notch and the shield looks like a 70 non fresh air. The question is where is the brace on the end carbs for the stud to go through. Maybe they are just not completely finished or mistakes for the supplier.
Re: 6 Pack I.D.
[Re: lewtot184]
#3104447
12/22/22 09:39 AM
12/22/22 09:39 AM
Posts: 4,784 Ontario, Canada
mccannix
Ontario, Canada
somebody could have removed the brackets to install aftermarket carbs. You can see spotweld remnants where they pried the top bridges off. It appears to be one of the early re-issues from Chrysler in the late eighties into the 90's under the old part number 2946389. The tooling was modified with that long notch in the front, presumedly for the AC crowd. Below is the original Chrylser issue style
Re: 6 Pack I.D.
[Re: 71ragtop]
#3104448
12/22/22 09:41 AM
12/22/22 09:41 AM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
Can you take better pictures , all 3 are cutoff only showing sections instead of the entire unit
Re: 6 Pack I.D.
[Re: 6bblgt]
#3104794
12/23/22 07:45 AM
12/23/22 07:45 AM
fastmark
Abilene, Texas
all three of the OP's pictures appear to be of the same air cleaner
it has been modified - the carburetor bridges are gone & I believe the air shield has been added
this piece was sold thru Direct Connection/Mopar Performance in the late-'80s/early-'90s with the cutout on the driver's front for A/C compressor clearance The pictures are so close, they are confusing. I see two air cleaners. One with the air shield and small notch on the pass side and another with no shield and the bigger notch on the dr side for the ac compressor. I’ve never seen one with the ac notch. It’s clear from the bottom picture that the bridges have been removed on the outboard carbs. I bet your right. They were modified for three Corvette carbs of three center Mopar carbs. I’ve used three center carbs at one time before. I did not modify an air cleaner though.
